Old 02-25-2007, 07:19 PM   #4486
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
will this suit our G4S? i am seriuosly thinking of this upgrade!!
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 02-25-2007, 07:33 PM   #4487
or this is the correct one i think!!!
Old 02-25-2007, 07:37 PM   #4488
johnhsp's Avatar
Trader Rating: 18 (95%+)
Send a message via MSN to johnhsp Send a message via Yahoo to johnhsp Send a message via Skype™ to johnhsp
suit for G4S,but cannot use rear belt tension
Sanwa M11X With RX451
Xray 808 buggy,Ace DS1015,JP-3 Pipes,VP Pro 803
RB WS7 III,PR21BS(Precirotate),SH PX2009
Power by Rapicon fuel
johnhsp is offline   Reply With Quote
Old 02-25-2007, 08:34 PM   #4489
Ahhh cheers - how many use the rear belt tensioner?
Old 02-25-2007, 08:48 PM   #4490
Hye Guess the operationis working, here is the first Freeze shot keep in mind will do another to get it completly straight:
Enjoy the Before Shot
after Shot
Old 02-25-2007, 09:00 PM   #4491
just the tape process - for all to understand, LOL at my work desk at WORK
Old 02-25-2007, 09:35 PM   #4492
royfan33's Avatar
after Shot
Good for you! The freezer trick help me out many times on 1/8th buggy pipes. I think Nova pipes bend easier than some others, but the ice trick can usually salvage them....
I'm getting ready to paint a couple of bodies for next season. I'm no pro, but I like them to look decent. I was considering trying to do a "pro" type job with all the lines and colors, but I was also thinking of just keeping what I ended with. Tell me what you think of the one pictured. Excuse the battle wounds . It was an easy tape job, that is repeatable, and it stood out pretty good on the track.
royfan33 is offline   Reply With Quote
Old 02-25-2007, 09:43 PM   #4493
British Menace's Avatar
Originally Posted by casimirsa
My previous post
http://www.rctech.net/forum/showpost.php?p=2999138&postcount=3772 is still an "issue" to me
Reading through this forum most of the people say that the holes in the pistons needs to be drilled to 1.2 -1.3 mm
I first assemble my cars shocks with the pistons on standard 1mm holes.
now afer a few runs and test i decided to drill the pistons.
I left the pistons on the shaft with the metal washer underneath it. Firstly i took it to 1.1mm and noticed that the bit is is touching the washer.
My question now is if you take the holes to 1.2 or 1.3 does it realy help with the washer closing the hole for that 0.1 or 0.2 mm.
or am i to technical on this?
You are right. Some of the washers they supply for the shock building are slightly larger and you do have to watch this.
Either replace with thin section types that will not foul the larger holes or turn the one's you have down.
I turned mine down. I run with 1.3mm holes in mine.
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 02-25-2007, 09:44 PM   #4494
Looks good Royfan!
You can do my paint-jobs anytime...
Old 02-25-2007, 10:02 PM   #4495
Car Breaker's Avatar
[QUOTE=royfan33]Good for you! The freezer trick help me out many times on 1/8th buggy pipes. I think Nova pipes bend easier than some others, but the ice trick can usually salvage them....
QUOTE]
Agree with you. I went through like 3 Nova pipes and they all dent or bend easily. I waste so much money on them until I switch to Skyline. even with strong crash all I bent is a little on the header and the pipe is never dent what so ever. the same crush will mean a new pipe set for Nova. Nova should reconsider how they make their pipe.
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 02-25-2007, 10:15 PM   #4496
black-knight's Avatar
R/C Tech Charter Subscriber
Raced my virgin G4S at a local race here in Sydney on the weekend. The race is a yearly event called the Sydney Grand Prix. Anyway my car and motor went quite well, i qualified 9th, and finished 6th in the 30min final. (not bad for an electric racer lol ).
I was running harder than optimal from tire for the final, so next meeting ill be exploring softer fronts and ill run the speedshot front end for some roll adjustment. The car was faultless all weekend, no damage, no misbehaving.
The motor was a Team Orion WAPS REV .12, with the updated carby, i ran the standard G4S clutch with the Black TM spring & ED transmission.
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 02-25-2007, 10:17 PM   #4497
Originally Posted by black-knight
Raced my virgin G4S at a local race here in Sydney on the weekend. The race is a yearly event call the Sydney Grand Prix. Anyway my car and motor went quite well, i qualified 9th, and finished 6th in the 30min final. (not bad for an electric racer lol ).
congrats Black-Knight - its a start for better yet things to come!!! 30min final shit i wish we had those here ours are 10-mins or 15mnins!!! sometimes that longer time can make placements creep you up the ladder from others braking or flalling behind...!
keep it up
Old 02-25-2007, 11:36 PM   #4498
casimirsa's Avatar
after Shot
Glad it worked well for you that is a very good result!
Now for the second time make sure that the plug in the stinger is not in tight at all! You need to allow some pressure to release before all the water freezes!
My humble apologise to Novarossi for causing them to loose a sale!
"Horsepower is how fast you hit the wall. Torque is how far the wall moves after you hit it."
TM G4S (ED), TM G4S,SERPENT M2+835+960FD, MUGEN SEIKI MRX4-X, MUGEN SEIKI MRX4 (WORLDS CHASSIS), MUGEN SEIKI MTX4, MUGEN SEIKI MBX5T, HPI PRO4, TAMIYA, PALMARIS, RB C5+C5 RODY+V12 RODY, NOVAROSSI, JP, AXE ROSSI, MEGA, NOVAMEGA KHM, KO PROPO, HITEC, GRP, UFRA, ROBITRONICS, SJ, LRP
casimirsa is offline   Reply With Quote
Old 02-26-2007, 12:00 AM   #4499
Congrats' on a successful inaugural run with the G4s.
Not too sure if my spelling is right there but hey-ho...
I'm interested.....how did you find setting-up the G4s Nitro car in comparison to setting up an electric car?
I'm just the oposite.......I run 95% nitro and only this year have I even ran an electric car....mt TC4 (factory)....in a race?!!
Menace
Old 02-26-2007, 12:15 AM   #4500
Hey Guys the 4mm chasis will i need longer chasis screws to bolt everything else on? "Calling gansei master as he has a 4mm chasis
will be ordering this tomorrow to try out...!
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
