Old 02-18-2007, 01:30 AM   #4141
Z00M's Avatar
Trader Rating: 15 (100%+)
For whoever asked about the difference between the 2601 and the 2630, I've never run the 2630 so I can't comment on it's performance. I know Patto has run the 2630, maybe he has run the 2601 and could comment?
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 02-18-2007, 01:56 AM   #4142
Pattojnr's Avatar
Trader Rating: 19 (100%+)
ive never run the 2601, so i couldnt help there
but am very happy with the 2630.
as for round 2 , well done mike, on the win, unfortuantely i had probs with back markers that really too there toll, and some confusion left me sitting in the pits waiting for fuel i heard my name to come in but Sammy was looking at the screeen not nowing i was sitting there, got the car setup nice was easy to drive, just lacked a bit of mid steering for the final as grip came up i stuck with the 38 rears. but still happy with 3rd, as it was the most laps ive done in a 10 min final. just 6 seconds off finishing on the same lap as 1-2. as for the clutch set up mike, thats what i was running all day. 1 weight and about 1.5 threads with the black 1.8 spring, and 0.45 clutch gap.
think i need a bit more on the spring as i lacked a bit coming out of corners, but next time, always a next time. best lap previous was a 17.510, today in the final i strung 9 consecutive laps in mid and low 17's with a fastest lap of 17.002. so close to a 16. so im happy the car is getting better a s i set it up better now i need to drive it better. lol.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 02-18-2007, 02:29 AM   #4143
Serpentd's Avatar
With no disrespect intended, I think there is a little bit of bench racing going on here.
As far as shocks go, if you build them with medium rebound (I prefer to do it this way) you can use a lighter oil like the associated/losi 40wt. If you don't build it with the rebound you would need to set the shock up differently. The theory (and over here - in practice) is that this is similar to having a shock with different bump and rebound capabilities without having to use a heavy shock spring. I won't go into it any further but you should probably try both ways and see which one works best for you.
Cheers,
Mike.
Bench racing? Dude, I don't mean disrespect either, but what does this mean? Bench racing?
As far as shocks go I would have to disagree 100%. You want to have a consitancy with shocks. Adding some rebound or using less rebound to set up your shocks is not a tool you use for shock performance. This it what all the oils, pistons and springs are for. Now I will admit that it is very hard to set up shocks with no rebound but yet the right amount of absorbtion without any air involved. It almost has to be perfect amount of oil to do this every time. So to compensate for this "perfect amount of shock oil, manufacturers have used the hole in the cap to bleed the excess out or the best one yet on the market would be the new Serpent RCC shock absorbers. They use a foam piece inside the shock and a bleeder, however they now use a bottom cap like the Losi stadium trucks have used for years. Why go to all this trouble on making a shock when we have the standard G4S shock that has been around for over 10+ years? To get the perfect amount of bleeding WITHOUT any rebound. You just can't be as accurate on 4 shocks EVER time using rebound as a tuning tool.Though you might not feel it, it is trowing off your tweak somewhat and you will need to compensate for it somewhere. For example your steering trim or whatever.
Dude, if it works for you, awesome. But I wouldn't recommend this form of practice to a beginner. I know you couldn't recommend it to a semi-pro or pro driver, they wouldn't take your advice.
Not trying to piss anyone off ZOOM, just what I know from my 10+ years of racing and originally learning from the guys that were in the A and B mains at the Winter Nats. Yes, I do know most of those guys plus many more all over the world. Not talking about knowing who they are, but racing with them and talking with them at the track. Lots of those guys were A main drivers 10 years ago.
So for everyone that reads this, I guess go with your instinct and what works best for you. Later all!
Blessed are the SIC
Serpentd is offline   Reply With Quote
Old 02-18-2007, 02:31 AM   #4144
Serpentd's Avatar
ZOOM, as far as your cluch tuning goes, you are DEAD ON!!! Hope you didn't think I was attacking you or your post bro about the shocks. Maybe I am just the hard headed type. Actually, I am pretty hard headed. Peace bro!
Blessed are the SIC
Old 02-18-2007, 02:40 AM   #4145
Gascar 24's Avatar
well done zoom and patto
g4s on the podium again
starting to be a common event
but there is nothing common about the G4S man
paul
3 Racing f113
Savox, Thunderpower ,Speedpasion,Turnigy,DX3R
www.rcformula.com.au what a site for all your F1 needs
Gascar 24 is offline   Reply With Quote
Old 02-18-2007, 02:58 AM   #4146
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Well done boyz, G4S 1st & 3rd - ya cant complain about that!!!
patto - unlucky man with pit man and carby, hope ya fix the prob for next round, thou congrats on ya time bro - looks like nothing in it!!!
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 02-18-2007, 03:08 AM   #4147
black-knight's Avatar
R/C Tech Charter Subscriber
The next thing is the clutch flyweight weights. If you put 1, 2, or no weights in the clutch, this has an impact on the holding/engaging 'strength' and timing of the clutch. While it would be like a lightened flywheel in the minutest amount, this is not why it's done. If it was then we would just lighten the flywheel. With all the weights in, the clutch will engage and stay locked. If you run with 1 weight, then your clutch will engage a little softer but also a little later, and if you run with no weights it will engage softer still and even slip a little as well as engage later. This is all assuming you don't play with the clutch gap and spring preload while changing the weights.
Today for example I started with no weights in the clutch, a 0.7mm gap and 1 thread of preload. With this combination, there was too much slip. I ended up with 1 weight, .4mm gap and 2 threads of preload to get the engagement I was looking for. So as you can see, everything affects everything.
By the way, I qualified second today and won the main event. It was a great battle with a different MTX-4 driver from last week but awesome fun. I think I won the main by about .1 of a second in the end.
So that's 2 wins from 2 starts in our championship so I couldn't be more happy with the way things are going.
Cheers,
Mike.
Mike,
Did you use the black clutch spring or red one?
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 02-18-2007, 03:44 AM   #4148
Z00M's Avatar
I actually got this tip from 4 time BRCA 200mm touring car champion(2 on rubber and 2 on foam all in consecutive years) so I guess some pro's do use it.
As for bench racing, it's theory versus practice, and again, with no disrespect, you have no experience with touring cars, by your own admission. I actually tried this same setup on a 1/8th car and it didn't yield the same results. Perhaps because of the weight of the car I'm not sure. All I was trying to get across in my post was that there could be benefits that you haven't explored yet in a touring car. I guess when the weather lets up, you can try anything you like. Like I said before, everyone has different experiences and I try not to dismiss something that I have not tried.
I took no offence and my words here are not intended to cause any offence either, just sharing my own experience. Once I set up my shocks like this, I went from having top 10 results to having the top results I have now. I can build the shocks with the same rebound every time and I am careful to get them exactly the way I want them. My car even runs straight when set on the setup board so it can't be too tweaked.
As stated before, everyone should try whatever they want to try. Seems in this case there is no single answer, so I am not saying that you SHOULD construct your shocks with rebound, just that you COULD.
Cheers,
Mike.
XRAY XB4
Old 02-18-2007, 03:45 AM   #4149
Serpentd's Avatar
Congrats bro!!! 3rd is very awesome, but what is more awesome is your consistancy and lower lap times. This is where it's at! I'm way happy for you dude.
Blessed are the SIC
Old 02-18-2007, 03:46 AM   #4150
Z00M's Avatar
Originally Posted by black-knight
Mike,
I used the black spring. This has become my favourite as it seems very versatile.
XRAY XB4
Old 02-18-2007, 03:51 AM   #4151
Pattojnr's Avatar
Thanks D , for the encouragement, its all up to my driving now
Serpent - Walter RC
Old 02-18-2007, 03:55 AM   #4152
Serpentd's Avatar
Cheers,
Mike.
Dude, you are absolutely right about the lack of excperience with sedan. All my experience is in 1:8 scale. It just seems more logical to have a consitancy without rebound. But that is what you mean by bench racing. No offence dude. I suppose it will give me something to take a look at. So if I do try rebound, how much do you recommend? Like the shock shaft extends fully? or half way? what is a good starting point? Thanks dude.
Blessed are the SIC
Old 02-18-2007, 04:33 AM   #4153
Thanks for the info.
Old 02-18-2007, 08:22 AM   #4154
Send a message via MSN to ickvanovs
i dont really understand about the shock rebound... what it suppose to act .
can someone explain it in a more simple way? or probably a video?
i thought shock should return to its normal position as fast as it can.
ickvanovs is offline   Reply With Quote
Old 02-18-2007, 10:06 AM   #4155
Trader Rating: 244 (99%+)
NO. If you have shock rebound like you are discribing then your shocks are pressurized. You should have NO shock rebound. Do the shocks you are using have a bladder? If so you should fill the shock with oil. Place the shock bladder on top of the oil. press down in the center of the bladder with the end of an exacto knife until it seals to the body. then put the shock cap on.
***A-Main Hobbies, ProTek RC, AKA and Integy***
Fred Perkins is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
