Team Magic G4
Old 01-29-2007, 03:44 AM
  #3661
itchy b's Avatar
Great post Menace!
I never thought of it that way but it makes a lot of sence.
Looks like i'll be looking out for a set of setup wheels for the tool kit then
itchy b is offline
Old 01-29-2007, 05:18 AM
  #3662
Kodak Hodak's Avatar
Originally Posted by itchy b
Great stuff Kodak
What's with everyone missing the dogleg section to take a shortcut around the back off the start
to keep it clean at the start, i could only imagine carnage at the intial dogleg.....
its how we do it up here, just get away and get going, the race aint won at the first corner or first lap......
here is a nice clean laps of the state champion in a MTX4
http://www.youtube.com/watch?v=XbhAqNCaIA4
enjoy
Kodak Hodak is offline
Old 01-29-2007, 06:45 AM
  #3663
razzor's Avatar
BM great info ,makes a lot of sense and will note that in my tech book for my pit bag.
razzor is offline
Old 01-30-2007, 12:32 AM
  #3664
gansei's Avatar
Default my g4s..
i changed linkage stopper(for easy setup linkage)
and new dark option fuel tank.
gansei is offline
Old 01-30-2007, 01:58 AM
  #3665
British Menace's Avatar
Hey Gansei,
That is a nice car.
Are they 26mm tires you run on the rear or 30mm?
Menace
British Menace is offline
Old 01-30-2007, 03:13 AM
  #3666
Serpentd's Avatar
Originally Posted by British Menace
Hey Gansei,
That is a nice car.
Menace
Dude, those almost look like 30mm in the front and rear? So my distant friend Gansei, what size are those???
Plus how do you run your car without rounding the edges of the tire? Or do you let the tires round off and "scrub" in after some track time? I have ALWAYS rounded the edges to help avoid chatter so to speak? Just curious.
By the way, are those the Serpent shock balls you use for the top of the shock caps? I know you have posted it before but can't remember, plus all my Serpent "balls" are black, not brass in color like yours. I keep debating on that change or not. I do like the quick removal of the shock with those things.
What is the difference of your new tank? Obviously the cap, but why? Is it for a more consistant preasure or something? By the way, YES you have a very sweet car . Another thing is I still need to test out some different rear sway bars from other manufactures to see if I can avoid the update you did, the G4S sway bars just seem so soft in general that I want to try some others like Serpent or Mugen first. They also look like a different diameter, but need to play around a bit with that. If I do go the route you did on that rear sway bar set up you have, is the MTX4 the best route to go, or is there "other" bars that will work that you might know of? Dude, sorry for all the questions. I will post a few photos of my car tonight, plus a pic or two of the type of weather we are having here in good ole Colorado, USA. COLD and SNOW!!!!!!
One last thing, I also run the SMP Slide! I LOVE my 1:8th scale. I have actually only ran touring once at one race and that was back in October a few months back, and it wasn't a G4S , it was the S720 . Still a nice car, but it was a short notice race and I had to buy what ever I could find at the time. But now I have 3 G4S's to make up for it! I've been racing 1:8 scale for 8 years or so. Well dude, I don't want to keep boring the crap out of everyone so....Later bro!!!!
Serpentd is offline
Old 01-30-2007, 06:31 AM
  #3667
fenix's Avatar
why the fuel filter in the pipe fuel line?
fenix is offline
Old 01-30-2007, 08:00 AM
  #3668
gansei's Avatar
it is used for back pressure.. not fuel filter.
i removed filter net.
gansei is offline
Old 01-30-2007, 08:12 AM
  #3669
gansei's Avatar
of course, front is 26mm rear is 30mm.. does it look like some wide?
i did not round edge of tire in exercise race (some bothersome.. ^^)
i like color of new fuel tank. so i buy it!
i received mail from Dario why he was using MTX4 rear sway bars.
and i agreed to his opinion that G4S rear sway bars is too soft.
and i changed to MTX-4 rear sway bars and feel good.
my shock ball is Kyosho 5.8mm ball (V-ONE RRR).
and i did NANO coating on ball.
so ball color is yellow.
i can expect smooth activity and no wear out by NANO coating.
gansei is offline
Old 01-30-2007, 08:27 AM
  #3670
gansei's Avatar
Default fuel cap tune
i changed fuel cap shaft by 20mm bolt.
it help that hold more strongly fuel tank body.
so i expect that NO fuel leakage
gansei is offline
Old 01-30-2007, 08:36 AM
  #3671
razzor's Avatar
The Kfactory tank looks good for sure and the adjustable handle on the lid is nice too.
You dont have to buy a new tank to replace the standard tank ,the tank lid is available and would be a nice upgrade.
razzor is offline
Old 01-30-2007, 08:45 PM
  #3672
Default K factory tank
Hi,
I got the K factory tank too. Looks cool and works well too.
On the Speedshot front end, the Aluminium piece. Is it still the best idea to JB Weld the two smaller lightening holes? For more strength?
Menace
Old 01-30-2007, 08:53 PM
  #3673
Teehomo's Avatar
Trader Rating: 24 (100%+)
Hey guys.
Can I ask what is the general consensus on setting droop? How many only use droop guages and measure under the arms, and how many use the lift and drop method?
Also, in the Xray setup guide (before you pounce, my son races a T2 ) it refers to downstop setting and droop. However, they both appear to measure the same thing.
Any ideas on the preferred method??
Teehomo is offline
Old 01-30-2007, 10:45 PM
  #3674
razzor's Avatar
Hi,
Menace
BM i think it would be a wise thing to do.I was impatient to do mine and its bent know.
razzor is offline
Old 01-30-2007, 10:59 PM
  #3675
Default speedshot
Razzor. Really?
Did it take much of a blow/hit to bend it?
Menace
