Old 01-28-2007, 12:58 AM   #3631
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Originally Posted by Serpentd
Kodak dude, I'm glad to hear you had what sounds to be like a good test and tune day. You started to "iron" out the new car blues as I call them. Anyway, as far as your question in regards to your receiver pack, there are a few so called methods. For starters, think of your pack as a maximum of 1 hour of run time with a full peak charge. Hence why you can have a 1 hour main. However don't push the one hour out of your pack unless it is a main.
I always start the day with a full pack. In the morning after "practice" is done whether it's 2 or 9 tanks, I top of the battery for the heats for the day. Then after 3 heats I will top it off again for the main. Doing it this way, I NEVER have to worry about running too low.
However there are small volt meters so to speak that you can connect to the receiver to monitor voltage. They are small and shaped like a rectangle. They are about 1.5cm x 4cm and fairly flat. They have about 8 green led's and 3 red led lights. I have used them in the past for my airplanes. This is about all I know of for actually monitoring the votage while attached to the car. They weigh almost nothing, so weight isn't an issue. But if you just pay attention to how many tanks you are running, you really don't need a monitor other then paying attention.
I would suggest to put some sort of rubberband or something around the throttle of the carb. I actually use these little black or clear hair ties. They are like very thin rubber bands, but much stronger and the fuel doesn't hurt them. I have NEVER had one break. You do need to tripple them up to make them shorter if you know what I mean because of there length. This makes them "shut" the carb to idle just incase your Throttle rod ever came loose or broke or any of the thinks that can go wrong. I have seen it happen plenty of times on other vehicles, and has even saved me more then once.
I'm not sure if I answered your question, but this is what I do and have NEVER had a runaway ever in over 8 years of racing every form of nitro vehicle. The best of luck to you my friend, it sounds as though you are off to a GREAT start!!!!!! Your USA support friend...
Excellent you have made me rest at peace now, will use that rubber band trick as i do notice when the ball cup comes off the throttle the sleeve of the carb does push forward, so i think thats wise move.
As for the monitor of the battery, i gotcha, will invest in a decent swallow charger and possible that L.E.D light.
Your Australian friend
Frankie....
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 01-28-2007, 03:19 AM   #3632
shano's Avatar
Send a message via MSN to shano
Default Next Meet
Hey guys so dissapointed i didnt bring my g4s to LH after spending the day there so next meet im there WITH MY CAR without fail.I miss it so much and its driving me crazy so next 2 weeks are full on track time
shano is offline   Reply With Quote
Old 01-28-2007, 03:57 AM   #3633
Toy000's Avatar
I hear ya shane, im itchin to get my car out there as well. im well on top of the runaway glitch problem, and hope to be getting some decent laps down before the next meet. If all goes well and the 2 top runners belt each other off the track again, were gonna be in for a Team magic 1 2 3 Here s hopin i get rid of my gremlins.
Motonica.... its just like da Ferrari!
People say i know nothing but I know [email protected]#K ALL!!!!
Toy000 is offline   Reply With Quote
Old 01-28-2007, 04:05 AM   #3634
shano's Avatar
Well all i can say is that i may not finish in good position but i may be able to help wide out the others Hey at moment its all about finishing he races and keeping consistant laps for me then ill start to try and push my positions up hey u going up next sat
Old 01-28-2007, 04:07 AM   #3635
MaDaGAS CAR's Avatar
Send a message via MSN to MaDaGAS CAR
i had ball today an learnt so much bout the car!! wat should i do to get the g4 to handel better wen the tyres are still new and tonnes of foam left on em got me stuffed
MaDaGAS CAR is offline   Reply With Quote
Old 01-28-2007, 05:13 AM   #3636
ill become the darkhorse......
Old 01-28-2007, 05:39 AM   #3637
Serpentd's Avatar
Kodak my friend, here are a few pics of what I was trying to explain to you with the volt monitor and hair ties. I put the hair ties next to some smaller rubber bands to give you an idea of size along with the companys name to help you find these. Plus a pic of one installed on one of my engines. I found a few battery monitors after digging around some. The picture shows two different ones, these would plug into channel #3 or if you only have a 2 channel recevier, then you would need a "Y" splitter, Hope this helps some. Later bro!
Team Magic G4-copy-rc-shit-007.jpg   Team Magic G4-copy-rc-shit-008.jpg   Team Magic G4-copy-rc-shit-009.jpg   Team Magic G4-copy-rc-shit-010.jpg   Team Magic G4-copy-rc-shit-012.jpg
Blessed are the SIC
Serpentd is offline   Reply With Quote
Old 01-28-2007, 06:07 AM   #3638
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Hey D, still looks like you havent been able to run the G4S yet, how close weather wise is it, to being able to run, or start racing ? i know its cold as there, i have some friends going over there for a month, so they are expecting some very cold weather. hope its not too long before you run. and sounds like you have another Aussie friend, in Frankie (Kodak).
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-28-2007, 06:21 AM   #3639
g4-racing.de's Avatar
Also you can use this:
Carburettor Security O-ring: save your engine!
From This :
http://www.greenrc.net/
Marc
KM-racing H-K1/Novarossi/AXE-Rossi Engines/Robitronic germany
g4-racing.de is offline   Reply With Quote
Old 01-28-2007, 08:53 AM   #3640
gansei's Avatar
Default G4 New Steering System
K1480(G4 New Steering System )
what is difference of K1480 and Normal G4S Steering system?
more mild? or more quick? more stable? than normal?
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 01-28-2007, 09:12 AM   #3641
razzor's Avatar
Gansei thats not new its what used to come on the G4e/Mongoose .The swing rack steering system was good and smooth from what I heard but the current system on the G4S replaced the swing rack system and is preferred by most drivers that have run both cars.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-28-2007, 09:15 AM   #3642
razzor's Avatar
on the carb return spring/elastic band topic.A buddy says that the rubber bands used by dentists on braces works well and are fuel proof.Havent tried one ,looking into it though and will be going to check my dentist.
Casterracing ZX1.5R
Old 01-28-2007, 09:51 AM   #3643
gansei's Avatar
thanks for your advise..
But i could not understand exactly.. ^^
do you mean swing rack steering system is G4S normal steering system(single bell crank steering system)?
MY SPONSORS:
Old 01-28-2007, 10:00 AM   #3644
Sow&Steady's Avatar
Careful! He might just want to add some fillings onto your car instead!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 01-28-2007, 01:21 PM   #3645
afm
afm's Avatar
First G4 came with a sliding rail steering system, which had it's share of problems (binding of plastics on rails)
Then the G4 Evo came with the swing rack steering system (which you are showing), which worked well, but didn't have enough Ackerman.
Then came the G4S with the current single bell crank steering system, with lots of Ackerman and more steering than previous models. The option for this system is an adjustable bell crank arm…read here
http://www.kfactoryracing.com/produc...4118&pageNum=2
AFM
afm is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
