Old 01-17-2007, 06:32 AM   #3406
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by surreal
Come on guys, can anyone help me?
i have not found a online copy either on the G4s. but mongoose/ evo are on the TM site. maybe asking TM for a copy might get you somewhere ? have you lost your original ?
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-17-2007, 06:44 AM   #3407
NiMo's Avatar
Originally Posted by gansei
ED trans weight is some heavy.
so i did light weight tune for drive pully
Not so sure about the ED system being heavy, but what I do know is that with the standard drive system I could not get the Wasp CRF to pull out of a corner, no matter what clutch gearing set up I tried, and the motor always got very hot, so I switched to a torquey JP.
But since fitting this ED system I have had problems with wheelspin as I now have too much torque (even with tallest 1st gear), so last weekend I decided to try the Wasp CRF again, and is was pulling easily and running much cooler (16/20 pinion).
NiMo is offline   Reply With Quote
Old 01-17-2007, 06:47 AM   #3408
afm
afm's Avatar
i want to get droop setting relation information.
i think there are some rules when i must increase or decrease droop.
thanks.. ^^
This is a guide I've edited from different sources, hope it helps
AFM
GPP Model Racing
Team Magic-Peru
DOWNSTOPS
Down travel (or droop) is how far the suspension drops below when raised from ride height, before the tires leaves the ground. If you set a car on the ground, push it down a few times to settle the suspension, then begin to slowly pick up one end of the car, you’ll notice that the tires will stay on the ground for a little bit before they come up. This is droop.. Adjusting droop can greatly affect the way your car handles.
As you increase your front droop you will smooth the car going into the turn, and gain steering on the exit of the turn.
As you decrease your front droop your car will initiate the turn quicker but will have less steering coming out of the turn. The car will also have a more responsive feel.
As you increase the rear droop your car will gain more side bite and traction.
As you decrease the rear droop you car will become more responsive and will have less side bite, but giving you more steering.
Normally on low bite tracks such as parking lots you will find more droop will increase traction and hook your car up. On high bite tracks you will find that less droop will help keep the car flatter and increase corner speed and lap times.
If you need a little bit more steering on power, or in the middle of the turn , add a little more droop to the front suspension. If you want a little bit more rear traction in the middle of the turn, reduce the amount of droop in the front or increase the amount of droop in the rear.
IMPORTANT: It is very important to have the same downstop settings on the left and right
QUICK GUIDE OF DOWNSTOP ADJUSTMENT
Front Downstops
Higher
• Decreases front chassis upward travel on-throttle
• Increases high-speed steering
• Increases “initial” on-throttle understeer
• Better on smooth tracks
Lower
• Increases upward chassis travel on-throttle
• Decreases high-speed steering
• Decreases “initial” on-throttle understeer
• Better on bumpy tracks
Rear Downstops
Higher
• Decreases rear chassis upward travel off-throttle or under braking
• Increases stability under braking
Lower
• Increases rear chassis upward travel off-throttle or under braking
• Increases steering in slow corners
afm is offline   Reply With Quote
Old 01-17-2007, 06:57 AM   #3409
gansei's Avatar
AFM
GPP Model Racing
Team Magic-Peru
DOWNSTOPS
Front Downstops
Higher
Lower
Rear Downstops
Higher
Lower
thank you very much!!!
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 01-17-2007, 10:31 AM   #3410
razzor's Avatar
Ill try and scan one tomorrow ,last time I scanned amanual in pdf it turned out to be a very large file.Lets see what happens
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-17-2007, 10:35 AM   #3411
razzor's Avatar
That has been noticed by us as well ,its been from not enough to too much.
Would love to try out the new CRF in my car.Its supposed to be easier to tune.
Casterracing ZX1.5R
Old 01-18-2007, 03:16 AM   #3412
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Hey All,
Well got my butt into gear and got some heat shrink for the servo wires and antenna upper deck section.
I tell you its a real pain in the butt, as everything is tight a squishy....
But in the end i have done some mods that will make me sleep better i guess.
Mod 1. Drilled the hole bigger on the Alloy antenna holder - for more room and clearance.
Mod 2. Drilled the Reciever cage on the side, so the wire of the antenna comes out easy and not kinked.
Mod 3. Heat shrink the entire antenna right up inside of the balloon where the reciever is wrapped with 2 x balloons to protect as dirt & grime, plus prevent any glitches.
Mod. 4 Super Glued an OFF CUT cable tie, to the power plug attachment on the G4S, this helps to pull out after races etc.... Found the Tip on here!!! NICE
Mod 5. Resoldered the entire battery pack to be that bit more solid and less to fracture under bumps and rolls.....
Overall it went smooth, cant find any glitches yet, thou x-fingers all well once hits the track....!
Here's so,me pics to showcase what i have done!
Enjoy, feed back is always great
Team Magic G4-spektrum_dx3-22.jpg   Team Magic G4-spektrum_dx3-23.jpg   Team Magic G4-spektrum_dx3-19.jpg   Team Magic G4-spektrum_dx3-17.jpg   Team Magic G4-spektrum_dx3-21.jpg
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 01-18-2007, 04:16 AM   #3413
Toy000's Avatar
Originally Posted by MaDaGAS CAR
i don t understand why it happens to u but not to me we have same car,radio and spectrum cant see why i dont get this problem
im thinking the battery pack was to blame i resoldered it and took other precautions mentioned already
Motonica.... its just like da Ferrari!
People say i know nothing but I know [email protected]#K ALL!!!!
Toy000 is offline   Reply With Quote
Old 01-18-2007, 04:26 AM   #3414
shano's Avatar
Send a message via MSN to shano
Default NEW SHELL
Hey guys Just painted my first shell for my g4s turned out great.Kosta servos work fine thankyou i appritiate it and last of all i get me novarossi 2630 pipe and manifold next week.I CANT WAIT IM EXCITED
shano is offline   Reply With Quote
Old 01-18-2007, 04:37 AM   #3415
MaDaGAS CAR's Avatar
Send a message via MSN to MaDaGAS CAR
good to here well cum on then wheres the pics of the shell u cant say u painted it but dont show us
MuGeN powered by MAX POWER !!!!
MaDaGAS CAR is offline   Reply With Quote
Old 01-18-2007, 04:38 AM   #3416
shano PICZ, PICZ, PICZ
Old 01-18-2007, 04:42 AM   #3417
shano's Avatar
Default shell
hey guys got no camera at the moment so i go to my bro tommorrow night and use his.how do i import photo into forum and what resolution should it be?????
Old 01-18-2007, 05:06 AM   #3418
yeah its not the best solder on ther, i have also re-soldered my battery pack.... Just to be safe of the 100mph flying karate air crash....
Heres a PIC
Old 01-18-2007, 05:14 AM   #3419
shano's Avatar
Default race day hobbies
hey guys how do i check raceday hobbies out i tryed racedayhobbies.com but horse racing comes up
Old 01-18-2007, 05:16 AM   #3420
shano's Avatar
Heres a PIC
thats my next job resoldering battery pack
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
