Old 01-16-2007, 12:08 AM   #3361
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
this is a really silly question , but i just got my Spektrum from the US, and in the book it tells me nothing on what servo to use!!!
There is the following:
1 x Hgh Torque Servo - is this for Steering or throttle?
1 x Standard race Servo - is this for Steering or throttle?
i am sure its a simple answer!
Cheers
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 01-16-2007, 12:22 AM   #3362
fenix's Avatar
you can use a high speed servo on the trothle,and a high torque servo on the steering..
Or high speed high torque on both, i have two 9402 futaba servos, or the 94357 aitronics trothle or 94358 steering..
fenix is offline   Reply With Quote
Old 01-16-2007, 12:31 AM   #3363
Gascar 24's Avatar
Trader Rating: 15 (100%+)
Originally Posted by gansei
your other question is "would i have to get the carbon fibre nose or could i use the standard nose part that is with the car !!!!" ?
i could not understand what do you mean.
sorry for my poor english.
did you mean what part is between carbon front upper plate and wide bumper?
it is sponge normal bumper. but i cutted it.
But now.. i changed sponge bumper + wide bumper
i think sponge bumper protect body to be crushed.
sorry gansei
i meant the carbon fibre top support would i have to get that or will the stock top bummper support do the job
paul
3 Racing f113
Savox, Thunderpower ,Speedpasion,Turnigy,DX3R
www.rcformula.com.au what a site for all your F1 needs
Gascar 24 is offline   Reply With Quote
Old 01-16-2007, 12:39 AM   #3364
gansei's Avatar
Cheers
if you enjoy heavy breaking, pls use high torque servo in throttle.
anyway, steering servo is protected by servo saver.
and servo saver act very much in high speed corner.
so. the road surface resistance is high. high torgue servo do not best performance because servo saver.
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 01-16-2007, 01:10 AM   #3365
Thanks guys........ working on it as we speak!!!
Old 01-16-2007, 01:35 AM   #3366
Hey Guys,
is this right what i am doing? the wirring - is there a special way to run it?
Should i zip tie them together for neatness?
Tips, Tips, Tip please.....
Cheers
Frankie
Team Magic G4-spektrum_dx3.jpg   Team Magic G4-spektrum_dx3-2.jpg   Team Magic G4-spektrum_dx3-3.jpg   Team Magic G4-spektrum_dx3-4.jpg
Old 01-16-2007, 01:44 AM   #3367
muppet racing's Avatar
Originally Posted by johnhsp
anyone try K14118,which one better (L,M,S) thank
Hi, Not much of an answer but it really depends on the track and grip levels, L (same as stock G4S) works well in the UK (low - medium grip) but we did use S at the worlds (high grip), its supposed to turn in a little sharper, and then a little less steering coming out of a corner. I havent tried the M position.
Its just a case of trying each and seeing what suits your track/driving style.
Good Luck.
muppet racing is offline   Reply With Quote
Old 01-16-2007, 01:52 AM   #3368
Hi Frankie,
I dont think there will be room behind your throttle servo to run your leads as it may rub on the side of your tank, I would run them on top of the servo, then turn into the back of receiver box (engine side). I would use rubber grommets to keep them together, just a bit more flexible if you have to move things about.
I also smooth off any sharp corners of plastic/alu, where any leads run.
But my cars never look the neatest, its purely functional !!
Good Luck.
Old 01-16-2007, 02:06 AM   #3369
Gascar 24's Avatar
Originally Posted by muppet racing
Hi Frankie,
Good Luck.
i agree
thoughs cable ties will wear though everything in there
frankie sometime neat is not practical all i have done is twisty tied ( from the freezer bags the soft wire ones) the main long bit of the leads but if there one thing about the g4s i dont like its this issue
u will fine that wherever a wire can fit u will need to put one there
so as they say just stuff em in there dude and make sure none hang out the bottom
even mr neat freak rob has everything jammed in there including a failsafe
paul
3 Racing f113
Old 01-16-2007, 02:18 AM   #3370
razzor's Avatar
Hey Guys,
Cheers
Frankie
Wiring is looking good ,although I see in the second pic you mounted the reciever on the bottom plate ,id suggest mounting it up side down on the top cover ,it will help with running the wires and hooking everything up.The lower reciever bracket will be like a inspection cover so there is no unecessary movement of the wiring.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-16-2007, 02:30 AM   #3371
okie guys, heaps of cool information.......... changin again, and i have placed the reciever upside down as you mentioned RAZZOR...
As for everyones info, sweet, got the drill from you all and will make the smart mod of removing the cable ties....
cheers, will post more pics later.......
Old 01-16-2007, 03:43 AM   #3372
Z00M's Avatar
Patto, any idea when racing starts again?
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 01-16-2007, 04:14 AM   #3373
Pattojnr's Avatar
Trader Rating: 19 (100%+)
first sunday of Feb, should be the 4th. the racing calendar is on the site now. but i informed Boz that i did stumble onit and it does need advertising. i cant wait im itchin, its been too long.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-16-2007, 05:27 AM   #3374
Ok guys, been speaking to people all night.... yeah i went PINK balloon
Acutally i went double layer of the balloon, just to be safe.....!
Tell you the truth, its very very, fiddly at this part of the car.... but taken my time thas for sure...
Here are some pics:
cheers
Team Magic G4-spektrum_dx3-6.jpg   Team Magic G4-spektrum_dx3-8.jpg   Team Magic G4-spektrum_dx3-10.jpg
Old 01-16-2007, 05:37 AM   #3375
Pattojnr's Avatar
nice colour Balloons Frankie ! to be sure, to be sure. i am expecting the same nice color on your Mazda man. your getting close to running now ! i can feel the excitement building.
Serpent - Walter RC
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
