Old 01-14-2007, 08:02 PM   #3346
Send a message via AIM to T1bobo
Hey guys i have a Q!
I want to mount my RX on the car but somewhere it will be kinnda away from harm i know that its not gonna be easy but i'll take that risk! i was just wanting to know what i should use to mount it i was thinking super glue and put it on the side of the throttle servo or maybe on the upper deck could you point me where i need to go to get this right!!?
T1bobo is offline   Reply With Quote
Old 01-14-2007, 09:30 PM   #3347
MaDaGAS CAR's Avatar
Send a message via MSN to MaDaGAS CAR
mayb put ur battery pack where reciever goes and reciever where the batrey goes thats wat i would do and zip tie the reciever in i use square team magic battery packs so it works for me
MuGeN powered by MAX POWER !!!!
MaDaGAS CAR is offline   Reply With Quote
Old 01-15-2007, 03:05 AM   #3348
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
wouldnt this change the balance of the car?
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 01-15-2007, 04:15 AM   #3349
nope doubt it they are like 10grams mayb 20grams max nothing major
Old 01-15-2007, 04:52 AM   #3350
razzor's Avatar
Yes it would effect the balance.Id suggest fitting the reciever in its location but to mount it upside down and too the splash cover.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-15-2007, 06:17 AM   #3351
Pattojnr's Avatar
Trader Rating: 19 (100%+)
T1bobo has a different car, not a G4S or even a G4, he has the trinity reflex. so the weight balance isnt there to start with. what he wanted to know is how to mount his reciever, which razzor understood. and i dont think going backwards in mounting the battery pack where the mongoose was, is a move forward for the G4S. i think madagascar is just trying to be different as there has been an influx of the G4S in adelaide for this season, and maybe a bit dissapointed due to this as well. T1bobo you have PM.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-15-2007, 07:35 AM   #3352
personally i love the car its fantastic but i like to be diffrent its personal preferance by saying that im not gothic or any thing like that i dont mind other people having the car it doesnt bother me just wish they shopped around b4 they all just went a got 1 cos every1 else did. this might not be right but its just how it seems
but as they saying goes "the more the merryer"
btw patto where u get ur info from and wats the advantages of running the ed trans
Old 01-15-2007, 10:49 AM   #3353
Yeah i sould have told you guys that i dont have a G4/G4s i do have a trinity reflex! and i love it i would like to get a G4s one day but for now im in love with my REFLEX lol!
Old 01-15-2007, 01:49 PM   #3354
Pattojnr's Avatar
where did i get my info from ? what info ?
as for the ed trans, things are smoooooth. the new trans is able to give you some more gearing options. while you can gear the car for huge acceleration, but yet somehow through great design, you dont seem to loose out on top end either. and if you follow the k factory site, the ratios for before and after arent quite what they seem. 15/20 pinions for the new trans was like the 18/23 for the old trans. but applying that to the track the 16/21 seems more of a comparison to the 18/23 of the old system, even though the ratios are different. i suppose its the efficiency that has improved and i may even have to go 17/22 for my track, but i will see later on when the season starts. im itchin to go , cant wait
Serpent - Walter RC
Old 01-15-2007, 07:00 PM   #3355
afm
afm's Avatar
.........what are the advantages of running the ED trans............
The advantage of the ED transmission system is that the overall internal differential ratio drops from 2.526 on the Std system to 2.190 on the ED system......so let's say at equal final gear ratios on both systems, the ED system rotates slower putting less stress on the whole transmission system (bearings, belts, pulleys etc.) the engine spools faster, and top end improves, and also sharpness out of corners because also the clutch bell/pinions are lighter (6gms) vs the Std (13gms)...also mentioned is the advantage of having more low and high end ratios to cover almost any track....
On preliminary tests done by Team Phenix (D. Richey) some time ago, and somewhere in this thread, they reported an improvement of 8 full seconds in a 5 minute test.....it's tenths of seconds per lap that add up...so imagine in a main heat....
AFM
afm is offline   Reply With Quote
Old 01-15-2007, 07:30 PM   #3356
gansei's Avatar
Originally Posted by Gascar 24
hi guys
had a ball at my first club meet
finished 8th for the day
beacause 5mins into the final the 2speed nut that hold the first gear came off
and so did the first gear
and finished me for the day i reckon i was running about 5th at the time
but in qualifing manage 7th 5th 5th which i was happy with for a first run.
the car was plantted all day tyre wear was even so i reckon it was setup ok
now just need practice practice practice to improve an get to know the track a bit better
paul
ps thanks for the pic gansei would i have to get the carbon fibre nose or could i use the standard nose part that is with the car !!!!
also how did u mount your presure chamber on the deck im to scare to drill the carbon there as its very thin
i used cable tie in crack between battery and deck ^^
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 01-15-2007, 07:55 PM   #3357
johnhsp's Avatar
Trader Rating: 18 (95%+)
Send a message via MSN to johnhsp Send a message via Yahoo to johnhsp Send a message via Skype™ to johnhsp
anyone try K14118,which one better (L,M,S) thank
Sanwa M11X With RX451
Xray 808 buggy,Ace DS1015,JP-3 Pipes,VP Pro 803
RB WS7 III,PR21BS(Precirotate),SH PX2009
Power by Rapicon fuel
johnhsp is offline   Reply With Quote
Old 01-15-2007, 08:30 PM   #3358
Gascar 24's Avatar
Trader Rating: 15 (100%+)
thank gansei u are a very helpful man
did u see my other question about front end
paul
3 Racing f113
Savox, Thunderpower ,Speedpasion,Turnigy,DX3R
www.rcformula.com.au what a site for all your F1 needs
Gascar 24 is offline   Reply With Quote
Old 01-15-2007, 09:32 PM   #3359
gansei's Avatar
paul
your other question is "would i have to get the carbon fibre nose or could i use the standard nose part that is with the car !!!!" ?
i could not understand what do you mean.
sorry for my poor english.
did you mean what part is between carbon front upper plate and wide bumper?
it is sponge normal bumper. but i cutted it.
But now.. i changed sponge bumper + wide bumper
i think sponge bumper protect body to be crushed.
MY SPONSORS:
Old 01-15-2007, 09:53 PM   #3360
surreal's Avatar
Trader Rating: 39 (98%+)
Send a message via ICQ to surreal Send a message via AIM to surreal
Hey guys... sorry to interrupt. I need help finding a digital copy of the G4S manual.
Do you know anywhere I can download it? Can anyone scan it?
Take care
surreal is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
