Old 01-08-2007, 07:34 PM   #3256
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Hey All,
Stage 4 is finished... not too far away now
http://kodakhodak.blogspot.com/2007/...ld-up-pt4.html
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 01-08-2007, 07:41 PM   #3257
interesting belts? is it for show "bling" or they stronger?
Old 01-08-2007, 07:49 PM   #3258
British Menace's Avatar
Default Build
Hey Hodak
Good build review. Plent of photo's. I just got my new G4s from Sam and I'm looking foreward towards starting the build.
Darn work...........always gets in the way. Just when I have fun thing's to do at home...
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 01-08-2007, 07:52 PM   #3259
Default Belts.
Those yellow belts were the old K Factory belts they had before the new G4s low friction belts came out.
Some people had some problems with them shredding.......I never had that problem and they really did turn well.
I believe they were produced using Kevlar...not certain though.
Old 01-08-2007, 08:01 PM   #3260
Originally Posted by British Menace
Hey Hodak
Cheers for the kind words, its taken me 3 full days to get it to this stage, but i have also been doing the blog at the same time and doing many Avatars aswell.
Someone has way too much time up there sleeve...
Goodluck with your build and dont be shy to post away here, so all us can see
Old 01-08-2007, 08:12 PM   #3261
Default May do
You build well Hodak......so praise where it's due I say.
This will be my 3rd G4 now. I got one of the originals back in ....?....was it 2003?
Can't remember now
Anyway.
The car come such along way since the G4C I had then.
Do you have a special room set up for building your car Hodak?
Just curious because we just got a new house and I'm using the basement to do all my RC stuff in.
Old 01-08-2007, 08:33 PM   #3262
Can't remember now
Anyway.
Would you believe i build the car on a japanese large coffee table, with a old bed sheet to protect the table and for the advantage to see any parts i drop.
Generally i sit in front of the TV, put a cool DVD on and work away.....!
The missues, she is cool as she does support the new craze, she thinks i am a KID.....
Any as for i build well, well i am getting support from a "birdy friend" & have done research on other forums like 3.hobby.net....!
thou cheers on the kindness of words!
Old 01-09-2007, 03:07 AM   #3263
shano's Avatar
Send a message via MSN to shano
Default i know i shouldnt post this here but HELP ME GET RID OF THIS!!!
Hey guys i have a Gpx4 to trade that is 7 months old.It has a hyper 12 motor in it an has only had 2 races run through it.Plenty of spares, the only thing it dont have in it is reciever and servos.It will include some tools like tyre wrench andd etc.
I AM AFTER any of these
-Gel cell battery and charger
-TM starter box
-Hex Wrenches
-2 high speed metal geared servos
-tm tools and car bag
-telementry for spectrum dx3
-Any hop ups for Team Magic G4S (k-Factory)
shano is offline   Reply With Quote
Old 01-09-2007, 03:34 AM   #3264
gansei's Avatar
Originally Posted by afm
ADJUSTING FRONT AND REAR GEAR DIFFERENTIALS
Gear differential action is adjusted by filling the gear differential with differential oil of a specific viscosity.
Differential oil is rated with a “viscosity” number that indicates the thickness of the oil, which determines how much the oil resists flowing. Differential oil with a higher viscosity (for example, 100,000 oil) is thicker than differential oil with a lower viscosity (for example, 40,000 oil).
• To make a gear differential LIGHTER, fill it with thinner oil.
• To make a gear differential HEAVIER, fill it with thicker oil.
EFFECTS OF FRONT GEAR DIFFERENTIAL ADJUSTMENT
Lighter Front Differential (thinner oil)
• Decreases understeer
• Decreases stability under braking and acceleration
• Increases chance of traction roll
Heavier Front Differential(thicker oil)
• Increases understeer
• Increases stability under braking and acceleration
• Reduces chance of traction roll
EFFECTS OF REAR GEAR DIFFERENTIAL ADJUSTMENT
Lighter Rear Differential (thinner oil)
• Decreases on-throttle steering
• Less acceleration if the grip is there
• Less predictable car (cars with very “loose” diffs have a tendency to understeer heavily under throttle and turn-in oversteer as soon as you lift)
• Less on-throttle oversteer (snap-oversteer)
• Less turn-in understeer
• Less stable under braking
Heavier Rear Differential (thicker oil)
• Increases on-throttle steering
• Better acceleration if the grip is there
• More predictable car (cars with very “loose” diffs have a tendency to understeer heavily under throttle and turn-in oversteer as soon as you lift)
• More on-throttle oversteer (snap-oversteer)
• More turn-in understeer
• More stable under braking
TRACTION CONSIDERATIONS:
* The higher the traction, the lighter the diff oil up front, and the heavier at the rear.
* The lesser the traction, the heavier the diff oil up front, and the lighter at the rear.
AFM
thanks for good information.
But i could not understand about TRACTION
what do you mean by "The higher the traction","The lesser the traction" ?
The higher the traction means "high grip"? or "high speed circuit"?
i want to know about the exactly meaning of TRACTION Word !!
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 01-09-2007, 03:58 AM   #3265
Gascar 24's Avatar
Trader Rating: 15 (100%+)
i reckon he means grip
by the way great info AFM
paul
3 Racing f113
Savox, Thunderpower ,Speedpasion,Turnigy,DX3R
www.rcformula.com.au what a site for all your F1 needs
Gascar 24 is offline   Reply With Quote
Old 01-09-2007, 06:24 AM   #3266
afm
afm's Avatar
ByTRACTION I mean GRIP.....as Paul said
High Traction Track = High Grip Track
Less Traction Track = Low Grip (loose) Track
AFM
afm is offline   Reply With Quote
Old 01-09-2007, 09:28 AM   #3267
gansei's Avatar
AFM
thanks for your reply...
i think that front diff must be harder than rear diff.
so i quess that it is good front 100000, rear diff 10000 in low grip Track.
and front 50000, rear 40000 in high grip Track.
MY SPONSORS:
Old 01-09-2007, 10:29 AM   #3268
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Default Car setup tips needed
Hey guys.
I hope i can get some help
This is the track i will be running at this year and it will be my first time out there. I am hoping that you pros could help me with a base setup before i get out there?
http://www.jacksonrcracing.com/onroadpics.htm
The track seems a little small with tight turns. Hopefully you can give me some setups just by looking at the track.
nitrobeast is offline   Reply With Quote
Old 01-09-2007, 10:48 AM   #3269
razzor's Avatar
Bud you could work with the setup Gansei posted earlier or use Muppet's setup of of 3hobby.It would be good enough to get you in the ball park.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-09-2007, 10:55 AM   #3270
nitrobeast's Avatar
Yeah i printed out Gansei setup. I was gonna start with the stock setup but not sure if i want 2.
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
