Old 01-06-2007, 08:41 AM   #3181
NiMo's Avatar
Originally Posted by itchy b
Thanks Mate,
No wonder the Aussies won the ashes 5-0 with guys willing to lend a hand to fellow Aussies
Cheers
Joe
Yeah! we had to let them win, just so our ears can get a rest, which they haven't since we took it from them
NiMo is offline   Reply With Quote
Old 01-06-2007, 08:52 AM   #3182
Pattojnr's Avatar
Trader Rating: 19 (100%+)
here we go, excuses excuses. maybe a match fixing enquirey is needed ? maybe the English cricket team heard that if the Aussies didnt win back the ashes, that warney wouldnt retire untill they did ? then it was too late to try and win a game cuse they played themselves out of form by doing so ?
so many questions , one answer. Aussie Aussie Aussie, Oi! Oi! Oi!
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-06-2007, 09:16 AM   #3183
MaDaGAS CAR's Avatar
Send a message via MSN to MaDaGAS CAR
lol we won to bad you guys had nuthin just remember 5-0 anyways......
bak to the topic of avatars kodak and chance of makin a half greek flag and half australian just testing to see how good u are
just another quick question has any1 got vrc and how would u rate it out of ten if im gona spend 200aud on a pc game and adapter its gotta be good
MuGeN powered by MAX POWER !!!!
MaDaGAS CAR is offline   Reply With Quote
Old 01-06-2007, 10:42 AM   #3184
gtrmx's Avatar
Originally Posted by razzor
Im proud to wear the colours bro.
GTRMX is the car that heavy that you need to lighten it that much !
Whats your guys min weight ? ours is 1.8kg
Our minimum is 1.725 kg with transponder...
A long way to go if you compare with other cars out there...
gtrmx is offline   Reply With Quote
Old 01-06-2007, 10:44 AM   #3185
British Menace's Avatar
Hey T1bobo,
Don't panic mate. I used to run the Reflex in the Uk Nationals and it does take some time to get used to.
There are some odd qwerks with that car which seam to make things happen which don't make sence sometimes.
I'm sorry I'm not sure exactly what you already know so you may have heard this already.
Disconnect the rear shocks from the A arms. The arms should now move all the way up and down smoothly. Sometimes when the arms get to the higher points in their movement, they get stiff or jerky. This can make the car spin out at some weird times. Also, I found that using a short wheelbase gives more steering and is good on the smaller tracks and the middle setting on the rear bottom A arms is good for the larger tracks.
Also. I found using the bottom shock location on the rear A arms was good in low to medium grip tracks and the top setting for the high grip stuff.
Now, I never ran a rear sway bar and I ran the rear very stiff. The car seamed to like it. I used to run between 23 and 32lb springs on the front with 60 to 80wt oil and 34 to 37lb springs with 50 to 80 wt oil in the rear.(Bumpy and smooth tracks respectivly)
0 toe in front and 2 to 3 degrees in the rear. 2 degrees camber all round.
4 to 5mm ride hight front and 5 to 6 in the rear on 62mm tires.
Most important though is to make sure those rear arms 'fall' under their own weight without the shocks connected and no jerkyness.
Make sure your shocks move smoothly. The stock piston with the o rings are great but you do nead to maintain them frequently. Also, the shock mountings, make sure these are 'loose'. The shock should be able to turn on the mounting but no movement, or very little, when the arm is moved up and down.
I hope this helps.
Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 01-06-2007, 10:49 AM   #3186
gtrmx's Avatar
Originally Posted by T1bobo
OK NOW IM PISSED
It's been 4 days now that i have been working on my car and i still have yey to get the right setup everytime i go out and drive it all it wants to do is swing out in the rear.... i put the stock springs back on and it helped a little but not as much then i put a softer shore tire in the rear and nothing happend and now i just really dont know what to do could someone please break down each step on how to rise the ride height and the droop beacuse evertime i mess around with them its nothing but trouble also could you post pics of what i would need to play with the get the right setup(ride height,droop,etc)
PLEASE HELP ME!!
If there is extremely low traction use 5K silicon in the rear diff with a solid axle in the front... Only if traction is really low...
I once went to a track that required -1 of droop in the front and 0 at the back to keep the car planted. That means I had to unthread the front shock ball cups a bit to allow the suspension to travel down just a tad more...
You could also try 3.5 of toe in at the back and maybe 4 of rear camber...
Does your track have low traction?? If not let me know to give out other suggestions.
Also check that your dogbones are not binding as the suspension compresses.
Old 01-06-2007, 11:13 AM   #3187
macnkitty2002's Avatar
when might the G4S RTR be available in the US?
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 01-06-2007, 12:47 PM   #3188
razzor's Avatar
Check out Racedayhobbies
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-06-2007, 04:15 PM   #3189
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Gansei welcome onaboard.... Here you go budd!
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 01-06-2007, 04:31 PM   #3190
Oh, and those avatars are looking great
Is there any chance that you can make one with the Australian flag and Mugen logo for me?
you have PM.........
Old 01-06-2007, 05:22 PM   #3191
FREELANCE_RCer's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Kodak Hodak
Is this roughtly what ya after?
Excellent work on those avatars.
Hope you also do the Philippine Flag / Mugen Seiki too.
FREELANCE_RCer is offline   Reply With Quote
Old 01-06-2007, 05:51 PM   #3192
The MUGEN Aussie one is a once off, i can only say this as i have really only designed these for TMG4S Fans as we are seriuose in our cars and sport.
Just trying to keep the TM guys as a community together.....
Please dont take it personally its just if i start to do for every make, i wont get nothing done.
Spoken to Team Magic "Edith" they are over the moon in the design i have created and they have been kindly enough to send me a FREE TM T-Shirt for my efforts.
Or you could donate to the Kodak Racing funds if you require a custom Avatar, Lets say $1 AUD for an avatar.....
I just hope we all understand where i am coming from.
Regards
Frankie
Old 01-06-2007, 06:41 PM   #3193
revo523's Avatar
can i have a avatar i have a dollar with the usa frag!
revo523 is offline   Reply With Quote
Old 01-06-2007, 07:13 PM   #3194
gansei's Avatar
thank you very much~~
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 01-06-2007, 07:17 PM   #3195
Ok here is Stage 2 complete of the G4S Build
http://kodakhodak.blogspot.com/2007/...ld-up-pt2.html
Enjoy All....
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
