Old 12-14-2006, 02:48 AM   #2881
razzor's Avatar
Originally Posted by johnhsp
Here is my mods G4S,thx gansei
Looks good ,whats with the body posts sticking out back ?
Is that for a bumper ?
or to hold the body.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 12-14-2006, 02:50 AM   #2882
gansei's Avatar
good mod!
throttle server mods is very impressive!
is low center(G4S stock) good? or
is weight center(like MTX-4) and fast response time good?
gansei is offline   Reply With Quote
Old 12-14-2006, 02:51 AM   #2883
gansei's Avatar
Originally Posted by razzor
Great vid bud .
The one track has a very looooong back straight ,im sure taht must be a engine breaker.
yes! many RC user broken engine in end of back straight.
i also did.. ^^
Old 12-14-2006, 03:02 AM   #2884
gansei's Avatar
Default muffler question
i taken muffler from my RC friend for test
muffler is Meilke EFRA Nr2624 (pls see attachement)
i want to know this muffler's special feature.
pls advice..
Old 12-14-2006, 04:48 AM   #2885
NiMo's Avatar
pls advice..
Hope they've improved the strength of it.
I had 2 of them on an FW05, both got flattened in one meeting, it seems that only the slightest door handle rub would squash them, I then put the pricey Kyosho one on and that lasted 18 months without damage, and it performed better.
NiMo is offline   Reply With Quote
Old 12-14-2006, 07:09 PM   #2886
johnhsp's Avatar
Trader Rating: 18 (95%+)
Send a message via MSN to johnhsp Send a message via Yahoo to johnhsp Send a message via Skype™ to johnhsp
body post from bumper use,the throttle server is better than stock car,most faster & safe (servo)
Sanwa M11X With RX451
Xray 808 buggy,Ace DS1015,JP-3 Pipes,VP Pro 803
RB WS7 III,PR21BS(Precirotate),SH PX2009
Power by Rapicon fuel
johnhsp is offline   Reply With Quote
Old 12-14-2006, 08:30 PM   #2887
Send a message via MSN to ickvanovs
can you give more details on how did you do the servo mod?
thank you
ickvanovs is offline   Reply With Quote
Old 12-14-2006, 08:56 PM   #2888
johnhsp's Avatar
just cut the upper desk,& mods it,
Old 12-15-2006, 12:20 AM   #2889
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
the servo mod really makes no difference to me. that john has nothing to do, so thats y he modded it. kekeke... btw, john, dun be mad, m just joking k? cheers
uniquexme is offline   Reply With Quote
Old 12-15-2006, 12:44 AM   #2890
johnhsp's Avatar
wat r u talking about uniquexme,i think u better go to hell , ,but i like my mods ,next time mods again
Old 12-15-2006, 07:33 PM   #2891
uniquexme's Avatar
mod mod mod, u mod till ur car like shit. kekeke...
Old 12-17-2006, 09:20 AM   #2892
British Menace's Avatar
Default Set up change's?
Ok..............
Has anyone noticed any set-up change's when using the new speedshot baulkhead system and the new Flashpoint rear end system?
I have just ordered them and it crossed my mind.
Tony
British Menace is offline   Reply With Quote
Old 12-17-2006, 11:38 AM   #2893
razzor's Avatar
I fitted the front bulkhead but havent had a chance to try it yet.
rear upper arm though i have tested since I fitted teh quick release wheel setup.
I found the rear needed less camber with the new setup but will have to confirm next tim out to confirm.
Casterracing ZX1.5R
Old 12-17-2006, 06:44 PM   #2894
johnhsp's Avatar
anyone who have modify G4S pinion gear,cause G4S pinion is too wear,any good ideal
Old 12-17-2006, 08:10 PM   #2895
G4S'er's Avatar
I just wish to re-iterate the need to fill the two openings of the rear arms on the alloy bracket of the Speed Shot Buldhead system. I was out with my car and tested mine that has been filled! I tested it against different walls at different angles all for the good of you guys here on RC Tech! It held up beautifully. I believe we ( Raceday Hobbies ) are going to fill ours we have in stock. The alloy brackets in the Speed Shot Bulkhead system pack itself, and also on the individually packed alloy brackets before sending them out!
I had the setting on the Speed Shot at stock and didn't have the time to test other settings. But look forward to doing so in the near future. So I hope all racers that do try different setting let us know what you notice in your car's handling.
Putting on the Flash hubs with the new upper links I believe will need a change in camber and also will give a lot of options to work with also when spacers are played are added and removed. Unfortunately again I didn't have the time to work on different settings. Hard to play with things like this at a one day race.
I will tell you the ED Tansmission is one of the best pieces I have used to see a huge change in speed without shelling out another $400.00 for that "better new hot engine!"
This gearing system as promised is awesome off the line and off the middle of tight corners. The highlight of this ED Transmission is how easy it allows the engine to use all of it's available torque to reach rpm's and pull all the horsepower the engine has packed in it earlier and longer! I was getting ooooh's and ahhhhhh's as my mighty G4S bravely ran down the straight away catching and passing cars that were at least 1/4 down the straight before I even got on it. No special or "hot" new motor this week, just the same old wild azz MF.12MasMo that I had in the car before!
The G4S in 2007 is going to be ( and is now ) the car to beat! Anyone who jumped off the wagon recently better get the hell back on it again and soon! Winning in 2007 will be between the G and M cars next year. If you are a top driver and made a mistake and took the wrong ride, WE FORGIVE YOU !! .... However email me and maybe together we can open the path to Glory, Cheer, and best of all....FUN!
Merry Christmas to all of you and your families. May this holiday season be the best blessed season ever!
Sam
G4S'er is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
