Old 12-07-2006, 03:39 PM   #2821
NiMo's Avatar
Originally Posted by Lycan
How about that... the bearings from the 2 speed fit inside the larger bearings of the quick change hubs... means I can use my old UJ's and new hubs without the need to wait for spacers
What rear roll bar is that?
NiMo is offline   Reply With Quote
Old 12-07-2006, 03:47 PM   #2822
Mugen MTX3
Andrew
Lycan is offline   Reply With Quote
Old 12-07-2006, 04:09 PM   #2823
G4S'er's Avatar
Flash Pit inserts are in stock now. I was told a bearing would work but wasn't sure what bearing it was! However the inserts are much cheaper.
G4S'er is offline   Reply With Quote
Old 12-08-2006, 06:42 AM   #2824
gansei's Avatar
Default rear stabilizer tune
dario said that G4S's rear stabilizer was too soft.
so he changed rear stabilizer to Mugen style.
and i made a copy..
i will test it this weekend in korea local circuit.
and i made titan coating on shock ball. (kyosho 5.8mm ball)
this is very smooth and never wear away!
Team Magic G4-sany0001.jpg   Team Magic G4-sany0002.jpg   Team Magic G4-sany0003.jpg   Team Magic G4-sany0004.jpg   Team Magic G4-sany0005.jpg
gansei is offline   Reply With Quote
Old 12-08-2006, 07:01 AM   #2825
MaDaGAS CAR's Avatar
Send a message via MSN to MaDaGAS CAR
hey how did u put those pillow balls in ur rear lower arms to hold the sway bar wouldnt mind putting em in just found it a bit strange cheers
MuGeN powered by MAX POWER !!!!
MaDaGAS CAR is offline   Reply With Quote
Old 12-08-2006, 08:05 AM   #2826
Roki's Avatar
and i made a copy..
I noticed the different brake pad material you are using. what is it and is it any good.
Roki
Roki is offline   Reply With Quote
Old 12-08-2006, 09:40 AM   #2827
gansei's Avatar
Roki
this is a teflon brake pad.
i expect smooth breaking and long durability.
Old 12-08-2006, 05:40 PM   #2828
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
and i made a copy..
sweet mod.
uniquexme is offline   Reply With Quote
Old 12-09-2006, 04:23 AM   #2829
hi posted above on how the sway bar was attched but no answer just need to know how u got it to hold on to the bottom arm did u drill the hole out or is it a diffrent arm all together
Old 12-09-2006, 05:27 AM   #2830
GoFast's Avatar
Send a message via MSN to GoFast
Yes, you drill a hole (with a drll) to fit the ball screw which you attatch to the standard arm. Have a look at your G4S and you'll see where to drill the hole.
GoFast is offline   Reply With Quote
Old 12-09-2006, 04:25 PM   #2831
afm
afm's Avatar
Where did you get it?? is it an aftermarket pad, or did you just got xx teflon sheet an made it yourself ???
AFM
afm is offline   Reply With Quote
Old 12-09-2006, 04:41 PM   #2832
Gascar 24's Avatar
Trader Rating: 15 (100%+)
hey patto
paul here in sa
how is the ed trans going
we are not sure what to do with gearing over here yet have only drive the track twice so far
i have just run my LS3 in a bit and wow its quick but now i have the learn to drive all of again
paul
3 Racing f113
Savox, Thunderpower ,Speedpasion,Turnigy,DX3R
www.rcformula.com.au what a site for all your F1 needs
Gascar 24 is offline   Reply With Quote
Old 12-09-2006, 05:20 PM   #2833
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Hi Paul. 2 things about the ED trans, unfortunately i did a motor and pipe swap at the same time , so i cant compare to before. i will do some testing on monday week with the old motor and see the difference. secondly the one way i got was faulty so i spent most of the time trying to find a fault that i could do nothing about. what i did notice was that the gearing that comes with the trans, the 16/21 pinion and bell, was good for the Ls3. but i would like to try out the 17/22 gearing as well. the motor looked faster than a Zac motor that was running on the same day, i do think the trans had something to do with that, as i was running the stock Nova Ls3 but a different pipe to the Zac. once the one way is sorted i think the package is going to be very strong indeed, im going to try the new rear hubs with the inserts in January testing so i am looking forward to the new year. 2 months of no racing is hard to come to terms with when i was just getting a good combo together.
Hope you enjoy your new G4S , and there is lots of info on setup on here. just use the 'search this thread' button above this window to find out anything you need
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 12-09-2006, 05:25 PM   #2834
gansei's Avatar
AFM
it is R&D teflon product. (RD402 Teflon SP Break Pad (for All Car) )
R&D is japanese RC option maker (iwamoto)
pls see attachment. ^^
Old 12-10-2006, 01:41 AM   #2835
NiMo's Avatar
I assume that you cut the pads yourself ?
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
