Old 11-07-2006, 08:38 PM   #2536
Holeshot's Avatar
[QUOTE=Bundy_Bear]Hi Guys
I installed a brand new Mega ZX12 into my G4S on Sunday night and finished running it in at the track tonight. This is the first time i have ran the car since i had those one way bearing failures in the 2 speed. I have installed the new KFactory hardened cam and borrowed a friends bearing from his G4 Evo. Problem i have now is no mater what i do it won't change gears... I even pulled it apart and rebuilt it again in case i was a noob. Still nothing
I borrowed friends 2 speed from his Mongoose and it works fine, so i know it is nothing else. I will have more of a play shortly, but all i have done is changed the Cam
I too had the same problem. The hardend cam is way more efficient. The car shifts early with the same spring tention. Mine was shifting right away. Like the others on this forum tightening it did the trick. Put some paint in the hole of one of the adjustment holes to make sure you can tell them apart so that you dont tighten the same one twice.That did the trick.
Holeshot is offline   Reply With Quote
Old 11-08-2006, 01:30 AM   #2537
razzor's Avatar
Thanks Holeshot ,thats a excellent tip.
Am rebuilding my car at the moment will do that.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 11-08-2006, 06:51 PM   #2538
Holeshot's Avatar
Default 2 speed adjustment
Razzor
somewhere between 8 -9 turns after you start the threads into the shoes with the new stiffer springs and hardened cam should get you real close.
Old 11-08-2006, 10:04 PM   #2539
nitro_racer23's Avatar
ok probly a stupid question but i want to put the rear hub carriers on the FLASH CHANGE TYRE SYSTEM onto my g4s but i dont want to use the flash tyres because of availability and price so can i put the ordenary hub in
1) can they be used with ordenary cups from the g4s
2) what is the part numbers i will require
3) what bearings will i need
cheers
Chris
nitro_racer23 is offline   Reply With Quote
Old 11-09-2006, 02:36 AM   #2540
Z00M's Avatar
Trader Rating: 15 (100%+)
cheers
Chris
There doesn't appear to be a part number for the hubs alone at this stage.
As Sam (G4S'er) said, the hubs can only work with the current G4(S) hardware when you have the special inserts to carry the current bearings. These are also not available yet.
I'm pretty sure Sam detailed all this in a post about a couple of days ago.
Cheers,
Mike.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 11-09-2006, 03:55 AM   #2541
Regional Moderator
daniz24's Avatar
K14123 G4 Flash-Pit Quick Change Tire System
K14123-1 G4 Flash-Pit System Insert (for stock G4 drive shaft)
K14123-2 G4 Flash-Pit Front Steering Block
K14123-3 G4 Flash-Pit Rear Hub Carrier
K14123-4 G4 Flash-Pit Rear Upper Link Set
K14123-5 G4 Flash-Pit Universal Joint (2)
K14123-6 G4 Flash-Pit Quck Change Lever & Accessories (2)
daniz24 is offline   Reply With Quote
Old 11-09-2006, 01:02 PM   #2542
G4S'er's Avatar
Thanks Daniz24. These are all on my website and prices as well. I have the Flash Pit kits in now and have all the hubs and inserts coming at the end of the month. The inserts will be ready at that time I was told. Then you can purchase the hubs and use your present axles!
SamF
G4S'er is offline   Reply With Quote
Old 11-10-2006, 04:29 AM   #2543
Bundy_Bear's Avatar
Originally Posted by Holeshot
Razzor
Holeshot / Razzor:
Turns out it did need to be screwed in more, but when i got to the point were it would change, the screws were sticking out of the bottom of the shoes. I have changed the 2 speed springs over to Evo ones that are longer in length and all is good now...
Bring on tomorrow so i can burn some
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 11-10-2006, 09:59 AM   #2544
schufflerbot's Avatar
Talking
Originally Posted by razzor
PM g4ser hes owner of raceday.Hes no1 for TM products and parts.
wow, you guys werent kidding. Sam, you ROCK! I ordered this stuff 4 days ago and its already sitting in my mailbox! If anyone needs parts for their G4, I have to say Raceday is the way to go. Fair prices, excellent personal service and outstanding shipping/processing speed. (almost too fast!)
I couldnt believe it, when i called and had a question i was expecting to have to leave a message, wait 3 days, then call back and leave another...
not with Sam... I called the number on the website and it was his cell! he answered my call and questions immediately!
Again, if you cant tell, I'm impressed and will definately be using raceday from now on.
schufflerbot is offline   Reply With Quote
Old 11-10-2006, 10:20 AM   #2545
razzor's Avatar
Thats good to that you sorted.
I know when I built my car one of the tips was to shorten the clutch screws a mm or so ,worked for me.
The G4 build tips on 3hobby was a big plus when I built my car.
Casterracing ZX1.5R
Old 11-11-2006, 12:30 AM   #2546
muppet racing's Avatar
Hi, heres a link to the build tips on 3Hobby, for anyone new to the car or this forum:
http://www.3hobby.net/modules.php?na...r=asc&start=60
If anyone has anything to add, then we should do an up to date one really !!
muppet racing is offline   Reply With Quote
Old 11-11-2006, 06:00 AM   #2547
Bundy_Bear's Avatar
It's BROKE!!!!
BB
Team Magic G4-img_1108.jpg   Team Magic G4-img_1109.jpg   Team Magic G4-img_1110.jpg
MissMooRC Racing
Old 11-11-2006, 06:04 AM   #2548
NiMo's Avatar
Congratulations on being the first
NiMo is offline   Reply With Quote
Old 11-11-2006, 06:52 AM   #2549
Bundy_Bear's Avatar
NiMo:
It was kinda my fault, i got trigger happy on the exit of the sweeper and left the track on the outside as a result. I got marshalled, but put right back in front of the leaders as they were coming through. I will have a closer look tomorrow, but i am hoping it is just the arm and shock end...
BB
MissMooRC Racing
Old 11-11-2006, 10:34 AM   #2550
jokersat's Avatar
Default wer
can any one help me with the two speed shoe! how many terns i mast tern the shoe screw (+/-) for adjustments
jokersat is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
