Old 09-24-2006, 01:19 PM   #2116
razzor's Avatar
I believe the new ED system has holes in the bell for adjusting clutch spring tension but the current UFO bells do not have these adjustment holes.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 09-24-2006, 01:47 PM   #2117
rcrevolution's Avatar
Send a message via AIM to rcrevolution
http://www2.towerhobbies.com/cgi-bi...p?&I=LXFKH4&P=7
anyone know if that will be completely compatible with my Mongoose centax clutch?
Im asume it will fit on the SG shaft, but will the spring adjusting nut fit on that and will there be and rubbing issues with the clutch weights
rcrevolution is offline   Reply With Quote
Old 09-24-2006, 03:08 PM   #2118
G4S'er's Avatar
rcrevolution - the link you show doesn't seem to work for me. I am guessing that you are looking for a new housing. I take it you don't have the UFO clutch system but the kit clutch system. I don't know what other fits however maybe Dennis could help here. I would think just to purchase a Team Magic housing and save the guessing?
SamF
G4S'er is offline   Reply With Quote
Old 09-24-2006, 03:10 PM   #2119
G4S'er's Avatar
You are right razor it does have a hole for the spring tensioner nut.
Old 09-24-2006, 06:00 PM   #2120
http://www2.towerhobbies.com/cgi-bin...?&I=LXFKH4&P=7
try that
I just wanted to know cause my LHS has those but they dont have the TM stuff.
I have a RD Mongoose btw with the K-Factory Centax Clutch (not the UFO)
Old 09-24-2006, 06:01 PM   #2121
I have managed to put the orignal back on and I was wondering, how much play do I need between the clutch bell and clutch shoe?
I have 2 washers under the bell to increase play and I still could use some more, is it natural to need more then 2 washers to increase play?
Old 09-24-2006, 06:06 PM   #2122
Motorman's Avatar
RC you need to add shims behind the clutch bell so it sits about 2 shims off the shoe. Then shim the front so it has about .015 end play. Or about the thickness of 2 shims removed when it has no end play with shims installed on the outside.
I'm not sure if that one will work or not. I know a mugen or serpent one will. Most of them are the same as a G4.
The issue with the hole in the bell for adjusting the nut is that it sits in the wrong place. with the spacing on the G$ it really would need to be further forward which would put it under the second pinion somewhat. Some clutch bells had a hole but it was kinda useless because it didn't line up
Ick
pillow ball from a RRR will work on a G4
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 09-24-2006, 06:59 PM   #2123
cool thanks I have a question about the shocks
should I lay them down like an MTX like so
http://img162.imageshack.us/img162/6...ture071hs3.jpg
or leave them stock which is one hole over and a more "standing position?
what are the benefits of each position?
also I need a quick setup tip
what should I set my rear and front camber at? and my front and rear toe?
I am running at 0 camber but I slide too much around corners, I am also running 0 toe in front and rear.
my ride height is about 4mm is that good?
I dont have setup gauges and I need to do this by eye so if you could tell me by mm I could set it up that way since I have a caliper.
thanks for the help
Old 09-24-2006, 07:42 PM   #2124
Chris West's Avatar
Send a message via MSN to Chris West
0 toe and camber is bit silly unless u are only going in a straight line
try 2 camber on the front and 3 on the rear
and try 2* toe in on the rear and 0 or 1* out on the front
that should stop sliding
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 09-24-2006, 10:06 PM   #2125
how do I adjust that camber without setup gauges?
should I just go to stock measurements which had some camber
Old 09-24-2006, 10:32 PM   #2126
Car Breaker's Avatar
thanks for the help
0 chamber is for Drift car
about the gauge, you can ask someone who has it and borrow it. However, you eventually should get one
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 09-25-2006, 03:20 AM   #2127
Thumbs up We Want You!!
Team Magic Model needs some good freelance writers to review our products.
We require the ideal candidates for the job have experience in writing for R/C magazine and understanding of R/C car products. S/he will possess a high command of English and must be a strong writer. While having a R/C background is recommended, it is not required. However, having great passion for R/C is the most important. Writers should also have experience of writing for the internet. We will review your composition.
Please submit by e-mail no more than two writing samples with curriculum vitae. If you currently have your work posted online, please provide the URL. Please also tell us what do you need for the reward whether the product or others. Thanks.
No phone calls please!
Mail to: [email protected]
Subject: Team Magic Products Review
TM Tina is offline   Reply With Quote
Old 09-25-2006, 03:25 AM   #2128
Bundy_Bear's Avatar
Car Breaker:
I would run 0 degress camber for a rubber tyre setup.... A foam setup does run a lot more negative camber.
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 09-25-2006, 03:53 AM   #2129
Send a message via MSN to ickvanovs
i just bought K14118 the adjustable ackerman angle.
what kind of improvement i can expect?
ickvanovs is offline   Reply With Quote
Old 09-25-2006, 04:28 AM   #2130
Bundy_Bear's Avatar
I have reassembled my clutch on my Mega ZX12 with the Picco collet and will now see how that goes. Does TM or anyone else have a tool for adjusting the clutch spring tenstion? I don't think my fingers can take any more attack from the pliers, i could end up loosing a finger
BB
MissMooRC Racing
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
