Old 09-23-2006, 08:58 AM   #2101
asw7576's Avatar
Originally Posted by Holeshot
As a techie who appreciates egineering. I don't even care about being the fastest driver but I love the egineering that goes into this car. Thats mainly why I bought it. As soon as I saw it I wanted it. I knew nothing of it's performance potential. I have always loved Kfactory parts. This car was made for me. I almost dont care how much the upgrades options are. I have sent Sam many emails about the kool stuff that is available for this car. I know he is sick of me by now. The quality, fit and funtion is so flawless I am constantly amazed at the stuff that keeps coming out and available. I wouls not own any other car now.........................Ron
I want to see the goodies you put on the car please.
Must be nice to see them.
Old 09-23-2006, 09:07 AM   #2102
razzor's Avatar
I am running the TM lightweight ball diff.
Id like to know what would be the pro's and cons between the 51t and the 48t diff pulley.
I am running the the following
20t brake and side pulley
26t front side pulley
1st gear 18/52
2nd 24/46
I am running 62mm front tyres with 60mm rears.
Any suggestions or comments welcome.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 09-23-2006, 11:06 AM   #2103
Send a message via MSN to ickvanovs
does the pillowball from RRR fit in G4S?
ickvanovs is offline   Reply With Quote
Old 09-23-2006, 11:26 AM   #2104
rcrevolution's Avatar
Send a message via AIM to rcrevolution
http://www2.towerhobbies.com/cgi-bin...?&I=LXFKH4&P=7
will that one fit on my car?
rcrevolution is offline   Reply With Quote
Old 09-23-2006, 11:55 AM   #2105
boner's Avatar
yes they fit.
boner is offline   Reply With Quote
Old 09-23-2006, 02:25 PM   #2106
Car Breaker's Avatar
I have the Kfactory light pilot ball, they are a bit too long for the front of G4 if you wany nerrow front end. not sure if RRR use the same one
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 09-23-2006, 05:32 PM   #2107
NiMo's Avatar
Threaded bit is longer but ball is the same size
NiMo is offline   Reply With Quote
Old 09-23-2006, 06:21 PM   #2108
Originally Posted by boner
yes they fit.
thanks
i got kawahara titanium pillowball and they are much lighter compare to stock (RRR). im gonna compare the weight of the g4s (stock) and the kawahara as soon as i get time.
Old 09-23-2006, 10:38 PM   #2109
gtrmx's Avatar
1st gear 18/52
2nd 24/46
Razzor,
If you notice the concept behind the new transmission is to reduce the number of rotations of the 2sp shaft.
The way to achieve this is to make larger pulleys and smaller diffs, thus reducing the internal gear ratio. If you use the larger 51t diff gear then you are going against that principal. What you will end up with by using the larger diff ring is a slower rotating rear axle. I do not think you really want that unless there is no traction at all in your track.
Again, the less the internals have to spin, the lower stress on the motor, as long as you compensate with the smaller pinions (16t, 17t for first and 21t or 22t for second). Otherwise the tranny would be extremely difficult to spin.
Suppose for a minute you really want to try the larger (51t) diff gear. If you do not change the brake pulley then you will need a longer belt and you would have massive underdrive at the rear. Then you would also need to slow down the front axle by reducing the size of the side pulley. I feel lazy to do the math, but maybe you would need a 19t brake pulley and a 18t side pulley. If you happen to change the brake pulley to 18t to allow the use of the original belt then that would make the underdrive at rear even worse. If you change to a 20t brake pulley then you would need an even longer rear belt.
So I would not go for the 51t diff.
I understand this from Dennis Richie's explanation on the Phenix clutchbell system. I hope I am making good use of your words, Motorman.
I totally favor the ED Transmission!! I cannot wait to put it in my car!!
Take off will be insanely fast!!
My 2 cents...
gtrmx is offline   Reply With Quote
Old 09-24-2006, 01:32 AM   #2110
razzor's Avatar
Thanks GTRMX get the dea although I am still using the std transmission setup on the g4s ,idea should still apply.
The std diff gear on ball diff is 48t and I should stick with that.
Casterracing ZX1.5R
Old 09-24-2006, 10:56 AM   #2111
royfan33's Avatar
Is it possible to adjust the clutch spring tension without removing the bell? Maybe I'm missing something, but I assumed it would be adjustable while ready to run in the car like my old Impact.
royfan33 is offline   Reply With Quote
Old 09-24-2006, 11:06 AM   #2112
razzor's Avatar
Bell needs to be removed to adjust clutch spring tension.
I need to look at the possibility of drilling a hole to adjust like the Serpent clutch.
Casterracing ZX1.5R
Old 09-24-2006, 12:19 PM   #2113
royfan33's Avatar
Thanks Razzor...I wonder if being adjustable in car is part of Serpent's patent of the Centax system. Gotta keep the lawyers happy
If you figure where to drill LMK...
Gary
Old 09-24-2006, 12:43 PM   #2114
razzor's Avatar
Will do !
Casterracing ZX1.5R
Old 09-24-2006, 12:46 PM   #2115
spenzalii's Avatar
Send a message via AIM to spenzalii
Are you sure? Just about every modern push type (centax) clutch I've seen has a hole where you can adjust the tension of the spring. It would seem to be a step back with the new tranny not to have this (although I'm not too keen on needing individual clutch bells for 2nd gear)
I could be wrong, though.
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
