Old 09-14-2006, 07:23 PM   #1996
afm
afm's Avatar
Originally Posted by royfan33
Anyone have any idea where the stock springs fit in, rate wise, with the boxed set.
tm gray 1.9mm 52.0 lb/in
tm orange 1.8mm 41.5 lb/in
tm blue 1.7mm 31.0 lb/in
tm aqua 1.6mm 26.0 lb/in
tm silver kit stock 26.0 lb/in
tm purple 1.5mm 20.0 lb/in
tm pink 1.4mm 17.0 lb/in
tm fuccia 1.3mm 13.5 lb/in
tm green 1.2mm 11.0 lb/in
AFM
afm is offline   Reply With Quote
Old 09-14-2006, 10:15 PM   #1997
royfan33's Avatar
AFM
Thanks AFM. I was off a little in my guess.
royfan33 is offline   Reply With Quote
Old 09-15-2006, 04:35 AM   #1998
Bundy_Bear's Avatar
Default More Worlds Today!
My ISP is being stupid so i can't upload them. I'll try and attach them here, but not sure if it will work very well. I also got access to the Pits today and got some great photos, but they are too large to post here
These well show the attention to detail that the QRCCCA have gone in preparation to holding these World Titles... Also what the drivers get up to when the track is wet
Hope to be able to do that soon... You'll just have to be patient
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 09-15-2006, 05:03 AM   #1999
Bundy_Bear's Avatar
Default Pics!
A wet start to Friday 15th @ Worlds
Wet track action "Alot of people got caught out on foams, some made way back to pits to throw rubbers on..."
"Alex K in action in his quarter final, great drive on semi damp track! He went onto win it, but had an issue at the start of his next one"
Inside Pit action still coming
BB
MissMooRC Racing
Old 09-15-2006, 06:15 AM   #2000
Bundy_Bear's Avatar
Default Pits!
"The Sunken Pits of the 2006 Worlds... Looks like a great place for frogs ATM"
Pic1
"What the pros get up too when waiting to go out on the track..."
Pic2
VRC Playing England Park Raceway - signage is correct, even has guy on drivers stand with the funny headset
The awsome facilities you get at the Worlds!
Pic3
MissMooRC Racing
Old 09-15-2006, 08:43 AM   #2001
Pattojnr's Avatar
Trader Rating: 19 (100%+)
great pics bundy. must be a buzz being there to at least watch. hows your G4S going ?
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-15-2006, 10:00 AM   #2002
Send a message via MSN to ickvanovs
i cant set my front droop both to 2mm
i ended up having 2mm on left and 3mm on right side
the right side always got 1 mm more droop than the left
what should i do?
ickvanovs is offline   Reply With Quote
Old 09-15-2006, 10:16 AM   #2003
afm
afm's Avatar
what should i do?
Asuming you have a G4-S, Check your manual on page 8, "03 Lower Suspension Arm"....there you'll see on step 4 those to little plastic anti-roll bar adjusters. They are used to compensate the height of each lower arm independently...also check on the perfect, no binding, aligment and lenght of each anti-roll bar blade..
I had the same problem with my G4S, and had to shave 1mm on the lenght of one blade ( make it shorter) to avoid the binding and one arm being haigher than the other one.
AFM
Old 09-16-2006, 03:12 AM   #2004
Bundy_Bear's Avatar
PattoJnr:
Thanks... i got a few more today, but am out of space on the ISP for storage now
I haven't ran the G4S since Tuesday night now, been to occupied with the Worlds. The clutch was way to snappy for me... I have pulled it apart, but because i am running a Mega ZX12 i couldn't use the kit collet. I had to use the engine one, but i have no realised it makes the flywheel sit out 1mm further then the kit one. This also puts more tension on the spring as well
I have ordered the correct collet for the picco engine to suit the UFO clutch.
BB
MissMooRC Racing
Old 09-16-2006, 03:25 AM   #2005
NiMo's Avatar
I have been using the Kyosho 3D clutch spring from my old FW05, it is the same as the new 1.8mm black spring but 1.5mm shorter in length, and is only screwed on 3 turn from when it first gets a thread bite.
NiMo is offline   Reply With Quote
Old 09-16-2006, 03:44 AM   #2006
AFM
thanks
Old 09-16-2006, 04:18 AM   #2007
Bundy_Bear's Avatar
NiMo:
Thanks for that, but i don't have any of my Kyosho stuff left
Also, i think the engine (Mega) collet is a different taper to the kit one as flywheel is now slipping on the collet
BB
MissMooRC Racing
Old 09-16-2006, 10:02 AM   #2008
what does the harder / softer clutch spring do?
Old 09-16-2006, 10:35 AM   #2009
FOCKYERDODER's Avatar
Harder clutch spring engages the clutch late. Good for bigger tracks.
Softer clutch spring engages the clutch early. Good for smaller tracks.
FOCKYERDODER is offline   Reply With Quote
Old 09-16-2006, 03:39 PM   #2010
SacWolf's Avatar
Default clutch's
any one tried Team Orion's 6 shoe clutch?
SacWolf is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
