Old 09-10-2006, 11:50 PM   #1951
Send a message via MSN to ickvanovs
Originally Posted by uniquexme
yes, indeed they are very very close. my frenz OS was hit a bit, about 0.5mm, but it wouldn't damage ur engine. so dun worry too much. but on the other hand, d other frenz using nova, hehe, its even worse, slightly deeper cuts.
im using nova
ickvanovs is offline   Reply With Quote
Old 09-10-2006, 11:50 PM   #1952
royfan33's Avatar
Default Picture
Forgot to post a pic. Still have a few things to do. I also noticed in the pict that I forgot to put the decal and the lower left front airdam. The left rear wheel nut missing is because of the missing threads. I'm no artist, and the paint design is borrowed from Proline brochure. Not perfect, but I can live with it. One of the things I need to do is cut the holes in the windshield and rear window. Anyone have a pic of yours, and what do you use to cut the hole? I never did this on my buggy. A dremel was all that I need for that.
royfan33 is offline   Reply With Quote
Old 09-10-2006, 11:51 PM   #1953
Bundy_Bear's Avatar
Originally Posted by ickvanovs
ups
btw where did u get the spring from?
Re:Spring...
hehehehe... when i had my orginial G4 Evo 18mnths ago i was having same problems with the brakes, i tried fuel tube & ended up giving up in the end.
Then it came to me... I raided a normal desktop pen for the spring and with the G4S sitting on the bench i appear to have solved it. I am yet to track test it over a full race distance... If not Kfactory have the brake set as another option.
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 09-10-2006, 11:55 PM   #1954
asw7576's Avatar
aawww
about the ballons, is that ok to cover the receiver with a ballon?
i find the distance to engine is so close, the ballon not gonna melted right?
btw did u put the receiver cover towards the fuel tank or engine?
thx
Side belt touch the upper deck ? Use belt tensioner to lower it. Don't worry if the belt feel stiff. Use waste silicone oil to oil the belt and wipe off the excess.
Receiver cover towards the fuel tank.
Ballon will not melt.
Becareful when mounting the upper deck, make sure all wires are not squeeze by upper deck.
Old 09-10-2006, 11:55 PM   #1955
Bundy_Bear's Avatar
royfan33:
I just used the lid off the spray can and traced around that. Use a det of curved hobby scissors and clean up edges with the dremel or some sandpaper.
Pic looks good man, you are better at painting then me, hence why i went with the GT Stripes... ohhhh, but that is also because i reckon the old man should put emon his MPS
BB
MissMooRC Racing
Old 09-11-2006, 12:00 AM   #1956
razzor's Avatar
With regards to the disc being close to the engine ,dont worry about it ,its ample clearance.A worthwhile upgrade is to put the Kfactory brake pads as the std brakes tend to fade during a race.
Cars are looking good there guys !!!
Also balloons on the recievers are not affected by the heat of the engine or the fuel.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 09-11-2006, 12:01 AM   #1957
silicone oil?
do you think its better to use the belt conditioner?
Old 09-11-2006, 12:09 AM   #1958
razzor's Avatar
Its ok to use tensioner ,so long as you can twist belt over it wont be too tight especially as your car is new the belt will stretch a bit.
Casterracing ZX1.5R
Old 09-11-2006, 08:48 AM   #1959
royfan33's Avatar
Thanks Bundy. I'll give that a shot. I know there's a rule on the size of the cutout, I just need to do some research.
Old 09-11-2006, 11:14 AM   #1960
last I looked it was 50 MM
Motorman2 is offline   Reply With Quote
Old 09-11-2006, 11:19 AM   #1961
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
If you guys are talking about the cooling hole the rule changed to 60mm.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 09-11-2006, 11:46 AM   #1962
NiMo's Avatar
EFRA is still 50mm (or did I miss something?)
NiMo is offline   Reply With Quote
Old 09-11-2006, 04:56 PM   #1963
Winner's Circle's Avatar
Default Front to rear drive ratio chart for the G4S
I have a Microsoft Excel worksheet that is set-up for the G4S. This worksheet allows you to see the effect of different size pulleys and different wheel diameters on the front to rear overdrive ratio.
I will gladly share this. Contact 1-866-nitoRc or email [email protected] to get the worksheet.
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 09-11-2006, 06:26 PM   #1964
wallyedmonds's Avatar
i was told this too
wallyedmonds is offline   Reply With Quote
Old 09-11-2006, 07:35 PM   #1965
G4S'er's Avatar
Nice looking car Royfan... great paint job!
When talking about the belts, a couple of drops of Serpents premium oil works great also. Makes everything very smooth. We carry that product and of course use it as well.
The front hole being changed to 60mm is my understanding also, much check and see. Remember the bigger you make that hole the less front down force you have. Something to consider.
The new shock bladders are in stock also. These are made with a softer rubber that will rebound instead of dent like the black bladders hate that when it happens. But having smooth consistent shocks is a good thing!!!
A lot of new parts by K Factory. Some are pricey, but really solid up the car! And some just look cool !!! lol
Later!
SamF
G4S'er is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
