Old 09-08-2006, 02:57 PM   #1921
NiMo's Avatar
There has been interference with those who have place the receiver low (on the removable section), but those who have done it my way appear ok.
I have glued the L shaped section to the carbon radio tray, then fixed the RX upside down to that L pate with double sided tape.
It seems to be away just a little from chassis heat and fuel spillage this way.
NiMo is offline   Reply With Quote
Old 09-08-2006, 03:53 PM   #1922
Holeshot's Avatar
Default spectrum Receiver
Originally Posted by razzor
buddy had 2 Spektrum transcievers fail on him over a period of 2 events.
Had to run his finals with 40mhz Ko Module.
Seems a few guys had problems with there Spektrums but the older DSM units not the new Pro Modules.
Just got a Pro module for my EXZES after waiting a month local distributor to get them.
I had problems with the first run units. Sent mine back and had no more problems. Unfortunately I totaled a car because of it. 56mph into a concrete curb backwards. (Failsafe applied brakes at the last second to spin the car around)I have the pro units now anyway, antenna inside shell also, no problems. Fuel go into the first run units and softened the plastic as well as making the circurty act funny. i now put silicone around everything now. Since i dont have to wory about changing crystals or rotary wheels.
Holeshot is offline   Reply With Quote
Old 09-08-2006, 04:16 PM   #1923
razzor's Avatar
I need to get a transciever for my G4s but current reciever is fitted into 2 balloons and then mounted in its location.I also drilled the radio tray earial hole a bit bigger for a piece of aerial tube to fit and super glued it in place.
Havent had any issues with it.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 09-09-2006, 02:21 AM   #1924
asw7576's Avatar
I did almost the same things.
2 ballons to cover the Rx
3mm cut the top part of radio basket so the basket seat level to chassis
rubber gasket ( pull from mugen ) to reduce vibration.
Drill larger hole for antenna passing ( carbon fibre and antenna mounting )
Heat shrink tube for covering the antenna wire at the hole section.
Old 09-09-2006, 04:25 AM   #1925
Z00M's Avatar
Trader Rating: 15 (100%+)
The spectrum receivers before the 'pro' series are easily affected by fuel and also the glue in double sided tape. You can tell if it's affected by looking at the casing and seeing fine cracks or the casing becomes soft. This will immediately cause radio problems for the spectrum.
Wrap your receiver tight in a baloon before fixing it to the cage with tape.
The pro series receivers (with the clear smokey plastic) are fuel proof.
I don't attach my receiver to the bottom of the cage, I attach it to the upright protective plate instead. Then the cage is acting as a protective barrier and not as the part holding the receiver that gets hit by kerbs and bumps.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 09-09-2006, 09:06 AM   #1926
Send a message via MSN to ickvanovs
can you post pics so i can get the idea please?
btw what kind of ballons? just normal ballons?
ickvanovs is offline   Reply With Quote
Old 09-09-2006, 09:41 AM   #1927
razzor's Avatar
Normal party balloons ,I use the smaller ones that I stretch over reciever.The larger ones work but can be a bit of a pain to secure.
Put wires through neck of balloon and on the location of the aerial wire make a pin hole and stretch it to put the aerial wire through.
Secure to top part of reciever bracket.
Casterracing ZX1.5R
Old 09-09-2006, 11:54 PM   #1928
mtveten's Avatar
Trader Rating: 27 (100%+)
my pro reciever failed after 4 track days, I pub my micro 3500 unit back in and every just fine again.
Mark
mtveten is offline   Reply With Quote
Old 09-10-2006, 01:15 AM   #1929
dnitro's Avatar
Dennis,
The 2006 European 1/10 champ car has a CF front crossbar instead of the plastic one that comes with the kit. It doesn't extend and doesn't screw to the radio plate. My question: Does this give the chassis more flexibility and does this make the chassis susceptible to getting bent during a crash?
Also check out the rear stabilizer. Are these aftermarket parts or custom made?
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
Old 09-10-2006, 02:48 AM   #1930
razzor's Avatar
That is the Kfactory front cf brace.If looking to get that piece spend your money wisely and get the new speedshot front assembly instead.
Casterracing ZX1.5R
Old 09-10-2006, 12:22 PM   #1931
asw7576's Avatar
Originally Posted by Holeshot
..... Unfortunately I totaled a car because of it. 56mph into a concrete curb backwards. ....
56mph impact ?
Did it explode ( like in a movie ) ?
Old 09-10-2006, 12:33 PM   #1932
what should i do with the side belt?
top touching the upperdeck and bottom belt sitting on the chassis
Old 09-10-2006, 01:31 PM   #1933
razzor's Avatar
where the belt is touching either sandpaper or use a flat file to shape or round the edge of upper plate and chassis.Not much else you can do but to remove the sharp edges that could damage belt.
Casterracing ZX1.5R
Old 09-10-2006, 06:10 PM   #1934
aawww
about the ballons, is that ok to cover the receiver with a ballon?
i find the distance to engine is so close, the ballon not gonna melted right?
btw did u put the receiver cover towards the fuel tank or engine?
thx
Old 09-10-2006, 06:56 PM   #1935
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
wat i did is wrap up the entire rx with ballon, then i cut a tiny hole at where those wires to be connected, then i plug in those wires, and then i wrap up the entire ballon with wire tape and dump back to the L-plate and its done. quite simply job though. so fuel shdn't be that easy to get inside the rx.
uniquexme is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
