Old 09-04-2006, 10:39 AM   #1846
royfan33's Avatar
Default Spektrum
Hey guys, can anyone tell me if a Spektrum receiver, S3000(?), will fit the G4S. I'm considering buying one for my kit.
royfan33 is offline   Reply With Quote
Old 09-04-2006, 11:06 AM   #1847
mtveten's Avatar
Trader Rating: 27 (100%+)
Yes, the spektrum will fit in the G4s but I would highly recommend you get the upgraded pro version to avoid all the potential bugs many experienced with the original system
mtveten is offline   Reply With Quote
Old 09-04-2006, 11:14 AM   #1848
razzor's Avatar
Shouldn't be a problem.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 09-04-2006, 12:16 PM   #1849
Default Team Magic G4S and RDLogics Mongoose
Guys,
I'm very interested in this car but what is the diff. between the Team Magic G4S and the RDLogics Mongoose, are they pretty much the same car, parts can be swap/ or use? Correct me if I'm wrong but did the TM G4S has the option of front one way or universal is the mongoose the same and why is it cost to much to get the TM G4S than the mongoose whats the diff between the 2.. thanks.
BeBop is offline   Reply With Quote
Old 09-04-2006, 12:33 PM   #1850
gtrmx's Avatar
There are several differences,
The new one way can be locked as you already know.
The steering system is totally new and is a great improvemente over the previous design. The new one new has a bullet-proof servo saver integrated into the bellcrank, much like those present in other cars.
The new chassis makes room for the new steering system, and so does the new radio tray. They both push the servos backward to make room for the bellcrank.
Also, the new UFO clutch is the best ever from Team Magic. It works great!!
The rear shock tower support is made out of aluminum for strength and great looks.
Those are the main differences. Some smaller ones may escape me now.
I hope it helps!
gtrmx is offline   Reply With Quote
Old 09-04-2006, 12:37 PM   #1851
gtrmx's Avatar
Suspension parts are the same, socks are the same, rear bulkheads are thicker were the hinge pins run but you can use the old ones.
The chassis incorporates a rear belt tensioner.
Shock towers are made out of thick carbon fiber plate.
Old 09-04-2006, 01:15 PM   #1852
razzor's Avatar
The G4S is the newest evolution of the Mongoose/G4 Evo.
If you own the Mongoose/G4 Evo you can upgrade the car to the latest spec by purchasing the upgrade kit.
Only hassle is the upgrade kit does not have the UFO clutch system.
If looking to buy a car ,get the G4S as it has all the extras as standard.
Kit includes the following:
G4S Alum. 7075 Chassis (w/rear belt tensionser)
G4S Carbon Radio Plate
G4S Carbon Transponder Holder
G4S 850 Receiver Battery Pack
G4S Bell Crank Steering System (w/adjustable rods)
G4S New Nylon Front Upper Stiffener Bracket
Thick Servo Arm (for Futaba/Ko/Sanwa)
G4S Receiver Mount
G4S Servo Mount
G4S Radio Plate Mount
Special 12cm Receiver Battery Pack Wire Set (w/mount)
New Small Alum. Antenna Rod Mount
K Factory Competition Belt (front/side/rear)
G4S Sticker
G4S Alum. Side Brace
G4S Instruction Manual
Casterracing ZX1.5R
Old 09-04-2006, 01:42 PM   #1853
wallyedmonds's Avatar
Originally Posted by Pattojnr
Wally: what are you overdriving ? front or rear ? and the 1mm split ? front smaller, or front bigger ?
Bundy : it might be the ball cups ? when they are new i found them pretty tight. they will loosen up. but i wouldnt get the pillow balls too tight, servo might not find center perfectly, just a thaught anyway
the front,the front smaller,and you guys say it will stay in the sweet spot longer well ill try it again and i said my friend has a g4s and hes a fast guy iv only been running these cars for 8 years or so.and i like this car not much to setup very easy.and the clutch is supper nice.
wallyedmonds is offline   Reply With Quote
Old 09-04-2006, 01:48 PM   #1854
G4S Receiver Mount
G4S Servo Mount
G4S Sticker
Do you have any options on battery like the flat pack or you are pretty much stuck with this type of battery
Also if I'm not mistaken there is a RTR version is this the same as the G4S or is there a diff. between the RTR and the Kit.
Old 09-04-2006, 02:00 PM   #1855
razzor's Avatar
You can make up bat pack with larger capacity AAA cels.
I run my club meets and ran the nationals with out any poblems.
Std pack is a 800mah 6v.
Casterracing ZX1.5R
Old 09-04-2006, 02:36 PM   #1856
royfan33's Avatar
Thanks guys....one other question regarding radio equipment. I come from 1/8th buggies, and swear by Air 358/359 servos. .10/200oz @ 6v. I see most onroad guys like the Futaba 9451(?). Is it weight or something else. I already have two 358s ready to go.
Old 09-04-2006, 03:53 PM   #1857
asw7576's Avatar
Get the smallest Spectrum receiver and use double or triple double tape to minimize vibration. My friend lost two KO receivers in 1 day as result from vibration. G4S receiver basket is very small, so get the smallest receiver. A baloon will be good to cover the receiver from fuel spills.
You can use 358/359 servos for awhile to save some bucks. If you want to go pretty, yes you can buy Futaba 9451 because it is more responsive and suitable for on road cars.
Old 09-04-2006, 05:55 PM   #1858
9451 rock they last so long its not funny
Old 09-04-2006, 09:32 PM   #1859
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
does anyone here use LSD for rear?
uniquexme is offline   Reply With Quote
Old 09-04-2006, 10:06 PM   #1860
royfan33's Avatar
Cool, I've got a M11 and Spektrum setup on the way.
Funny how the 358/359 seems to be the servo of choice for 1/8th buggies vs. the 9451 for these. I'll keep an eye out for a deal on the 9451.
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
