Old 08-31-2006, 03:36 AM   #1801
Z00M's Avatar
Trader Rating: 15 (100%+)
Originally Posted by uniquexme
guys, can anyone kind enough to share the gear ratio chart here pls? i have almost the complete set of gears and pulleys, but really dunno which one to combine to give the best max performance. thx in advance.
Dude, the one thing you don't want to do is to underdrive the front.
Use the following combinations if you want to experiment.
Stock the car has:
19 brake, 19 brake-side, 27 front-outside and 18 front-inside. This gives you 1 - 1 drive and you run same size tyres all around
Option 1:
18 Brake, 19 brake-side, 27 front-outside and 18 front-inside. This gears down the rear of the car so it's like running a smaller pinion and you get more accelleration but you are in effect overdriving the front of the car so you need to make the front tyres smaller by about 2.7mm.
Option 2:
19 Brake, 19 brake-side, 26 front-outside and 18 front-inside. This is like running the normal ratios but you are in effect overdriving the front of the car so you need to make the front tyres smaller by about 2.2mm.
Option 3:
20 Brake, 20 brake-side, 27 front-outside and 18 front-inside. This gears the whole car up but unless you are running a huge track with a monster motor I think this would be a rare combo. There would not be very much bottom end from the car.
Option 4:
18 Brake, 18 brake-side, 27 front-outside and 18 front-inside. This gears down the whole car so it's like running a smaller pinion and you get more accelleration without overdriving the front of the car so the tyres would be 1 - 1 ratio.
You can continue to experiment as much as your imagination will let you but you don't want to put a bigger gear on the front-side pulley or a smaller gear on the brake-side pulley as this will underdrive the front of the car.
Hope this helps,
Cheers,
Mike.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 08-31-2006, 03:46 AM   #1802
wallyedmonds's Avatar
the car gos faster when you underdrive the front. only when you use a oneway up front.
wallyedmonds is offline   Reply With Quote
Old 08-31-2006, 03:52 AM   #1803
Z00M's Avatar
No wally, it wouldn't. That might be your perception but it would only work if you had big tyres on the front and little tyres on the back.
XRAY XB4
Old 08-31-2006, 04:57 AM   #1804
razzor's Avatar
Thumbs up
Stock the car has:
Option 1:
Option 2:
Option 3:
Option 4:
Hope this helps,
Cheers,
Mike.
Thanks zoom ,this is what I needed to understand
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-31-2006, 06:26 AM   #1805
royfan33's Avatar
Default Thanks,
Thanks for the welcome guys....I have alot to learn about on road. Any tips are appreciated.
I tell you what though, lucky that Don bought Don's off Don otherwise he would have had to change the name!
Funny thing is the previous owner was Tony, he had bought from the original Don. Its been Don's Hobbies for 30+ years
Thanks again
Gary
royfan33 is offline   Reply With Quote
Old 08-31-2006, 02:18 PM   #1806
Send a message via AIM to munrath
Dennis,
Did you get a chance to send out the pinions?
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 09-01-2006, 02:10 AM   #1807
Z00M's Avatar
Has anyone heard from Dennis lately? I don't think he has been checking his emails.
XRAY XB4
Old 09-01-2006, 05:46 AM   #1808
critterracing's Avatar
i talk to him basically every day now. he's quite busy but i know he'll answer the emails soon he always does.
aldo
Crispy Critters Hobby Shop and Raceway
1275 BLOOMFIELD AVE Unit 31 BLDG 6
FAIRFIELD NJ 07004-2729
973 575-0375 https://www.facebook.com/
www.critterhobbies.com www.rcpix.net
critterracing is offline   Reply With Quote
Old 09-01-2006, 07:40 AM   #1809
yea guys I'm still here. Just busier than hell
Motorman2 is offline   Reply With Quote
Old 09-01-2006, 09:49 AM   #1810
G4S'er's Avatar
HE'S ALIVE!!!!
G4S'er is offline   Reply With Quote
Old 09-01-2006, 09:59 AM   #1811
YBSLOW's Avatar
Wa!
Whiner!
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 09-01-2006, 02:03 PM   #1812
Motorman's Avatar
Bite me ya primadonna.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 09-01-2006, 02:04 PM   #1813
YBSLOW's Avatar
Ha ha ha!
I prefer high maintenance..............
YBSLOW Racing
Old 09-01-2006, 07:40 PM   #1814
Z00M's Avatar
Dennis, I sent you a PM (to Motorman)
XRAY XB4
Old 09-01-2006, 08:36 PM   #1815
skengines's Avatar
Trader Rating: 226 (100%+)
Is there a way to make sure that the 9mm Pivot ball nut wont come loose? To give a better description, they are the 8 screws that screw in to the hub carrier.
I know you cannot screw it in too tight or else the sterring will bind.
Reason why I am asking, is because while I was breaking my engine in, one of the screws came loose. It was probably because I did not screw it in enough, but I was wondering if an of you guys use a glue of some type.
How much play should there be? Should the hub carrier be able to move a tad bit?
skengines is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
