Old 08-14-2006, 10:21 PM   #1666
Z00M's Avatar
Trader Rating: 15 (100%+)
Those are nice pieces of engineering. I guess the only question I have is - Why?
I guess it's because it's there.
With the Hoda version, I take it there is a spacer under those cells for the receiver. So the cells on the bottom don't touch the belt? Wouldn't this negate any advantage over standing up the servo?
Cheers,
Mike.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 08-14-2006, 10:51 PM   #1667
Regional Moderator
daniz24's Avatar
Now why is everyone prefer the throttle servo standing up? Just because the new Kyosho RRR Evo has it?
daniz24 is offline   Reply With Quote
Old 08-14-2006, 11:06 PM   #1668
Car Breaker's Avatar
It doesn't matter to me, I don't take off Servo that often
it just amaze to see people to special thing like putting a stand up servo dawn or vice versa
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 08-15-2006, 05:01 AM   #1669
Bundy_Bear's Avatar
Default G4S
Hi
I have just ordered my G4S from RaceDay hobbies and i look forward to flying the TM banner on the east coast of Australia
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 08-15-2006, 05:10 AM   #1670
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
Car breaker, Beleive it or not the receiver is already in there!... it is on the left side of the throttle servo...all I have to do is put my servo horn on and It is ready to go. Here is a closer pic the rec. is behind the orion rds sticker enclosed in a protective plastic casing.
Zoom, The reason I did this is because I really do not like the g4 spaceship like tank.... pit stops are difficult do to the ribs in the tank when the lid is opened then if it gets over flowed all the fuel is run down hill all over the electronics....this way it will run right down to the chassis and to the ground....and there are no ribs in the lid of this tank plus with this one you can see when its full....with the g4 tank there is no warning your almost full until the fuel reaches that upper deck by then it's shoot'n back out the top.
Another reason is, when the g4 has more or less fuel it reaLly affects the handling!....so by putting in a tank that keeps the fuel on an equal plain through out the entire run should help that and having the stand up servo on one side and the rec. pack directly across from that should really balance it out and again make it handle the same through out the entire tank of fuel and placing everything closer to the center should make the car a little more planted.....Well anyways I'll try it this weekend! Thanks for the compliment!
Team Magic G4-g4-protocls-001.jpg   Team Magic G4-g4-protocls-002.jpg   Team Magic G4-g4-proto-004.jpg
SCUBA STEVE is offline   Reply With Quote
Old 08-15-2006, 10:51 AM   #1671
G4S'er's Avatar
Fly that banner high and proud Bunny Bear, you are going to be one fast dude, opps sorry, one fast mate there in Australia.
Fun helping you guys out! Thanks
Need some pics also!
Sam
G4S'er is offline   Reply With Quote
Old 08-15-2006, 05:50 PM   #1672
Z00M's Avatar
Good reply Steve - At least now I know the thinking behind your mods.
Just for info though, there is only 13% of the fuel above the radio tray in the standard fuel tank, wheras now you'll be more like 22% or 23% so while it's in a slightly more compact area like you said, it's taller and heavier above the radio tray. Evenly offsetting weight from the electronics is ok, though you would need to look at the actual weight amounts on each wheel when ready to race to determine if your balance is correct. I did a couple of things to the G4S to get the balance as close to nuetral as possible so the setup can act more consistently.
Like you say, the proof is in the lap times so I wish you all the best. I don't think there is any one formula that is the best so go get em!
Cheers,
Mike.
XRAY XB4
Old 08-15-2006, 06:21 PM   #1673
Mike, Thanks! I will let you guys know how it works...... I would guess it should only be the same or better.....I Hope!!
Old 08-15-2006, 11:17 PM   #1674
asw7576's Avatar
Originally Posted by SCUBA STEVE
...... Another reason is, when the g4 has more or less fuel it reaLly affects the handling!....so by putting in a tank that keeps the fuel on an equal plain through out the entire run should help that and having the stand up servo on one side and the rec. pack directly across from that should really balance it out and again make it handle the same through out the entire tank of fuel and placing everything closer to the center should make the car a little more planted.....Well anyways I'll try it this weekend! Thanks for the compliment!
Hey... I would like to check that with the rest of G4S owners.
I'm getting the same feeling. Every refueling beyond 25 minutes mark, I feel the car is better to drive when the tank is full and become awful to drive when the tank is going empty.
Old 08-16-2006, 02:51 AM   #1675
Bundy_Bear's Avatar
Sam
Hi Sam
Thanks.. Pleasure dealing with you and look forward to it continuing in the future.
I will post pics after the build the process, just have to wait for the mailman
Thanks,
Andy
MissMooRC Racing
Old 08-16-2006, 05:00 AM   #1676
itchy b's Avatar
Originally Posted by Bundy_Bear
Hi Sam
Thanks,
Andy
those bears know how to have a good time
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 08-16-2006, 08:38 AM   #1677
g4-racing.de's Avatar
Unhappy
Hello
some Pictures from the Euro:
Darren with the german Team Magic Driver Marc Kreisig......
For me it was the last Time this year with The G4(S)
After 3 years ago i dont found a Dealer or Driver with spare Parts by the Track.
marc K dont drive Team Magic next year so i the only G4S driver on Races in West Germany.......
I was a good Time with you all
Thanks for all
Marc
KM-racing H-K1/Novarossi/AXE-Rossi Engines/Robitronic germany
g4-racing.de is offline   Reply With Quote
Old 08-16-2006, 06:10 PM   #1678
MechanicJon's Avatar
Send a message via MSN to MechanicJon
Originally Posted by Motorman
Hugo,
we want to slow the speed of the transmission and mainshaft down. if you use 18 the FDR is 2.80. if you can get to 20 the FDR is 2.40. what we are doing is slowing the mainshaft down so we have to gear the engine lower. The transmission is the heaviest rotating part of the car and it takes the most power to spin it up and down between gears which eats power. (inertia is the enemy) If we don't spin it up as high between gears its all free power that is not wasted spinning up excess rotating inertia. the difference between 2.80 and 2.40 is several thousand less rpm on the mainshaft between each acceleration and deceleration of the transmission.
However using 20's on the mainshaft with 18 as a first gear pinion will not allow you to gear low enough. (on stop and go USA type tracks, this is less of an issue on large sweeper tracks like europe has.) for 20's you really need to go 16 or 17 on first gear which you cant do on the G4s clutch bell as it is. However this can be done with a modified kyosho UFO bell and modified kyosho pinions.
Ok time top give a little more info on how this is done..............
MechanicJon is offline   Reply With Quote
Old 08-16-2006, 11:40 PM   #1679
gtrmx's Avatar
I think I have a clue on how this is done.
I tried fitting an engine with a regular Kyosho clutch into the car. The Kyosho clutchbell is too long, so both the pinions and the bell have to be shortened since they stick out too far and do not mesh with the spurs. The clutchbell also hits the second gear spur.
So the pinions have to be cut shorter, making sure the thread on the 1st pinion remains intact. Care must be taken to align pinions with corresponding spurs when cutting pinions. I would also suggest not using the one-piece engine mount since it would not allow the engine to sit as far as could be necessary.
Since I do not have a kyosho UFO clutchbell I do not know how heavily it has to be modified. So I'll have a friend machine a new one and thread it for the kyosho pinions. We'll make it out of aluminum for its lightweight.
So that is my opinion on the subject.
Wish me luck!
gtrmx is offline   Reply With Quote
Old 08-17-2006, 01:11 AM   #1680
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
wow, nice picture.
uniquexme is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
