Old 07-27-2006, 11:13 AM   #1591
NiMo's Avatar
Originally Posted by SCUBA STEVE
I would like to try something different and run the same size tires all around...I just need to figure out what I would have to do to the pulley's to acheive that.
replace the 20T side pulley with a 19T one, and run the 27T front side pulley (19/19/27).
I have found the setting I'm more comfortable with is the 19/19/26 pulleys and 1mm split, running the suggested 2mm split gives me too much understeer for my liking.
NiMo is offline   Reply With Quote
Old 07-27-2006, 11:25 AM   #1592
itchy b's Avatar
with the 19/19/26 combo, using the pulley calculater it tells me that i should use a 2.97mm or so split.
what difference will it make to the cars handling if a 3mm split is used to a 1mm split being used with the 19/19/26?
will a 1mm split put more strain on the drive belts with the 19/19/26?
cheers
joe
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 07-27-2006, 11:31 AM   #1593
mtveten's Avatar
Trader Rating: 27 (100%+)
I run a 18/19/27 pulley setup and start my tires @ a 2.5mm split. From my experience as the split decreases the car tends to loose steering in through mid corner. With the same shore tires front & back and a good setup your tire wear front to back can be close enough where the car's feel won't change during a 20 or 30min main.
Mark
mtveten is offline   Reply With Quote
Old 07-27-2006, 11:42 AM   #1594
rbboy's Avatar
Send a message via MSN to rbboy Send a message via Yahoo to rbboy
So that makes:
2004 UK IC Rubber Champion
2005 UK IC Touring Champion
2006 UK IC Touring Champion
... and still no offers to get you to the worlds?
ps. I don't miss you at the club, 'cos while your away I can win
I hope Team Magic can sponsor Darren for the 2006 Worlds... really think he will put in a show for the G4S... GO DARREN!! GO Team Magic!!!
www.xtremerchobbiesph.net
rbboy is offline   Reply With Quote
Old 07-27-2006, 12:27 PM   #1595
razzor's Avatar
Ive emailed TM and asked them.
They have replied that they are discussing it.
Wouldnt it be cool if all the guys supporting Darren could email TM and pass on the request.
Im sure they will see how popular he is for the TM brand.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 07-27-2006, 12:28 PM   #1596
asw7576's Avatar
Our local hero Teddy Syach & G4S are in Singapore now to join Singapore 2006 Invitational Challenge Race 2.
All the best Teddy !!!
Old 07-27-2006, 12:43 PM   #1597
SCUBA STEVE's Avatar
Trader Rating: 86 (99%+)
Thanks for the info guys
SCUBA STEVE is offline   Reply With Quote
Old 07-27-2006, 02:37 PM   #1598
Regional Moderator
daniz24's Avatar
Anyone can share rollout chart for G4S? Thanks
daniz24 is offline   Reply With Quote
Old 07-28-2006, 12:23 AM   #1599
asw7576's Avatar
Rollout = (tire diameter * 3.1416) / [ (spur / pinion) * internal gear ratio ]
http://www.arroyoc.com/index.cfm?fus...ear&isflash=No
Old 07-28-2006, 01:37 AM   #1600
XTREMERCHOBBIES's Avatar
Go Darren!!! hint.. hint.. Nick Ko
XTREMERCHOBBIES is offline   Reply With Quote
Old 07-30-2006, 01:47 PM   #1601
NiMo's Avatar
Got new motor and got myself back on form.
Had plenty straight line speed but a little to much punch, so may go for a 20T pinion next time out.
Running only one weight in the clutch weights is definately the way to go, no bogging and plenty of infield drivability.
Took FTD today and 2nd in the 10m final, and that was only because I lost 2nd gear after only 4 laps (was not lapped by leader).
Old 07-30-2006, 02:23 PM   #1602
Sow&Steady's Avatar
I'll agree to that!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 07-30-2006, 02:34 PM   #1603
asw7576's Avatar
Teddy Syach ( G4S ) got A2 at Singapore Invitational Challenge 2006.
Congratulations
Old 07-31-2006, 06:35 AM   #1604
RayJ's Avatar
Default G4S Gearing changes
Dennis devloped a new internal gear system for the G4S that some of us got a chance to run this past weekend at Toledo. It was a very definate improvement, and I picked up about .3 sec's per lap. I also ran the new Black clutch spring with all the weights in the flyweights, and dialed a ton of clutch in it. Dennis reworked a Kyosho UFO clutch bell and pinions. The motor just came to life, and the bottom end pulls waaay harder!! The first column of numbers is the standard drive numbers, and the second is the numbers for the improved internal drive. I also undertsand in afew months Team Magic will be offering a still lower internal drive. Some of the prototype stuff I saw was really really trick!!
Front Diff.Pulley 32 32
Inside Front Pulley 18 18
Outside Frt Pulley 27 26(option pulley)
Outside Rear Pulley 19 20
Brake Pulley 19 20
Rear Diff. Pulley 48 48
1st Speed Pinion 19 17(TM Kyosho UFO pinion)
2nd Speed Pinion 24 23(TM Kyosho UFO pinion)
1st Speed Spur 51 52
2nd Speed Spur 46 47
Fr. Tire Diameter 61 59
Rear Tire Diameter 62 62
1st Speed Final Gear Ratio 6.781 7.341
2nd Speed Final Gear Ratio 4.842 4.904
Ratio between 1st and 2nd Speed 40.05% 49.69%
Final Coeficient 2.526 2.400
Ratio between Front & Rear Tires 98.39% 98.82%
RayJ is offline   Reply With Quote
Old 07-31-2006, 10:03 AM   #1605
G4S'er's Avatar
Good Info RayJ !
Sam
G4S'er is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
