Old 07-21-2006, 03:23 AM   #1546
Originally Posted by G4S'er
That Mechanic Jon is right on top of things ! This is sam with a more appropriate name --- G4S'er!!!!!!
Good one Sam...
RC_Alan
rc_alan is offline   Reply With Quote
Old 07-21-2006, 06:38 PM   #1547
MechanicJon's Avatar
Send a message via MSN to MechanicJon
somebody got a do it!!
MechanicJon is offline   Reply With Quote
Old 07-22-2006, 08:37 PM   #1548
phantom-racing's Avatar
I just got g4 and I was wondering if any one can explain to me when you use the rear solid axle and with what front axle combination ( one-way, solid axle or diff)
is it better to use front solid axle or diff or both?
phantom-racing is offline   Reply With Quote
Old 07-22-2006, 11:22 PM   #1549
Regional Moderator
Darkseid's Avatar
On the subject of the brake disk, it really isn't that unusual for the disk to be really close to the carb. In fact, on every nitro car I have had, it was neccesary to turn the carb slightly to aviod the disk.
Reflex- check
R40-check
Mongoose-check
G4s- check
It seems that unless your engine has a really small carb, then you'll just have to turn it to avoid the disk. Its never be a problem, and often times, to get a good angle with servo rod, turning the carb is neccesary anyway, so it all seems to work out.
TLR 22...Tamiya F104...
Old 07-22-2006, 11:23 PM   #1550
Regional Moderator
Darkseid's Avatar
Hey asw7576:
Is that Team Magic's Lola body front bumper kit that you have mounted up on your car?
Old 07-23-2006, 10:06 AM   #1551
asw7576's Avatar
Originally Posted by Darkseid
Hey asw7576:
Yes.
Today was my first G4S race and she won B1 in 45 minutes race. Superb handling especially in the sweeper
Old 07-23-2006, 05:14 PM   #1552
Regional Moderator
Darkseid's Avatar
Well this was my first race day since I converted my Mongoose to G4s specs.
Fastest in all three qualifiers, A-main TQ, and 2nd in the A-main only 1.7sec down to one of best local guys is pretty good for the first race out with it.
One problem though... A problem that may have kept me from getting the win.
BRAKE FADE!!!
I'm not just talking about brake fade during a race, I'm talking about brake fade throughout the whole race day. By the end of the day, I had added 10 'clicks' of travel to my brake ATL, just to get anywhere near the braking I started the day with.
Each heat race was a little worse than the next, and by the main, I had no confidence in the braking of the car and it really messed with my prefered racing line.
I believe the culprit is probably heat causing fading during the race, and that carrying over and causing extra wear on the pads. Question is, how do I solve this? I'm considering adding some lightweight springs between the plates similar to what Kfactory uses on their ultimate brake pads to make sure that there is no unwanted brake rubbing.
But the first thing I think I want to try is this Kfactory G4 Lightweight vented brake disc. If someone has tried one of these, can you tell me if there was any improvement over the stock disc as far as fading goes.
I've also heard that carbon fiber disc are great at avoiding brake fade, so is there one of those for the G4 series?
Old 07-23-2006, 08:49 PM   #1553
Motorman's Avatar
get the 1498 brake pads. That is all you need. with those its game over on brake fade
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 07-23-2006, 10:50 PM   #1554
Regional Moderator
Darkseid's Avatar
You mean these G4 Real Racing Brake Pads
For $27+shipping(Raceday Hobbies), I would hope "thats all I need".
So no new brake disc needed, just those?...okay, I'm willing to to try it if it means no more brake fade.
Old 07-23-2006, 11:27 PM   #1555
asw7576's Avatar
BRAKE FADE!!!
Yes, use very thin springs in between the plates and slightly move forward the brake lever for more bite feeling.
Motorman : Can you ask team magic to make harder plastic for spur gears ? Another improvement is 4mm thick alluminium brace on the spur gear side to fully cover the main shaft bearing. ( make thin at bottom side so it still fit to lower chassis ).
Yesterday race, 4 winners with G4S : A2,A3, B1,B2
Old 07-23-2006, 11:59 PM   #1556
razzor's Avatar
Brake fade has been the only niggle I have really had with car ,hope to have new pads on car for the nats in 2 weeks time.
Motorman ,how is the new Axial motors going ?
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 07-24-2006, 03:42 AM   #1557
muppet racing's Avatar
Default UK Nationals
Quick update,
Just had our latest national at the ultra fast Tibshelf circuit, and although we struggled a little in qualifying (2nd & 3rd !) I managed to win the A final by a couple of laps, so out of 6 rounds, G4S has won 5 & taken 3 TQ's, this is all on very different styles of tracks.
Our next race is at the European Championships at Heemstede in Holland, so lets all hope for a good result there at sepent's home track !!
muppet racing is offline   Reply With Quote
Old 07-24-2006, 05:47 AM   #1558
XTREMERCHOBBIES's Avatar
Congratulations Darren! You make us very proud to be driving the G4S!!!
I'll put in a good word to TM and tell them to sponsor you in the coming worlds
XTREMERCHOBBIES is offline   Reply With Quote
Old 07-24-2006, 06:31 AM   #1559
Team Phenix drivers Brian Berry and Bobby Flack qualified 1 and 2 at the Midwest Series Chicago race this weekend and finished in the same respective order. Congrats to Brian and Bobby.
Brian finished 3 laps up.
ASW are you using the new black gears?
Razzor: Having some axial teething pains, the construction is great I just need to get it to run like I want it to.
Motorman2 is offline   Reply With Quote
Old 07-24-2006, 06:55 AM   #1560
Hi Motorman - Any break in and tuning suggestions for Axial .12 RR engine? Clutch settings on the UFO Clutch? We will try it out this week, any help is appreciated
Motorman 2 - What problems are you encountering with the Axial .12?
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
