Old 07-17-2006, 11:08 AM   #1531
asw7576's Avatar
Do you guys have problem with ultra close brake disc to engine ? I even use 20/25 pinion gears and it still dangerously too close.
Is there smaller diameter brake disc for G4S ?
Old 07-17-2006, 11:47 AM   #1532
NiMo's Avatar
I briefly had the RRR, and on that you had to sit the carb at an angle else it would be touching the brake disc.
Gap between motor and disc (Kfactory option) on mine is about 1mm running 18/24
NiMo is offline   Reply With Quote
Old 07-17-2006, 12:23 PM   #1533
asw7576's Avatar
Can't sleep well in the past few days hehehe .......
So here I comes
I installed her with awesome torque of KO Propo 2364 and 2366 Servos, crystal clear radio signal from Futaba PCM 1024 and finally Novarossi NSR12 with berrylium p/s/r for power and durability.
Her maiden race will be on 23rd of July with special painted Lola body like this. ( I'll post the picture later this week ).
Old 07-17-2006, 02:04 PM   #1534
Car Breaker's Avatar
nice car you have. enjoy it
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 07-17-2006, 08:40 PM   #1535
Z00M's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Pierre1
Ok thanks fo the info. I mail ordered and since i dont speak cantonese...The hobby shop here dont want to help you unless you buy the car with them.The manual has no info about the engine.
I played with the higher needle. I'm just at the treshold of the engine dying by itself. Would the lower needle have any effect? I notice glow plugs have number would getting a lower number glow plug change anything?
I guess i'll postpone the race if i dont wanna blow the engine.
Pierre, I would hope that the hobby shop would help in some way if you were to buy fuel and tyres and plugs and other things. I guess this is the risk with mail order.
I would suggest you go to the race meeting and maybe even contact the club president before hand and explain that you're new to this and maybe they can get someone to help you before racing starts to show you the basics and help set your engine. It's too hard to diagnose such a thing over the net.
Cheers,
Mike.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 07-18-2006, 01:02 AM   #1536
Piyo Piyo's Avatar
Your car problem is within the engine mounting screws. Please use the original ones from the box.
VIOLA ARIELLE & FLOREN ISABELLE
Piyo Piyo is offline   Reply With Quote
Old 07-18-2006, 03:46 AM   #1537
fix the brake disk into a drill and with a file; file down the edge while the drill rotates the disk.
or
i used a machine screw and a nut to lock the disk onto the screw, then placed the assembly into a drill. glued a piece of wet and dry to a block, fixed the block into a vice. started the drill and rubbed the disk against the wet and dry until the correct diameter was reached.
remember safty first, a good clear head visor will stop any dust/metal from hitting your face.
MisterLister is offline   Reply With Quote
Old 07-18-2006, 04:51 AM   #1538
asw7576's Avatar
Nope.... The gap will be even closer If I use original screws
STU
Old 07-18-2006, 04:56 AM   #1539
asw7576's Avatar
or
Thanks for the idea...... I go to a machinist some day during rebuild intervals ( currently the car is too cute to be dismantle ).
Old 07-18-2006, 02:55 PM   #1540
badKarma's Avatar
Send a message via AIM to badKarma Send a message via Yahoo to badKarma
anyone have a good servo advice for the G4S? What fits good and is quality?
badKarma is offline   Reply With Quote
Old 07-18-2006, 06:25 PM   #1541
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
i also noticed that my brake disc is very close to the engine, but i doubt that it will hit the engine. think we need to inform TM on it then.
as for the servo, m using Sanwa VX for throttle & VR for steering.
uniquexme is offline   Reply With Quote
Old 07-19-2006, 12:07 AM   #1542
asw7576's Avatar
Choose the best you can afford.
I'm using KO Propo 2366 & 2364 - 13kg metal gears because I'm torque junkie.
Old 07-19-2006, 12:32 AM   #1543
MechanicJon's Avatar
Send a message via MSN to MechanicJon
Ko Propo has a pretty good sale on high torgue and high speed analog servo's. http://www.shopatron.com/product/pro...605.1054.0.0.0
MechanicJon is offline   Reply With Quote
Old 07-19-2006, 07:58 AM   #1544
Regional Moderator
daniz24's Avatar
Originally Posted by Z00M
Mugen super hard spring.
Clutch nut showing 1 thread.
1 weight in the right hand side of each flyweight.
I then started off with .6 gap but I played with the gap to get the right feel. The engine is still no terror off the turns so don't expect too much.
I ran 18/23 and 52/47 gears.
Cheers,
Mike.
Thanks man, btw can you give me the updated track preparation or better such as gear ratio and tire shore suits best for the WC track in Brisbane? Or where can I search for it
daniz24 is offline   Reply With Quote
Old 07-21-2006, 12:26 AM   #1545
G4S'er's Avatar
That Mechanic Jon is right on top of things ! This is sam with a more appropriate name --- G4S'er!!!!!!
G4S'er is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
