Old 03-20-2003, 09:36 AM   #796
markp27's Avatar
Send a message via ICQ to markp27
Default Setup question
Hi Guys,
Looking in the 705 manual, I see it only mentions what the track width for the front should be.
What should the track width at the rear be?
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 03-20-2003, 10:49 AM   #797
fmolzer's Avatar
Mark, the rear track width kind of finds it self. Adjust your rear toe and camber to where you want them to be and that will take care of the track width by itself. With about 2-3 degrees of toe-in and a camber setting of around 3 degrees, the rear track width will be around 198-199 mm. If you go more agressively on the angles, it is possible to go over the 200 mm "legal" width.
Good luck.
fmolzer is offline   Reply With Quote
Old 03-20-2003, 11:34 AM   #798
Originally posted by fmolzer
lost man, can you confirm if you are using the centax clutch or the standard clutch that was included in the impulse/streetspec/pro kits?
I am using the second gen centax clutch.that came with the 705..at work now will post part # later, would've done so last night but dogs went MIA.
lost man is offline   Reply With Quote
Old 03-20-2003, 11:40 AM   #799
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
serpent stated it was impossible for them to make a 14 tooth gear to fit the cetax.. that is why they went for the drivetrain reduxtion.. would be very interessted if it was actually a 14 tooth.. post a pic too iif possible thanks.
ammdrew is offline   Reply With Quote
Old 03-20-2003, 11:51 AM   #800
markp27's Avatar
Ah yes, I see what you mean. Thanks for the info.
Mark.
Good luck.
Old 03-20-2003, 11:52 AM   #801
modellor's Avatar
I hope they have managed to make a 14t pinion. It will make life easier for us on our twistier tracks here.
You know the old saying Ammdrew, Everything is possible - you just need to find the solution.
modellor is offline   Reply With Quote
Old 03-20-2003, 12:06 PM   #802
ammdrew's Avatar
sure you could read salvins post saying it was impossible to machine a 14 tooth gear to fit on the clutch bell.. as having some expierience in machine shop operations , setup and practise, i can understand that there may be some impossabilitys about it, and that is why the old 14 was a one piece clutch bell...
i also think they would of had custom made gears three years ago... i too would be estatic if they came up with one, but i doubt the first place you are going to see it is in a hobby store in texas.......
Old 03-20-2003, 02:45 PM   #803
Im serious gentlmen ill get you that part # tonight for the pinion..listen to this,,,it might shed some light on the situation..when i bought this pinion it was only 7or9 bucks,...and to my suprise the 17tooth pinion that i bought was about SEVENTEEN bucks..thats a huge difference in price..perhaps this 14 tooth that i bought was an old part? who knows..but rest assured ill get you that part # tonight. in about 2 or 3 hours.. im suprised at yalls suprise.but it all makes sence now..i can see what your sayin amdrew...your saying the inside diamater would be too small...could i have bought an old out dated pinion....thats what it is starting to sound like...hmmmm
Old 03-20-2003, 03:08 PM   #804
ammdrew's Avatar
my guess is the part number you have is 801544 a 14 tooth gear suggested retail 8.40 and made for the clutch shoe system that came with the pro.....
there is also a 17 tooth second gear for the same system.....
Old 03-20-2003, 03:14 PM   #805
fmolzer's Avatar
That does not make sense at all. Why should a 17 tooth gear cost 17 bux and a 14 cost 8 bux? Isen't it pretty obvious that the price of the 14 tooth needs to be 14 bux? Come on guys, apply some common sense here...
Old 03-20-2003, 03:25 PM   #806
Send a message via ICQ to nizee
Well.... if he got 14T alu and 17 Steel...that make sense ya know for the price different....
i do know that steel gears are expensive compare to alu.
nizee is offline   Reply With Quote
Old 03-20-2003, 03:39 PM   #807
fmolzer's Avatar
Really, and I thought all metals cost the same. Thanks for the update.
Old 03-20-2003, 03:48 PM   #808
Trader Rating: 2 (75%+)
Also how many teeth on the pinion makes a factor!!
PUNISHER is offline   Reply With Quote
Old 03-20-2003, 03:50 PM   #809
Really, Really !!
As a starter, u might want to compare prices for part 909557 and 909577.
Old 03-20-2003, 04:05 PM   #810
fmolzer's Avatar
I called Salven and that was a misprint in the website. He agreed with me that a 17 tooth gear will always be about 17 bux. it is a misprint in the catalogue. It is supposed to be 17.51 not 11.75....
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
