Old 03-19-2003, 01:06 AM   #781
InitialD's Avatar
Default Re: clutch shoes
Originally posted by chachi
Pit-racer, any input into getting an engine? fmolzer has a pretty convincing arguement to stick with the TR......
Yes, I would agree with fmolzer to go with the OS engine. Easy to tune and idles good. OS engines tend to have better low end torque characteristics which is good for small tracks and good for cars like the Impulse and the 705 that have low drive ratios.
If you're more adventurous, you can go with a NovaMega S12 RE 3 port engine or the Novarossi S3 or even the RB X12 3 port engine. All are good engines. A little more difficult to tune but once you develop the skills to tune it, your car will fly like a rocket
Remember, engine HP is not everything. Driving skills is one thing but I place clutch setup and gearing above all else when it comes to speed. With a normal 3 port turbo engine in the old Impulse, I helped a friend of mine beat a Reflex NT with a Rody tuned engine on the straights with the correct gearing and clutch setup. Well it was an evil combination of the 13T/16T old fixed Centax clutchbell and the 17T, 22T and 47T pulleys
p/s: Damn, I wondered how long I could stay "Technically Evil" with 666 post
Old 03-19-2003, 01:08 AM   #782
InitialD's Avatar
Originally posted by modellor
Well guys,
reassure me that I have made the right choice in joining the Snake Pit .
Its been 10 yrs since I last raced a snake and 15yrs since I last owned one.
modellor, welcome to the pits... Hope the pit would benefit from your vast experiences.
Woow, did it take very long for the 705 kit to arrive at your door step? I thought the last you mentioned that you will be receiving your kit was like in January this year...
Old 03-19-2003, 01:10 AM   #783
markp27's Avatar
Send a message via ICQ to markp27
I installed all the clutch elements exactly as shown in the manual and it works for me.
I don't understand your explination?
markp27 is offline   Reply With Quote
Old 03-19-2003, 01:13 AM   #784
InitialD's Avatar
Default Re: Sirio
Originally posted by DSR
InitialD,
Are you saying that the Sirio 12's won't fit the 705? I hope this is not the case because that is the engine I just bought.
Has anyone seen the Sirio 12 on the 705?
I'm not saying that you would have problems. I have not seen a Sirio in a Impulse / 705 yet. But on the .21 Sirio engines on the 950, they have aligning issues with the 2 speed spurs and the pinions.
Anyway like what fmolzer mentioned, you would need to figure out the shimming as it is different from the Nova varients.
Old 03-19-2003, 06:09 AM   #785
modellor's Avatar
Yeah, our Serpent dealer ordered 30 cars last year and is only getting the last of the order now. He was told January but when he visited the factory 3weeks ago they didnt even have a full kit available.
It still hasnt reached my door yet. My team mate has it at his house so I should get it tonight or tomorrow. Hope to run it on Sunday.
modellor is offline   Reply With Quote
Old 03-19-2003, 09:53 AM   #786
Hey fellas i just bought a 1st gear 14tooth pinion..do i need to change my stock spur gear to run it.?
lost man is offline   Reply With Quote
Old 03-19-2003, 10:28 AM   #787
Pit-racer's Avatar
Chachi,yes stick w/ what you have and learn the car b4 you invest in a new engine. Finishing a race is more inportant than going fast and not!
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 03-19-2003, 10:28 AM   #788
fmolzer's Avatar
It depends, what clutch are you using? A normal spread on the gears is about 3 teeth on the spur i.e. 49/46. You can deviate a little bit but the price is less than perfect gear mesh. what other gears do you run except the 14 tooth?
fmolzer is offline   Reply With Quote
Old 03-19-2003, 10:41 AM   #789
Where did you find a 14t pinion that fits the cantax bell? The only one that Serpent lists is the 15t that I just bought along with the 50t spur.
ronin8451 is offline   Reply With Quote
Old 03-19-2003, 10:47 AM   #790
fmolzer's Avatar
I think there is a picco centax type clutch that you can use that has a 14 tooth 1:st gear on it. I have seen that on a couple of cars, but I am not aware of a 14 tooth tath will work with the new centax II system.
Old 03-19-2003, 02:42 PM   #791
Im running the stock gears..i bought the 14 tooth in sanantonio last week, it is a valid serpent part, made from the same material.(aluminum) ,,i am running a centax clutch..and the 14 tooth pinion does in fact screw onto the clutch.
Old 03-19-2003, 02:48 PM   #792
Please post the part number so the rest of us can get one too!
Old 03-19-2003, 04:19 PM   #793
ill post the part# later tonight. I also purchased a 17 tooth second gear pinion as well to go with the 14 tooth to answer your question fmolzer
Old 03-19-2003, 06:01 PM   #794
Trader Rating: 2 (75%+)
I believe lost man is useing the old 2speed clutch bell 14t pinion.....the lil'l black ones.
correct me if worng bro.....
PUNISHER is offline   Reply With Quote
Old 03-20-2003, 09:17 AM   #795
fmolzer's Avatar
lost man, can you confirm if you are using the centax clutch or the standard clutch that was included in the impulse/streetspec/pro kits?
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
