Old 03-10-2003, 02:01 PM   #616
Trader Rating: 2 (75%+)
JJ187RC,
The measurement in the instructions is too hard. It has 9.2mm when it should be 8.8 to 8.2mm.
Iím running a modify clutch shoe in my clutch that gives you a snapper response and less fade. I cut the yellow clutch shoe to replace the black shoe. The black shoes have the holes for the pins on the side of the shoe. That doesnít make those shoes ďthrow outĒ properly. It makes them swing out not throw out to the clutch bell. With the yellow shoes I made the holes for the pin in the middle of the shoe. That allows the shoe to throw out faster and more efficiency. Also Iím using the red shoe for the engaging shoe for less fade when engage. Itís a better matrial then the stock yellow shoe.
Iíll post a picture of the shoes tonight when I get home.
InitialD can you post the write up form MYTSN on modify clutch shoes?
DSR,
The snap ring goes inside the diff (#801432 axle long) to hold in the trust bearing. Yes, put a light coat of grease on the trust bearing and don't for get on the balls on the steel washers!!
PUNISHER is offline   Reply With Quote
Old 03-10-2003, 02:20 PM   #617
JJ187RC's Avatar
Thanks. I have been trying to get some more bottom end out of my car and I figured it was in the clutch setup is where it was missing. A picture would be great, I might have to try and have one modified for myself by the race the weekend. Are you coming up to Dallas this weekend?
JJ187RC is offline   Reply With Quote
Old 03-10-2003, 02:26 PM   #618
DSR
Thanks again Punisher. I now have a clear grasp on what to do.
DSR is offline   Reply With Quote
Old 03-10-2003, 02:43 PM   #619
Pit-racer's Avatar
Punisher! Give credit to the F-Man and not yourself! You don't have a clue until I explained it to you!
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 03-10-2003, 03:04 PM   #620
JJ187RC's Avatar
As long as it works I am happy, I just need more punch out of the corners.
Old 03-10-2003, 04:23 PM   #621
Cool
SSSHHHHHHHH.....I want them to think i'm a GENIUS!!!
JJ187RC , you can also try a 15t pinion......
See ya in Dallas!
Old 03-10-2003, 04:37 PM   #622
Pit-racer's Avatar
See you all in Dallas! Come on over to Pits' pit and intro yourself and for a cold one! If you're of age.
Old 03-10-2003, 04:58 PM   #623
Post CLUTCH SHOE MOD
Pic #1 shows the stock black shoe with the holes on the side of the shoe.
Old 03-10-2003, 04:58 PM   #624
JJ187RC's Avatar
I will be there for sure. Luckily I am only about 15 minutes from the track.
Old 03-10-2003, 05:04 PM   #625
Default oops...
lets try this again......
Pic # 1 modify yellow shoe
BTW- that is the Titanium 2speed shaft!!!
Old 03-10-2003, 08:41 PM   #626
Neil Rabara's Avatar
Speaking of the clutch, how do you adjust the clutch to not be so snappy out of the corners? Difficult to drive on low traction tracks.
Neil Rabara is offline   Reply With Quote
Old 03-10-2003, 08:56 PM   #627
apmk's Avatar
Unhappy please help
I know this is really out of way, but i've been following this tread and got some reply from you guys out there, Thank very much.
But the problem is i'm not able to read my reply , and not even able to edity my profiles.
Can you ppl give some advise pls
apmk is offline   Reply With Quote
Old 03-10-2003, 10:17 PM   #628
Pit-racer's Avatar
Have you tried loosening the rear diff a bit?
Old 03-10-2003, 10:47 PM   #629
bt
Default thanks
thanks to those who answered my questions on the pulleys and once again to initialD for the answers on the pulleys and centax questions
bt
bt is offline   Reply With Quote
Old 03-11-2003, 03:10 AM   #630
InitialD's Avatar
Yes, loosening the rear diff helps. You can also use a one size larger pinion for the 1st gear or smaller 1st gear spur to smoothen out the accelleration. Reducing 1st gear spur has a more refined effect unlike changing to larger pinions.
Smaller gap between the clutch bell and clutch shoe (stock is 0.7 mm) also helps to soften the punch. A looser spring tension also helps to ease out the punch (i.e. reduce the stock distance from 9.2 mm to something lower).
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
