Old 03-06-2003, 09:41 PM   #556
tennessee's Avatar
Rumor has it that serpent will unveil a new car for the summer of 2003 that will be 100% different from the 705.............
Did'nt they just release the 705 3 or 4 months ago..........
Makes you wonder what the heck they're doing over there..........
tennessee is offline   Reply With Quote
Old 03-06-2003, 10:04 PM   #557
modellor's Avatar
I was talking with a guy from the factory tonight and he never mentioned any new car.
modellor is offline   Reply With Quote
Old 03-06-2003, 10:31 PM   #558
paulfitipauldi's Avatar
Originally posted by ammdrew
tell you what i ran the old centax with the old drivetrain ratios and won or ran in the top ten for three years now, you do not have to have the new 17, 22/47 gears to compete, in fact the car is much easier to drive with the higher ratio, the lower is great on a tight very high traction track, if the track is loose you are better off finding the punch in the clutch, and be able to roll the throttle, the tc3 was always able to go to a lower ratio, that is why it alwasy looks so darn fast...... in heavy comp i have seen little if any diff in most of these cars.. the lower ratio on some pkg lot tracks would be better, but not all, it is just a option, and if it the reason you are not winning, you are really damn good, and need not be asking here or you have other areas that will give you more improvement........ just trying to help you help yourselves and not waste valuable thought and effort over one simple little thing.....
That's why i worried about that 17 t pulley, because all the tracks here in Puerto Rico are parking lots and they are very tight tracks, we run a championship here in 4 tracks ,, only one have a 250' of straight way , so I need that combination for the other tree tracks ,, plus that my 705 like I told you before is from the second generation and he came with the 47t and the 23t brake pulley, so i need to solve this as fast as i can because the next event is this sunday!!
So if this 17t pulley is not big deal for you , why every one who runs in the winternats is using this pulley,, i saw the track in a video and this track is bigger enough to run with the stock combination, look at the MY TSN set up sheets for that tracks of all the runners in there and you'll see
paulfitipauldi is offline   Reply With Quote
Old 03-06-2003, 10:34 PM   #559
Cool
Remenber is just a rumor, maybe he forgot to tell you about it, hehe!! why don't you ask it for the next time?
ciao!!
Old 03-06-2003, 10:45 PM   #560
modellor's Avatar
Nope. This guy contacted me to talk business. So he didnt forget to mention anything.
Old 03-07-2003, 12:13 AM   #561
InitialD's Avatar
Andrew you are right about the gear ratios and the type of tracks that it benefits from. Just wanted to get the best out of the engine. I find that when run on tight tracks, the Impulse / 705 is often overgeared. In the in fields of tight tracks, the car can bog down and overheat because the car is geared too high and not correctly. By the time 2nd gear is engaged, you are already somewhere at the end of the straight and you already need to slow down.
I find that the best way to use the powerband of the engine fully is to play with the gearing. The lowest gearing is unfortunately the 15T / 18T and even that I find that it is still too high for medium sized tracks.
Agreed that you can play around with the Centax clutch spring but the wear and tear of the clutch shoes and thrust bearing will be more severe.
All other cars (V1R, NTC3, Mugen) have internal ratio of 2.5 thereabouts. I believe the GT4 has also an internal drive ratio of 2. It makes it easy for car with low internal drive ratio to gear down and get very good acceleration out of the corner and in the in fields on small tight tracks. The Mugen and V1R cars (with the exception of the NTC3) have problems when it comes to very long tracks but that can be overcomed with large pinions and smaller spurs. I believe no one sees the day to have the chance to use a 20T pinion on the Impulse / 705...
Old 03-07-2003, 12:23 AM   #562
InitialD's Avatar
You are right about this Paul. I believe even Andrew used the 17T 22T/47T conversion himself.
Old 03-07-2003, 01:59 AM   #563
InitialD
I'll probably get to used the 20t pinion this weekend. Ran a 19t pinion last year. Track straight I heard is going to be about 240 feet. Goling over to Maui for their on-road champs this weekend.
RoyU is offline   Reply With Quote
Old 03-07-2003, 02:25 AM   #564
InitialD's Avatar
Originally posted by RoyU
InitialD
Wooow, lucky you It actually depends on what type of engine you use. If you have a high revving engine, you might want the 19T instead. Good luck at the races
Old 03-07-2003, 02:41 AM   #565
InitialD
May use the RTU. Haven't used it for awhile after I found out Ritchey stopped his engine sales. I got a used RTO, but the piston and sleeve is worn out. I think the previous owner ran it too lean. It was fast when he had it. I wonder if Ritchey sells piston and sleeve for the RTO?
Old 03-07-2003, 07:46 AM   #566
Roy, just send the piston and sleeve to OSROCKET (John Bohland) and have it squeezed. I have done this to going on 20 engines (I have 15 cars and many back-up engines fo on-road and off) and they all work flawless and the extra is that for the first 2 gallons you have much more bottom to mid punch with the original top end!
ronin8451 is offline   Reply With Quote
Old 03-07-2003, 08:17 AM   #567
Trader Rating: 2 (75%+)
Default Re: Re: 17T SIDE PULLEY
Originally posted by InitialD
PUNISHER, where did you get the 801256 part number? It' snot anywhere in Serpent's parts list. In fact there is no 17T pulley anywhere in Serpent's part's list except for the new 17T that just came out (801252).
#801256 17T Pulley/flange is a part that I found in a new Parts List that I have. It maybe a typo on the part number.
Thanks for clearing up the confusion......
PUNISHER is offline   Reply With Quote
Old 03-07-2003, 10:09 AM   #568
You got an address, phone # for OSROCKET?
Old 03-07-2003, 11:58 AM   #569
Thumbs down
Sniff* Sniff*
I think we have a trouble maker here in the Snake Pit!!
Old 03-07-2003, 02:32 PM   #570
J_Longbrake's Avatar
Trader Rating: 20 (100%+)
RoyU, you can get a hold of John at [email protected]
J_Longbrake is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
