Old 02-26-2003, 09:04 PM   #466
InitialD's Avatar
Originally posted by ammdrew
705 has better reciever location.
easier to take the motor in and out of quickly
like the easy tank removal
battery placement... take it or leave it
if you plant the car in the wall, dead on hard it will bend just behind the front bumper before the front bearing blocks, break the radio tray, exact same on both pro and 705
705 stays stiffer in your hands( ie less flex in the motor area due to the new stiffiners, but this make no real world advantage as it takes a ton of force to flex a pro( and i never use any aluminum x braces or stuff like that, just the stiffiners)
Very complete observation and comparison One of the things I noted were that in the 705, they are now using Veteq springs like what Ralph did to his Impulse PRO at the Nats last year The rear springs are a little longer and I feel that they perform better than the old ones.
Old 02-27-2003, 10:54 AM   #467
Ammdrew
Thanks for the info. As for other 705s beating me, I'm the only with a Serpent here. We've a couple MTX3s, lots of NTC3s, a few VoneRRs, a couple of RS4s and 3s
As for my Impulse its the Streetspec had converted to Pro. But now, I took off the shock towers and put back on the Top radio tray. To me it handles better.
Is the 705 lighter than the Pro?
RoyU is offline   Reply With Quote
Old 02-27-2003, 09:12 PM   #468
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
I ran my pro drivetrain in the 705 as i felt it was lighter and free,( very well massaged and broken in) as far as drive train they are identical, i was still using pins on all the pulleys until worlds when i switched to the hollow front shaft, which made no real diff in cinn, just made me feel better, and i ran the pin brake and side pulleys even on the hollow rear shaft untill winternats, i almost never seek lightweight and or special parts, they are usually a waste of money to the average guy, until maybe the last big race or two did i become comfortable on the stand and start to race like i was on a local track, and have a bunch of fun..
oh the springs in the box were identical, in the one i got two weeks ago???
the main diff in the cars is the chassie bracing, tank and battery placement...
her is me in ft myers
ammdrew is offline   Reply With Quote
Old 02-27-2003, 09:16 PM   #469
ammdrew's Avatar
here is a pic of the track by the driverstand, looknig through pit row, this track was a lot of fun to drive if you did it right if you were wrong, well not as much fun, i can say it is probably one of the best tracks i have enjoye drivig, my favorite part of the track was the carousel, i could pass three or four cars in trafiic on the inside line... a foot off the entrance and you could lose 8 feet in the corner.... it was a blast to
Old 02-27-2003, 09:50 PM   #470
Ducati998's Avatar
Would there be any probelm using Jr. servos on the 705 or maybe fitting problem with servo savers? Thanx!
Ducati998 is offline   Reply With Quote
Old 02-27-2003, 11:56 PM   #471
InitialD's Avatar
Nice pics Andrew. Glad to know you enjoyed racing there...
Anyway, for me, I know it made a difference in the belts and they way the car rolled when I changed to the new 705 pulleys in my PRO. The front belt last longer and the car rolls smoother. The new styled pullys eliminate play usually associated with pin styled mounts. Even the MTX-3 changed to the same style grub screw aluminum adapter pulley mountings... There must be something good here...
And as for the springs, look carefully. The part number given for the 705 yellow spring is 901415. This is a VETEQ spring as with other options of the white, red and blue springs. The yellow spring found in the PRO is 909415.
Old 02-28-2003, 12:03 AM   #472
InitialD's Avatar
I believe in terms of static mass, the 705 is slightly lighter with all the carbon side stiffeners compared to the PRO with aluminum side stiffeners etc.
Rotating mass is much reduced on the 705 due to the new 2 speed gearbox. That is the most important thing to look for.
Whatever it is, keep the Serpent flame burning in Hawaii, Roy
Old 02-28-2003, 07:19 AM   #473
ammdrew's Avatar
no i agree the grub screw stuff is much better. but not faster, the lighter two speed is a plus, rotating mass is were you want to remove it.. both my pro and the 705 weighed in about the same, just about illegal.. hmm i will look closer, never ran the ones that came with it..
Old 02-28-2003, 08:24 AM   #474
Trader Rating: 2 (75%+)
Cool WIEGHT
I just weighed my 705 the other day and it came in at 3lb 12oz.
PUNISHER is offline   Reply With Quote
Old 02-28-2003, 08:34 AM   #475
ammdrew's Avatar
minimum weight is 60 oz in roar, sounds like you are there if i calculated correctly...
Old 02-28-2003, 09:38 AM   #476
Thumbs up
YUP YUP.....
I have the light weight alum. screws set and hollow shaft on my 705.
Old 02-28-2003, 10:32 AM   #477
Pit-racer's Avatar
I have all alum. pulleys,lightweight screws,adj. rear swaybar,purple washers but no scale to weigh it! Working on a engine and pipe soon....was thinking about the sts rs3 and pipe.
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 02-28-2003, 10:42 AM   #478
ammdrew's Avatar
punisher email me, i think you may race with someone i would like to get in contact with..
[email protected]
Old 02-28-2003, 11:41 AM   #479
Arrow
You have mail Ammdrew.....
Pit,
I think your car won't be far off of mine. Nizam's car was only 1oz. heaver then mine. It might be that Adj. rear sway bar!!
Old 02-28-2003, 05:29 PM   #480
paulfitipauldi's Avatar
Talking Just one question??
Hi guys,,
I'm new in this forum, and i have a little question, if some one can help i apreciate,,
i use to run an impulse street spec, but recently I get my new 705, when i said recently i'm speaking about a week ago so my car is from the second generation, well every body is speaking about the rear pulleys, i little confuse here, my car came with a 47t balldiff. and 23t ,, so the belt get very thight, i built my car gessing that serpent have already correct this mistake, but .. well any ways i replace the 23t with a 22t,
Do i have to change the 18t side belt pulley too?? of course i don't have the 17t pulley, but i have a 19t for this side and a 22t for the layshaft side belt, what you guys recomend for this,, any help or coment will be apreciate it!! thanks in advance!!
ciao!!
paulfitipauldi is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
