Old 05-22-2004, 10:07 AM   #4216
That is the article I used to build it the first time. It is a good article, I just cannot figure out where I went wrong. It is a B!#$% to take out of the car and rebuild but I guess that is what I will have to do.
bigknot is offline   Reply With Quote
Old 05-22-2004, 10:09 AM   #4217
markp27's Avatar
Send a message via ICQ to markp27
Sounds that way - have you considered using the new adjustable diff? I bought the conversion parts and it works really great it's lighter and not so tedious to build.
markp27 is offline   Reply With Quote
Old 05-23-2004, 08:58 PM   #4218
You mean I can buy the diff for the 710 and make it fit the Impulse??? How much work is involved?
Old 05-23-2004, 09:44 PM   #4219
InitialD's Avatar
The 710 rear diff does NOT fit the Impulse PRO / 705. However, the diff adjustable collar to adjust diff tension is the same for the 705 rear ball diff and the 710 front and rear ball diff.
Old 05-23-2004, 09:51 PM   #4220
InitialD's Avatar
The second "new" car doe not do this, when I spin the right rear tire it just spins itself inside the FPS, the FPS does not spin. What am I doing wrong and how do I fix this?
If what I understood is correct, the FPS that you built yourself seems a little too loose ! Assuming you followed Julius' article to the T, then you need to tighten the rear diff collar a little.
Loosen the 1.5 mm grub screw on the external part of the FPS diff. With the 1.5 mm allen still in the screw, turn the rear left wheel FORWARD while making sure the 1.5 mm allen is still in the screw and stay put. This action will screw the collar in to tighten the rear diff friction. Then tighten the 1.5 mm grub screw again to lock the setting. Try it out and see if you get the friction you require.
Old 05-26-2004, 06:34 PM   #4221
Hey thanks, it turns out the little grub screw on the right side, inside the ball cup was not screwed in at all - am I supposed to screw this one down tight?
Old 05-26-2004, 06:39 PM   #4222
Sow&Steady's Avatar
bigknot ... just so you don't misunderstand ... there are TWO kinds of "ball" diffs for the Impulse/705.
1- FPS diff
2- Ball diff
(of course, there's the planetry gear diff too )
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-26-2004, 06:39 PM   #4223
Sow&Steady's Avatar
1- FPS diff
2- Ball diff (the adjuster collar fits this one)
Old 05-26-2004, 09:24 PM   #4224
InitialD's Avatar
Yes. That should be tightened as per the assembly instruction. But I seriously do not know if that will help your problem you first mentioned. Has that been solved yet?
Old 05-27-2004, 11:16 AM   #4225
Rapid Roy's Avatar
I've got a big problem with my 705. It just sits there and won't move at all. No power. The engine doesn't even make a sound.
Man, just can't get any time to go race. I can only pop in here and get jealous reading about all of you racing.
Rapid Roy is offline   Reply With Quote
Old 05-27-2004, 11:22 AM   #4226
Sow&Steady's Avatar
Roy, send it over to me, I'll make it move and the engine making noises at the same time
I'm in the same boat actually, been trying to service both my 705 and the 710 but not enough solid time. Just few minutes here and there being busy with the website
Old 05-28-2004, 06:42 AM   #4227
Sow and Inital D, in the article it mentions that that particular grub screw should be springy correct? Not tightened down all the way?
Sow - I have the FPS for the Impulse not the 705 unless they are the same.....
I have the Texas Biggie this weekend, I know I will come in dead last but there is an award for that!
Old 05-28-2004, 11:51 AM   #4228
Regional Moderator
kumpol's Avatar
Farewell to my old faithful 705......I will race it for the last time this weekend.....and then put it on my display (next to the Impulse)......
NEXT WEEK.......710 will be out instead.....
kumpol is offline   Reply With Quote
Old 05-29-2004, 03:02 AM   #4229
InitialD's Avatar
Hey, make that car into outlaw class with Lola shell. KevinS, markp27 and myself are doing it.
Cool. See you on the other side and good luck with the race and kick some ass !
Old 05-29-2004, 03:04 AM   #4230
InitialD's Avatar
If you're referring to the one inside the FPS diff, it is suppose to lock the diff initial setting so that the screw on the other side does not loosen out.
If you're referring to the grub screw on the external part of the FPS diff where it locks the diff collar, yes, don't tighten it too hard. Else you'll strip it.
With the Impulse, you need Impact dogbones with the FPS diff. With the 705, the dogbones can already be used with the FPS. The FPS diff is the same on the 705, Impulse and the Impact / 835.
Hey, I admire your attitude. Good for you. Not many people see the way you see things. Hats to you. Racing is not all about winning. Go and give the other guys a run for their money.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
