Old 05-09-2004, 10:41 AM   #4201
markp27's Avatar
Send a message via ICQ to markp27
Originally posted by KevinS
Once, with the 705 about a year ago. First comes start finish, then 2 ~90 degree turns left which I believe the top dogs do at WOT only to reach 100+ at the long straight in the back. That straight has a slight bend to the left near the hairpin, which makes it harder to position your car for the hairpin. You will know it's scary when you get there.
Ehm, I think I can feel a cold coming on and I won't be able to make it
markp27 is offline   Reply With Quote
Old 05-09-2004, 03:57 PM   #4202
Is there a scientifoc method to setting up the throttle linkages? I cannot seem to get mine setup properly and the manual's instructions are not ver good. Desperate for help.
bigknot is offline   Reply With Quote
Old 05-09-2004, 11:53 PM   #4203
markp27's Avatar
Yep Try Glenn Cauley's article on the subject:
http://www.mytsn.com/publ/publ.asp?pid=9742&ccid=9
Glenn has loads of great articles, you will find a lot of them useful
http://www.mytsn.com/publ/publlist.asp?cid=869&ccid=9
Cheers, Mark.
Old 05-10-2004, 06:16 AM   #4204
Thanks for the links mate!
Cheers - David
Old 05-10-2004, 07:21 AM   #4205
markp27's Avatar
Cheers - David
No probs, matey!
Old 05-19-2004, 10:44 PM   #4206
Trader Rating: 16 (100%+)
OK...not really the Serpent 705 question but I can't seem to find the Serpent Impulse PRO thread, so the next best thing is the 705...
I am going to activate my beloved Impulse PRO...however, seeing my S710 and my NTC3, I realized that the engine mount of the Impulse are like 6 feet from the ground....and I don't have the tools to cut the engine mount nice and flat...
My question is....is there any other brand like HPI R40, Yokomo or Mugen engine mount that is lower then the stock Impulse one and still fit the Serpent Chasiss...?
Thanks....
P.S....just realized this too.....does 705 enigne mount fit the Impulse PRO chassis...? If that is a fit, that is much better suite then other mfr...
Old 05-20-2004, 12:52 AM   #4207
InitialD's Avatar
The 705 mounts will match nicely on the 710. 710 is just lower by 1 mm. But neither will fit on the Impulse PRO...
If you get to lower the Impulse PRO mounts, remember to change the flywheel also.
Old 05-20-2004, 08:33 AM   #4208
ah....darn, too bad............but thanks for the tip about the flywheel....I have a 4mm chassis, so the centax flywheel is not really a problem if I am only lowered by like 4-6mm only
So does any one know where I can buy a lowered engine mount without cutting the stock one? Thanks.
Old 05-20-2004, 10:30 AM   #4209
Sow&Steady's Avatar
Originally posted by markp27
No probs, matey!
How was the race? Did you use the 705 or 710?
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-20-2004, 10:33 AM   #4210
Sow&Steady's Avatar
When I was driving the Impulse Pro, I went to friend and he machined the engine mounts for me. It was cheap
I don't think you can buy lowered engine mounts.
Old 05-20-2004, 10:34 AM   #4211
markp27's Avatar
How do matey! Had a great day, but it's been spoilt by an old Girlfriend turning up
I give a fuller run down when I don't feel so mad.
Three races: first race 2nd second race 1st third race 2nd
I was beaten by a 710 driver - the Mugen boys where 6 laps down on us. The race was summed over the best two races from the three - the 710 guy beat me by 1.35 seconds
A good day until I got home!
Old 05-20-2004, 10:40 AM   #4212
InitialD's Avatar
Hey, congrats ! Long live the 705 !
Ummm, wait till you have a wifey !
Old 05-20-2004, 10:43 AM   #4213
markp27's Avatar
Thanks, matey the 705 rules - well, except for the 710 that is
Wifey! no flipping way, me old mate - women are tooooooo much trouble
I have a couple of girls who are very good friends but wifey........nope!
Old 05-22-2004, 09:38 AM   #4214
Is anyone familiar with FPS diff? I have one Impulse Pro that is set up perfectly - only I did not build it. My second Impulse Pro which I did build "feels" different in the rear diff. When I spin the right rear wheel of the "good" car the the diff spins both tires and the FPS diff and it turns the gearbox. The second "new" car doe not do this, when I spin the right rear tire it just spins itself inside the FPS, the FPS does not spin. What am I doing wrong and how do I fix this?
Much obliged for any info or help.
Old 05-22-2004, 09:49 AM   #4215
markp27's Avatar
Hi BigKnot,
Take a look at Julius' article about building the FPS diff - maybe you can see from the description where you went wrong.
http://www.mytsn.com/publ/publ.asp?pid=1187
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
