Old 04-19-2004, 09:23 AM   #4171
Regional Moderator
kumpol's Avatar
Wheew....
I drove my old faithful 705 with Murnan Modified X12 and won in b-main....bumped up to a-main and finished 5th (five 710s and one 705 in a-main) at TC Spring Challenge in Atlanta......
www.tfbraceway.com
kumpol is offline   Reply With Quote
Old 04-19-2004, 09:28 AM   #4172
BaxterC's Avatar
Originally posted by kumpol
Wheew....
I drove my old faithful 705 and won in b-main....bumped up to a-main and finished 5th (five 710s and one 705 in a-main) at TC Spring Challenge in Atlanta......
www.tfbraceway.com
That just goes to show... SERPENT ROCKS... not to take anything from your driving... Well done. but if you had lets say an R40... you would not have done so welll....
BaxterC is offline   Reply With Quote
Old 04-19-2004, 08:03 PM   #4173
InitialD's Avatar
Wheew....
www.tfbraceway.com
kumpol, you're da man !
Old 04-25-2004, 06:38 PM   #4174
Does anyone know where I can find or want to sel the purple aluminum brake-lever that goes on the optional aluminum brake braket? "Brake plate alu purple with ballbearing" I do not want to use the plastic brake lever I know some one made aluminum ones.
Do you know where I can find one or buy one off of someone?
bigknot is offline   Reply With Quote
Old 04-25-2004, 09:09 PM   #4175
InitialD's Avatar
Sorry, but I have not seen any coming from 3rd party option houses that is specifically for the 705... Perhaps you could get one from the other car and mod it yourself.
Old 05-06-2004, 07:58 AM   #4176
KevinS's Avatar
Default S-705 New life
After I got the S-710 I decided not to sell my 705. Over the winter I took it apart, cleaned and inspected every part and replaced a lot of em to create an outlaw monster. Now it's finally done and I have pics
With the body on:
KevinS is offline   Reply With Quote
Old 05-06-2004, 07:58 AM   #4177
KevinS's Avatar
The rear end:
Old 05-06-2004, 08:00 AM   #4178
KevinS's Avatar
Topless:
Old 05-06-2004, 08:02 AM   #4179
KevinS's Avatar
And the front suspension, bumper, modified upper bumperplate...:
Old 05-06-2004, 09:02 AM   #4180
markp27's Avatar
Send a message via ICQ to markp27
Hey Kevin! Great pictures! Notice you haven't got the floating rear Impact mount that D was on about.
Look what I've found in my spares box
markp27 is offline   Reply With Quote
Old 05-06-2004, 09:46 AM   #4181
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Looks nice KevinS!! Have you ever noticed with the S9550 steering servo and a gear dif on the front that the serpernt servo saver makes contact with the gear dif casing? I had to dremmel down my serpent servo saver a lot so it clears. I hope it holds now with less material around the balls.
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 05-06-2004, 10:12 AM   #4182
KevinS's Avatar
Maybe I'll get the floating body mounts later. I havn't driven the car in this configuration yet, so maybe it turns out I need it afterall. Shame about the extra holes in the body if so...
Old 05-06-2004, 10:17 AM   #4183
markp27's Avatar
Yeah I'm holding off painting my GTP shell until I get the floating rear mount for that very reason.
I'm probably going to order the 2106 for the 705 - I was so impressed with the engine in my 710, how easy it is to tune and its power....it'd be terrible to go back to the SX-RE now I could never tune that engine
This is really breathing new life into my 705
Old 05-06-2004, 10:20 AM   #4184
KevinS's Avatar
I have never tried a gear diff. Does it have a 24T pulley too? Since with the front one-way the servo saver stays at least 1mm clear of the pulley...
Old 05-06-2004, 11:14 AM   #4185
Kevin - the stock servo saver cleared the one-way and they're both 24 teeth, but the extra diameter of the gear dif case compared to the small diameter shaft of the one-way is the problem..
I compared the S9550 to my S9303 that I used to have for my steering servo and the S9550 splines for the servo saver is moved forward about 1 mm and thats what makes it contact the gear dif casing.
John
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
