Old 03-18-2004, 07:39 AM   #4141
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
In your opinion, how much speed and torque should the servo be for the throttle and brake? Mine is lacking (S3004) and wanted to upgrade for this upcomming season. I could get a digital servo S9451 for the steering and put my current S9303 steering servo for the throttle. What's your thoughts?
John
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 03-18-2004, 07:46 AM   #4142
InitialD's Avatar
The S9451 is an excellent choice for steering. It's a good idea to use your current S9303 steering servo to throttle / brake duty.
Old 03-18-2004, 07:51 AM   #4143
I'll have to see for this upcoming season if I can get my hands on another S9451. I have one in my Xray and I love it. Will the S9303 be adequate for throttle/brake duty? [email protected] sec. (I think this is @ 4 volts, it might be higher @ 6v)
Old 03-18-2004, 09:02 AM   #4144
InitialD's Avatar
The specs is slow but should be plenty enough for throttle / brake duty.
Old 03-18-2004, 10:15 AM   #4145
Regional Moderator
kumpol's Avatar
How about S9450? I have 2 of them.....
S9402s are currently on my 705....ready to switch to digital servos......
kumpol is offline   Reply With Quote
Old 03-18-2004, 10:33 AM   #4146
S9450 has been discontinued.
S9303 at 6 volts is close to 95 with speeds of .18 @ 6 volts like I'll be using in the 705. I think it will be adequate, surely more than a S3004!
Old 03-18-2004, 11:22 AM   #4147
InitialD's Avatar
John is right. The S9451 superseeds the S9450. I still have the S9450 though and it is in my 705 as steering servo.
If I was you, I would use S9450 for steering and S9402 for throttle / brake.
Old 03-19-2004, 06:38 AM   #4148
Ok, here's whats going on in the servo department. I just bought an S9550 from randman.
Now do I use the S9550 in steering for the 705 (lower CG since the servo case is smaller and wont stick so high off the upper deck)and S9303 in the throttle/brake or do I take the S9451 out of my xray and put it into the 705 with the S9303 throttle brake, and put the new S9550 in the xray?
Will the S9550 be powerful enough for the 705? Speeds are great, but torque is around 90. S9451 is a lot stronger in the torque catagory and the same speed.
Inquiring minds want to know... This is the perfect time to wrench on cars, we just got 5" of snow! Grrr, and tomorrow is the first day of spring!
John
Old 04-03-2004, 02:08 PM   #4149
DOMOisCOOL's Avatar
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
BUMP
DOMOisCOOL is offline   Reply With Quote
Old 04-07-2004, 05:55 PM   #4150
Rapid Roy's Avatar
Hi, I bought a solid rear axle for the Impluse to use in my 705. The problem is that the solid axle is quite a bit wider then the ball diff. I went back the my LHS and got the Impulse spring steel dog bones to use with the solid rear. Is this the correct way to do it? I couldn't find a solid rear axle specifically for the 705.
Rapid Roy is offline   Reply With Quote
Old 04-07-2004, 09:09 PM   #4151
InitialD's Avatar
Yes. The thing is the Impulse solid rear axle (801401) is not made of Hudy spring steel for your information.
You could use the Impact solid rear axle and it is made of Hudy spring steel. Part number is 808370 for the complete set which comes with the solid axle and a 47T rear diff pulley. You could drop it right in the 705 because the 705 uses the Impact rear dogbones !
If you are currently using the low gear ratio (17T/22T/47T) on the 705, then you need not change the 47T pulley. If you use the normal stock internal ratio (18T/23T/46T), you need to get the 46T solid axle pulley (808371) separately.
If you want to get the lightened version fo the Impact solid axle, you could get the 808372 but note that it does not come with any pulley. All of them will fit the 705 with the stock dogbones.
Old 04-08-2004, 08:45 AM   #4152
AlanLim's Avatar
Hey InitialD......
What rear solid axle will do on the 705....I know it works great on Impact.... no idea what will do for 705 or Impulse.....explain please.....
How rear solid axle works on the 705....what effect I will get?
AlanLim is offline   Reply With Quote
Old 04-08-2004, 09:00 AM   #4153
teammpp's Avatar
Originally posted by AlanLim
Hey InitialD......
The impact solid axle will work on the 705. Not 100% sure but it should be the same as the 835 solid axle.
teammpp is offline   Reply With Quote
Old 04-08-2004, 08:14 PM   #4154
InitialD's Avatar
They are the same. The solid axle of the Impact / 835 will work on the 835 without modifications.
Old 04-08-2004, 08:17 PM   #4155
InitialD's Avatar
You get lots of on power steering. Less of off power steering.
Usually, on a large sweeping track, the fastest combo would be a solid rear and a front oneway.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
