Old 12-16-2003, 02:22 PM   #4051
Ducati998's Avatar
Default Re: 705 Laydown Steering System
Originally posted by sungtaz
705 Laydown Steering System (Look Like 710)
Coming Soon...........................................WOW
I think that radio tray is not design to be laydown. You can tell that the front of the radio tray have a opening for the steering servo. Also from the parts of the two pictures, it probably going to need more part then that to convert the 705 to a 710.
Ducati998 is offline   Reply With Quote
Old 12-26-2003, 05:43 AM   #4052
Diesel Racer's Avatar
Default Foam Tyres
Having just received my Hudy Tyre Truer for Christmas, I'm now making the switch to running foams instead of my usual rubber tyres on the Impulse Pro. I fancied giving the Jaco Nitro Shoes a try but beleive these may not fit is that correct? Also looking for a decent baseline setting such as tyre sizes, ride height etc.
Any info would be most welcome
Cheers
Mark
Diesel Racer is offline   Reply With Quote
Old 12-26-2003, 06:30 AM   #4053
InitialD's Avatar
Default Re: Foam Tyres
Mark, are you using one way front? You can try and look at Julius Kolff's setup ay mytsn.
Old 12-26-2003, 07:26 AM   #4054
Default Re: Re: Foam Tyres
No, at the moment D I don't have the front oneway that will have to be the first purchase, so I know for now I'll have to keep front and rear diameters the same.
Old 12-28-2003, 10:13 PM   #4055
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
I am letting my 705 go, built second night at winternats last year, ran perfect, took the point series this year, never missed a lick, would of one the big race( local race) took a glow plug while pulling on the field ( second lap) came back 7 laps down finished 2nd 1/3 lap back..
car was very very good to me.. got 4 710's prepped for winternats 2004, tires are in, motors are prepped and bench broken in, sad day , put my 705 on ebay... it was harder to put my pro on ebay, I had progressed that car from a streetspec to a pro over three years, it went through two national events a worlds, and countless local racing shows... but all that pain for a little progress.. all i know is my pro to 705 made no difference on the track and I would expect the same out of the 710.. just a few more adjustments to get wrong..
ammdrew is offline   Reply With Quote
Old 12-29-2003, 08:17 AM   #4056
EVOLUTION's Avatar
Bump.
EVOLUTION is offline   Reply With Quote
Old 01-11-2004, 03:25 AM   #4057
bleach1's Avatar
I have just started doing a little club racing with a 705 and was wanting to get a list of spare parts to keep with me. From peoples experience what spares should i cary for this car?
bleach1 is offline   Reply With Quote
Old 01-11-2004, 10:39 AM   #4058
Send a message via ICQ to lawndoggie Send a message via Yahoo to lawndoggie
Oh yea, this post is right up my alley! I am new to RC and got myself a 705 5 months ago.. let me tell you, I've broken tons of parts!!
YOu are gonna neeed shock shaft, top shock cover, ands that little composite thing that connects to the bottom of the shock shaft.
Then you need arms, front lower and upper arms, then rear lower arms...
And then you need bumper holder, both the top and bottom. Oh and get a pair of front doggie bones... Last but not least, get a few FC steering blocks!
lawndoggie is offline   Reply With Quote
Old 01-12-2004, 05:24 AM   #4059
bleach1's Avatar
This is a post about the 705 shocks. When they are assembled they had resistance but didnt spring out like other shocks i have built in the past. Is this normal with serpent shocks? When i fitted the top diaphram i found using ca to hold it was useless so i just fitted it and put the cap over it ensuring a seal. none have leaked as of yet. Anyone else do it this way?
Old 01-12-2004, 06:52 AM   #4060
Sow&Steady's Avatar
Bleach, this has always been one of the issues for the 705. The best is to use the new translucent o-rings which Serpent has released. I don't have the part number handy but I bought a set, replace the old ones and presto!
Sow&Steady is offline   Reply With Quote
Old 01-12-2004, 08:57 AM   #4061
InitialD's Avatar
Which translucent O ring is this? Do you mean the new purple O rings? I think the newer batches of the 705 already included this as a standard. That was what I noticed. Part number is 909407.
bleach1, I think your problem lies in the piston having small plastic flashes. You need to smoothen them out. Look here for the shock building tip. Ignore the alloy shock seal part as this is not required anymore with the new type bladders.
Old 01-12-2004, 09:07 AM   #4062
Sow&Steady's Avatar
Yes, the pruple o-rings.
I assume the flashes were taken care of by bleach1, else nothing will help!
Old 01-18-2004, 03:00 AM   #4063
bleach1's Avatar
Im having problems under braking. The back end of the car is stepping out just as i come to a tight corner at the tracks, so the grip is ussually high. Would using the transmitter ABS have a helpful effect without losing to much braking distance?
Also does serpent make aluminium shock bodies?
Old 01-18-2004, 03:13 AM   #4064
modellor's Avatar
Problem could be a number of things but most likely related to the shocks not being equal on both side (right and left). Are you running the front one-way? This will really magnify any problems in the set up.
Another problem could be the anti-roll bars or the chassis are tweaked.
If you have access to the set up stations follow the set up section in the rear of the manual and get the car set up mm perfect. It really has to be totally perfect to the mm or the 705 just doesnt drive right.
modellor is offline   Reply With Quote
Old 01-18-2004, 07:26 AM   #4065
InitialD's Avatar
Using ABS would help. But then the throttle servo will suffer. It wears faster.
What modellor mentioned is correct. You need to get everything perfect and tweak free in order that the car brakes hard and straight. Of course not as hard as you can brake with front diffs / solids but you will still be able to brake reasonably well.
Driving needs to be more disciplined. Especially on a tighter track as you need to be precise on the driving lines and the braking points.
The trick for the rear to not swap ends is NOT to make the rear wheels lock up when you brake. This means that you need to set the braking end point on the Tx a lot lesser. Also, what you can do to not make the rear lock up upon braking is to tap your brakes 2 or even 3 times. The car should be slow enough at the right speed to take corners.
With a front one way, you need to reduce rear droop to lessen the weight transfer to the front. A lot of weight transfer to the front (as a result of a lot of rear droop) will make the rear of the car step out upon the slightest of braking.
Yes they do. 909410 for the front. 909411 for the rear.
The aluminum ones will work better when ambient temperatures are high at 30 degree Celsius and above. That's what Serpent says.
On a side note, I put all 4 aluminum shock bodies on my 710 and they felt way "heavy" ! I never knew it made such a difference to the plastic ones.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
