Old 02-17-2003, 08:50 PM   #361
Trader Rating: 2 (75%+)
Lightbulb
JJ187RC,
You bet, how about you?
PUNISHER is offline   Reply With Quote
Old 02-17-2003, 10:19 PM   #362
InitialD's Avatar
Originally posted by Ducati998
Thanx InitialD, maybe youi can help me out instead. I was just wondering can you order part directly from Serpent USA? Also do you think if JACO foam would fit on the Serpent? Thanx!
I'm not from your part of the world (I'm from Mars ) but I don't think Serpent USA sells directly to end users.
As for Jaco Nitro Shoes, I don't know if they fit the 705. But I know for a fact that they were lots of it on display in one shop that I went in Singapore that was selling exclusively Serpent. I bet they fit but don't take my word for it. I'll try and give them a call and ask them if people had sucess using them on the PRO / 705.
Old 02-17-2003, 10:49 PM   #363
Ducati998's Avatar
Thanx! But I'm getting the 705 anyway, my cheap lhs which I think only carry Jaco but if it dosen't work then I try other foam from tower. Anyway please find out for me if you can. Thanx for the help!
Ducati998 is offline   Reply With Quote
Old 02-18-2003, 08:27 AM   #364
JJ187RC's Avatar
Punisher
Yes I will be there. I am ready to put this thing on the track and see what happens.
JJ187RC is offline   Reply With Quote
Old 02-19-2003, 05:56 PM   #365
Neil Rabara's Avatar
What did any of you guys do to the stock brake system on the 705 to get the pads to separate from the disk? Testing out my car, I noticed that the pads didn't move after I applied brakes.
Neil Rabara is offline   Reply With Quote
Old 02-19-2003, 06:45 PM   #366
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
they should move freely on there pins, and the top can be adjusted so it works to realease the brakes properly, just pull the arm off and move the plastic insert to get better alignment.. it should return to a perpinticular angle to the chassie... when released....
takes some monkeying around to get right, if it seems tight, check to make sure you do not have a bind in the top plate or the bulkhead on the bottom support... should have free rotation when realeased...
ammdrew is offline   Reply With Quote
Old 02-19-2003, 08:21 PM   #367
Pit-racer's Avatar
Well I fixed my shock problems by getting the alum. shock bodies and while I was at it I installed alum. pullies.I will be testing it at the swcs race this weekend and let you all know what happened. Rcinfinity just make sure the top brake bracket is not binding,there is a lip under it to sit the pads.
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 02-19-2003, 08:22 PM   #368
Thanks, I'll take a look at it.
Old 02-19-2003, 08:24 PM   #369
JJ187RC's Avatar
Pit-Racer,
Where the shocks coming off under Imapct or just coming off? I have not had that problem yet, but I have also not run the car that much.
Old 02-19-2003, 08:38 PM   #370
Pit-racer's Avatar
They were coming apart at the cap.Either the mold on the threads were bad or the bladders don't sit right.I stated earlier I had previous serpent cars and never had this problem...after two complete rebuilds I just bought the alum. shock bodies.
Old 02-19-2003, 08:55 PM   #371
InitialD's Avatar
Originally posted by JJ187RC
Pit-Racer,
I believe they come off upon slight impact. They usually don't. I had mine came off with a slight side brush against the wall.
The ones that I have on the PRO are with aluminum shock bodies and the threads do not strip. Heck, I clipped a side wall the other day and part of the shock cap broke into half. The bottom part of the shock cap was still threaded to the shock body. It was funny because there was no leaks and I could see the top of the bladder working.
Old 02-20-2003, 01:03 AM   #372
Advanti's Avatar
Default Problems with 705?
Hi guys,
i've been reading this shock problems on the 705. In fact, i 've ordered 705 as my 2nd car, but it seems to me there are many problems to be solved even its new and seems quite fragile on the shock bodies.
I am wondering if this shock in the 705 the same as in the Pro?
Or Serpent has reverted to plastic shock bodies from Alu. ones which is in the Pro?
Advanti is offline   Reply With Quote
Old 02-20-2003, 06:49 AM   #373
ammdrew's Avatar
the shocks have not changed, what i think is they had some mold runs that have too much glass or something in them, and they are breaking a bit easier, it is the same shock they have had four 4 years now, with the addition of the d shaft and pistons from the x-ray, so should not bee any issues,
no real problems with the car, and the shock i brioke was off my pro and probably 3 years old, an dit broke from impact....
serps are usually the strongest car on the track, mugan is right up there now with there new car, and all cars break on the wall, some of the first run 705, 835, and 950 seemed to have unusually easily broken parts but i would not expect this to contionue, and only saw it in the early release kits......
Old 02-20-2003, 01:48 PM   #374
markp27's Avatar
Send a message via ICQ to markp27
Default Taking an RC car on a plane?
Hi Guys,
I intend to fly from Germany to the UK this year and want to take my car with me. Is it normally possible to take the car as hand luggage?
How do the pro guys transport their cars?
Does anyone have any recommendations for carry cases, etc. ?
Thanks , Mark.
markp27 is offline   Reply With Quote
Old 02-20-2003, 01:52 PM   #375
ammdrew's Avatar
you will have to check the car in checked luggage, we shipped to the hotel, and met the cars there..
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
