Old 09-22-2003, 11:19 PM   #3661
InitialD's Avatar
Originally posted by Pyramid
Can you point me where is the discussion for this front mod? I`ve been looking trough couple pages within this threads with no luck. Thanks
3 mm inwards and 2 mm upwards from the original pivot pin hole location on the front bulkhead. See attached pic that I have posted earlier.
Old 09-22-2003, 11:34 PM   #3662
Pyramid's Avatar
Thanks.... Thats the hard home work to do
Pyramid is offline   Reply With Quote
Old 09-22-2003, 11:45 PM   #3663
InitialD's Avatar
Yes, it is quite tricky to get both holes to line up correctly and equally for both left and right upper arms.
Old 09-23-2003, 12:34 AM   #3664
InitialD's Avatar
Default Front Shock Placement (705)
Mark, this is how I do it on the 705. I do not tighten it down hard. Just enough that the M3 screws do not bind the shock movement.
Old 09-23-2003, 12:35 AM   #3665
InitialD's Avatar
Default Front Shock Placement (Impulse PRO)
This is on the Impulse PRO with cap screws.
Old 09-23-2003, 12:43 AM   #3666
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Front Shock Placement (705)
Yep, that's how I had mine, but mine seemed to bind even though I didn't screw them right down. As if the tops twisted a little and hit against the button head of the screw.
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 09-23-2003, 01:01 AM   #3667
Send a message via ICQ to lawndoggie Send a message via Yahoo to lawndoggie
Default fuel
Hi,
Interested to know the kinda fuel people use and the oil content.
Thanks, I am trying to select one and stick with it.
I have a RS12T5
lawndoggie is offline   Reply With Quote
Old 09-23-2003, 01:02 AM   #3668
markp27's Avatar
Here's my clockwork D1 picture InitialD
We've got an airline at the track now, so I can blast all that dirt off my car and no longer need to use my Dirt-Filter (c)
Cheers, Mark.
Old 09-23-2003, 01:07 AM   #3669
InitialD's Avatar
Default Re: fuel
I have a RS12T5
I believe in HK you can get Tornado fuels right? Stick with it. I have very good experiences with it so far. Very good power and easy to tune.
Old 09-23-2003, 01:26 AM   #3670
markp27's Avatar
The pictures have gone to my head. It isn't even friday
Here's a pic where you can see the 1/8th servo saver fitment and the solid front diff (sweet)!
Old 09-23-2003, 02:03 AM   #3671
InitialD's Avatar
I own up... I'm feeling really jealous already? Play the car more often !! It is too clean... Arrrhh !
I see that you use an allen cap screw to lock the servo saver onto the servo... Nice and easy right?
Perhaps the reason why you're still getting good steering with the front solid is because of the 1/8th scale servo. They give more agressive steering... Just a thought.
Old 09-23-2003, 02:42 AM   #3672
markp27's Avatar
It's a clean machine
The allen screws are indeed much easier to fit - but it is only that I lost the screw that I ended up fitting the allen headed screw Lots of screw lock this time
Maybe you're right about the servo saver giving me a lot of steering - certainly seem to get a lot of lock on the steering.
I'm going to alter the sensetivity on my RX unit for the breaking - I can program in different curves. The travel of the lever is too long when I want to break. I'll make it so that a small bit of travel in the breaking-direction results in a larger movement on the servo. This should give me more responsive breaking
Then I need to turn up my ATV a bit - it is only running on 40% at the moment. I probably haven't seen the full breaking potential as yet
Old 09-23-2003, 02:48 AM   #3673
InitialD's Avatar
Don't get carried away with too much braking... You need to maintain speed around corners to go fast. Brake just enough to slow the car down.
You must remember that at home, it can be a clean machine but on the track, it is a mean machine !
Old 09-23-2003, 03:16 AM   #3674
markp27's Avatar
The power of the breaks is going to my head
It's a mean, lean, clean machine!
Old 09-23-2003, 03:41 AM   #3675
Schrijver99's Avatar
Lightbulb
Ok its not friday, but here are my pics of the front supension
1: IMPULS PRO modded (front)
Schrijver99 is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
