Old 09-18-2003, 12:04 AM   #3586
InitialD's Avatar
Default Re: Re: Re: Re: Re: [Off Topic] Michael Salven's Radio Antennae
Originally posted by markp27
I was in contact with Ray Wood (Australian guy) who did the 2001 1/8th WC and he was telling me he left last week for the USA to do the WC for this year. I've just ordered the 2001 DVD to see what it's like - his 2003 WC DVD should be ready around christmas time.
Ahh, trying to get some inspiration on driving a 1/8th scale so that you can picture them better in your dreams?
I have the 2001 1/8th scale WC video held in Australia. Superb !
Old 09-18-2003, 12:40 AM   #3587
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Re: Re: Re: Re: Re: [Off Topic] Michael Salven's Radio Antennae
Dreams, dreams
Is your video from Ray? Really looking forward to seeing this!!
markp27 is offline   Reply With Quote
Old 09-18-2003, 12:49 AM   #3588
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: [Off Topic] Michael Salven's Radio Antennae
[BIs your video from Ray? Really looking forward to seeing this!! [/B]
Yes it is.
Old 09-18-2003, 01:03 AM   #3589
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: [Off Topic] Michael Salven's Radio Antennae
Yes it is.
It's not perceived as a sign of madness, when you watch the video with your TX unit in your hand, is it?
Old 09-18-2003, 01:15 AM   #3590
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: [Off Topic] Michael Salven's Radio Antennae
When that time comes, you'll know it's time to seek psychiatric help at the hospital and look for RC Anonymous counselling support group !
Old 09-18-2003, 01:27 AM   #3591
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: [Off Topic] Michael Salven's Radio Antennae
I can handle it - it's not like I can't live without it - I just like to carry my Rx unit around with me
Old 09-18-2003, 05:59 AM   #3592
Schrijver99's Avatar
Lightbulb
. Strange too that the external diff adjuster does not come with instructions. Neither has mytsn...
Anyway, my guess is that it's just an add on.
TIP:
You need to polish the outside of the dif where the external dif adjuster turns.
Schrijver99 is offline   Reply With Quote
Old 09-18-2003, 07:37 AM   #3593
EVOLUTION's Avatar
I agree,Ray does some awesome videos and the one of this years worlds should be no different.
EVOLUTION is offline   Reply With Quote
Old 09-18-2003, 11:49 AM   #3594
Originally posted by Schrijver99
TIP:
Schrijver99, does external gear adjuster eliminate the diff rings and balls, thrust bearing?
Sometimes I post just to look at Kraig's avatar
RoyU is offline   Reply With Quote
Old 09-18-2003, 01:23 PM   #3595
gear adjuster? maybe diff adjuster
No you still need the balls, it only replaces one ring (leftside)
Old 09-18-2003, 09:32 PM   #3596
InitialD's Avatar
TIP:
Nice pic of the rear. The rear adjustable sway bars don't look like they were set equal. Stiffer on the right than the left side?
Anyway which part exactly that you need to polish? Is that the left side long shaft (801432) where the diff adjuster nut sits inside? Why polish? Thanks.
Old 09-18-2003, 09:34 PM   #3597
InitialD's Avatar
You mean one of the two plates (the left plate) that holds the balls on each side need to be taken out (8378)?
Can you walk us through step by step on what you do to adjust the rear ball diff with the external diff adjuster when you tighten or loosen the diff at the track?
Old 09-19-2003, 01:26 AM   #3598
Exclamation
Thx, haven't seen it
It's a tip i got from a team driver (stanley Bauer), if you polish the part that is red in the picture, the dif will be more adjustable for better control.
To put the new adjuster on:
Polish the part in the pic
In step 3.2 (3.0 Differential Assembly) replace the metal ring (8378) with the dif adjuster
Put in the 3 screws and the hexscrew
Finish
The working is about the same as with the FPS dif
Turn in = more lock
Turn out = less lock
same as the fps but a little less control of the lock but with less weight
Old 09-19-2003, 01:33 AM   #3599
Whoops forgot the pic
Old 09-19-2003, 01:40 AM   #3600
InitialD's Avatar
Got it !
You mean in step 3.2 or 3.4? Step 3.2 metal ring will be on the right side of the diff. Step 3.4 will be the metal ring on the left which is the same side as where the external diff adjuster will be installed...
Turn in = more lock
Great. After turning the rear wheel to lock in (tighten) or lock out (loosen) the rear ball diff, I assume you need to lock the cap screw so that the settings will not run?
Do you still need to use the small pin to lock the diff screw like what is done in step 3.3 to tighten or loosen the diff?
Thanks for all the reply. I guess you're the closest we can get to a Team Serpent driver in Holland !
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
