Old 09-07-2003, 12:45 AM   #3436
InitialD's Avatar
Originally posted by RoyU
BTW D, when are you coming to Hawaii??
Currency exchange rates does not favour us. But no doubt, Hawaii beaches are one of the most beautiful in the world.
I sure can't afford to go to Malaysia?
Can't afford Malaysia? Yeah right... Genting Highlands is now a little different ya know...
Old 09-07-2003, 12:49 AM   #3437
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: 1/8th Sevo saver
Originally posted by markp27
Mine is part 1635.
Was not referring to the servo saver. Was referring to the brand of the servo itself.
What was that with the pulley flange?
The flange has a curved side and a flat side. The curved side is suppose to face the inner side of the pulley and belt. The pulley flanges on the one way are correct while the one on the solid axle is not as the way the pulley flange on the right side was mounted, the flat / sharp part faces toward the inner pulley. You will find your belts strip faster if they are installed incorrectly
Old 09-07-2003, 12:52 AM   #3438
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Re: Re: Re: Re: Re: Re: Re: 1/8th Sevo saver
Aha! I fluked it Murphy's law doesn't always strike
markp27 is offline   Reply With Quote
Old 09-07-2003, 01:00 AM   #3439
Naturally
Never been to Genting. Saw it on the travel channel on tv. Thats when I asked you if you've been there
Sometimes I post just to look at Kraig's avatar
RoyU is offline   Reply With Quote
Old 09-07-2003, 01:08 AM   #3440
InitialD's Avatar
Aha, I thought I remembered you mentioning to me that you've been there. Nothing to shout about though. It's a Casino / theme park but nothing like Las Vegas or Disneyland. One of the coldest place in Malaysia. 20 to 25 degree Celcius (68 to 77 F).
Ok, I'm rambling... Perhaps I should admit that the 70's show applies to me as well
Old 09-07-2003, 01:11 AM   #3441
markp27's Avatar
Hey stop this now! You guys talking about the 70s and being old - man-o-man!!!! You've got 6 years on me InitialD!!!!!!!!!!!!!! You're making me feel old!!!!!!
Old 09-07-2003, 01:15 AM   #3442
InitialD's Avatar
Ah, that was the idea
Anyway, I saw your posting on mytsn. On the contrary, I measured and the one way unit from end to end is 42 mm. The front solid axle is 1 mm longer at 43 mm !! It must be the pro drive cups / diff adaptors that is making the whole assembly shorter.
Old 09-07-2003, 01:18 AM   #3443
markp27's Avatar
I should have made myself a bit clearer on that point - it is indeed the completley assembled width I was talking about.
It's my age, you know - makes one forgetf.... ehm, what was I talking about
Old 09-07-2003, 07:44 AM   #3444
taz5176's Avatar
Default Re: Re: Re: Re: Re: Re: 1/8th Sevo saver
Mark and taz, it could be the different servos you're using? What are they?
I checked the one way and the solid axle. The 24T pulley (808229) is the same one used on the solid axle and one way. So they cannot be different.
P/S: I just noticed that the pulley flange (right side) on the solid axle is installed wrongly
hi guys, im using a sanwa vr. when i turn left, it'll hit the pulley flange (did i get the name right?)
anyone using a sanwa vr wif a 1/8 servo saver?
taz5176 is offline   Reply With Quote
Old 09-07-2003, 08:03 AM   #3445
markp27's Avatar
I have a Futaba servo, so there must be a slight difference in the position of the servo head on the sanwa. (pulley flange seems to be the right word to me )
Old 09-07-2003, 08:08 AM   #3446
markp27's Avatar
It shouldn't be a problem to remove some material from the servo saver flange to allow it to fit - I take it that it would just be the tip of the servo saver flange which is causing the problem? Simply grind it down a small amount - not too much though!!
Old 09-07-2003, 10:04 AM   #3447
InitialD's Avatar
Ummm, the stock servo saver does not have any problems if you follow the 705 manual instructions of installing a Sanwa / Airtronics steering servo to the T.
Ummm, it looks like for your case if the problem of steering servo mounting can already be solved with the stock servo saver, going with a 1/8th scale servo saver would get your into problems It's like 2 rights will end up in a wrong.
In your case, you should use it still and remove some material on the servo saver like what Mark has suggested because it gives a better Ackerman steering.
Old 09-07-2003, 02:41 PM   #3448
Send a message via ICQ to lawndoggie Send a message via Yahoo to lawndoggie
Default Throttle hitting gas tank
Hi, I just finished assembling the 705. One thing I noticed, when I extend the throttle switch on the engine fully, the "opposite end" of the ball head hits the black triangular plate (that holds the gas tank). I use a RS12 5P. Anyone ran in this problem before? And how did you fix it?
Secondly, I had lotsa problem putting the mid belt onto the pullies... Any suggestions?
Thanks for the help.
lawndoggie is offline   Reply With Quote
Old 09-07-2003, 03:20 PM   #3449
modellor's Avatar
I have that engine also. I didnt have any problems installing it in my 705. You can cure the problem by a couple of methods.
Firstly you can try turning you carb slightly so the ball does open over the tank mount.
Secondly, You could loosen the ball end and rotate it slightly so that it clears the carbon mount.
modellor is offline   Reply With Quote
Old 09-07-2003, 05:27 PM   #3450
Arun's Avatar
Interesting, InitialD...I never noticed that there was a difference in the sides of the pulley washers.
http://nexusracing.com
Arun is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
