Old 09-06-2003, 09:10 PM   #3421
InitialD's Avatar
Default Re: Re: Re: 1/8th Sevo saver
Slotmachine, the 1/8th scale servo saver trick is not new. Back in the days of non HPI forum on the Serpent Impulse PRO thread, this was already discussed. I believe the tip was passed to us in a form of a fax from Art Carbonnel directed to one of the racers (Kyle Gannon). In that tip, there were other stuff that was described among other things where Impact parts (pulleys etc) were used in the Impulse PRO.
Old 09-06-2003, 10:53 PM   #3422
Default Re: Re: Re: Re: 1/8th Sevo saver
Hey D, you got photographic memory? remembering all that
Sometimes I post just to look at Kraig's avatar
RoyU is offline   Reply With Quote
Old 09-06-2003, 10:56 PM   #3423
InitialD's Avatar
Default Race brakepad-set L + R (type A) - 9607
Woow, this is just in from mytsn.
Quote;
Braking at its best !
Complete set of steel brake-plate with a special type of, pre-mounted, brake-liner. Fits all Serpent cars. After many tests this brake-compound proofs a very high coefficient of friction, under al sorts of conditions. It needs limited time to heat up and then stays very stabile. No more glueing of brake-pads. The pads are mounted on to the plates in an industrial oven and then grinded to the correct thickness.
Old 09-06-2003, 10:58 PM   #3424
InitialD's Avatar
Default Re: Re: Re: Re: Re: 1/8th Sevo saver
I get paid by HPI
Did you not remember that piece of fax posted on that forum?
Old 09-06-2003, 11:09 PM   #3425
Default Re: Re: Re: Re: Re: Re: 1/8th Sevo saver
I get paid by HPI
Let's just say "the seventies were good to me"
Old 09-06-2003, 11:11 PM   #3426
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: 1/8th Sevo saver
Holy cow... Bell bottoms, Beetles and flower power ring a bell?
Old 09-06-2003, 11:38 PM   #3427
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Race brakepad-set L + R (type A) - 9607
Quote;
NICE! Someone is working overtime at Serpent - normally there are no product updates during a weekend - maybe they have soooooo many new things, that they now have to work longer
markp27 is offline   Reply With Quote
Old 09-06-2003, 11:41 PM   #3428
InitialD's Avatar
Default Re: Re: Race brakepad-set L + R (type A) - 9607
Yup, moreso during summer.
Old 09-06-2003, 11:48 PM   #3429
Default Re: Re: Re: Re: Re: Re: Re: Re: 1/8th Sevo saver
Yup, I'm an oldie
Memory not like it used to be
Old 09-06-2003, 11:51 PM   #3430
InitialD's Avatar
I saw it was close on mine, but it didn't seem to touch the pulley - I'm using the solid axle and not the one way - maybe there is a size difference there?
If it is touching, then you will certainly have to modify the servo saver.
Cheers, Mark.
Mark and taz, it could be the different servos you're using? What are they?
I checked the one way and the solid axle. The 24T pulley (808229) is the same one used on the solid axle and one way. So they cannot be different.
P/S: I just noticed that the pulley flange (right side) on the solid axle is installed wrongly
Old 09-06-2003, 11:52 PM   #3431
BTW D, do you live 24/7 in front of your computer?
It seems like you're always on the forums/threads
Old 09-06-2003, 11:55 PM   #3432
InitialD's Avatar
Really? I'm actually sleep writing.
Ummm, don't old people need to sleep less?
Old 09-07-2003, 12:13 AM   #3433
Well actually, I would like to sleep more, but I end up sleeping less
Then I become a GRUMPY, FRUMPY, GRUMPY old man
BTW, we're getting off the subject 705 remember
Old 09-07-2003, 12:18 AM   #3434
BTW D, when are you coming to Hawaii??
I sure can't afford to go to Malaysia?
And NO, I can't afford to sponsor you
Old 09-07-2003, 12:24 AM   #3435
markp27's Avatar
Mine is part 1635.
What was that with the pulley flange?
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
