Old 09-02-2003, 07:58 AM   #3301
Pyramid's Avatar
Originally posted by InitialD
RM 230 or approx USD 60. It's not the original Serpent 4 mm chassis though.
Any shops in town selling it already? How much?
Original serpent is selling at aprox USD80 here in Indonesia since about almost 2 months ago.
Pyramid is offline   Reply With Quote
Old 09-02-2003, 10:34 AM   #3302
Send a message via ICQ to nizee
US$80 ?? Wow...
D,
I forgot about Punisher Serpent 4mm chassis Picture. I'll post it when i'm back home. I don't think it's detail pictures, since i took it kinda distance away. Me and Punisher "only" is my pit buddy here at the track.
nizee is offline   Reply With Quote
Old 09-02-2003, 11:34 AM   #3303
Trader Rating: 2 (75%+)
Aaahhh........I thought we had much more then that!!
PUNISHER is offline   Reply With Quote
Old 09-02-2003, 01:02 PM   #3304
Arun's Avatar
I did have the old version, but that didn't matter. By hitting the spotter's foot, it bent the chassis in the front AND tweeked it noticeably from left to right. It ended up also breaking my right side graphite brace and my side belt. And, it bent just about all of my alluminum screws in the front. Oh, yes, and it tore up my body.
$$$$$$$$$$$$$$$$$$$$OUCH!$$$$$$$$$$$$$$$$$$$$$$
http://nexusracing.com
Arun is offline   Reply With Quote
Old 09-02-2003, 01:15 PM   #3305
Yupe.
Old 09-02-2003, 08:31 PM   #3306
initiald..
ur 4mm chassis is not original
wat brand izit or custom made ? izit light n strong ?
pokemon is offline   Reply With Quote
Old 09-02-2003, 09:00 PM   #3307
InitialD's Avatar
No, not original... The brand is Shooter. I believe they make a lot of hop up parts for Kyosho and Mugen.
It's very strong. 7075 material. However, the chamfering at the sides, front and rear is not as much as the original one when I compare it to the pictures on mytsn. Heavy? I thought the 3 Racing 4 mm chassis for MTX-3 is heavier but I may be wrong. The cooling holes are of different design. It is somehow chamfered to be more aerodynamic and angled to scoop more air unlike the original chassis. Wait for Friday
Old 09-02-2003, 09:16 PM   #3308
Default Serpent 4mm Chassis
This is Punisher 4mm Chassis.
Hope it looks clear.
Old 09-02-2003, 09:20 PM   #3309
InitialD's Avatar
Default Re: Serpent 4mm Chassis
Thanks. The chamfers at the side and rear of the original chassis looks more. Did Punisher take any weight readings?
Is that's your MTX-3 with Pixy engine in the background I see?
Old 09-02-2003, 10:24 PM   #3310
Default Re: Re: Serpent 4mm Chassis
Yupe, that's mine. Its Night racing here.
and by the side is Punisher.
Old 09-02-2003, 10:28 PM   #3311
InitialD's Avatar
Default Re: Re: Re: Serpent 4mm Chassis
Ummm, one big happy family
Old 09-03-2003, 09:16 PM   #3312
InitialD's Avatar
Default CG and Roll Center Revisited
One of the post made me put my thoughts deep in to this subject... Particularly relating to the 705.
Johan and some of you guys have asked how did the front upper arm mod felt and putting one and one together, I came to this conclusion...
I've not tested my car for some time (1 week is long enough ). On the intention to get more steering and getting even tire wear front and rear, I embarked on using softer front tires than the rear and the car will still work OK with no oversteer. I have also used a 4.5 mm split between the front and rear tires (using 18T side pulley, 22T brake pulley and 47T rear diff pulley). This should also make for more steering when running smaller front tires. In my incomplete testings, I have not used equal front and rear tire shore. My apologies for not bringing this up earlier but I think the front upper arm mod increases the roll center thus making the front part roll less. This means less steering.
My guess this is why Michael Salven (and perhaps Ralph Burch who I'm not sure if he did the front upper arm mod) had to take off the front sway bar to get enough steering.
I would think that on high grip tracks, this mod would prevent traction rolling to a certain extent. If Ralph actually did the mod, he probably set the car for way too much steering as it was reported that his car flipped a few times.
Going further, I think I may have overdone things a little. I think my front roll center is too high so much so I do not get enough steering. This is because using smaller front tires by running the split already increases the front roll center. Doing the front upper arm mod will increase the front roll center further On my Impulse, I remembered that I had lots of steering WITHOUT the front upper arm mod but only running with 4.5 mm split front and rear tires. It felt very nice. I think I'll run equal front and rear tires with the upper front arm mod and see how it goes.
Old 09-03-2003, 10:45 PM   #3313
Arun's Avatar
I can't ever seem to get any turn in when I run my front tires shorter. I have been trying to keep equal diameter front and rear, and it has been working for me lately.
Old 09-03-2003, 11:09 PM   #3314
InitialD's Avatar
In what way do you run the front tires shorter? The reason I run smaller front tires is to get the same front and rear rollout as a result when using different pulleys.
If you're just running smaller front tires than the rear with the stock internal pulleys, you're making the car underdrive i.e. rear driving the front. That would make for understeer.
Old 09-04-2003, 01:30 AM   #3315
Send a message via ICQ to lawndoggie Send a message via Yahoo to lawndoggie
Default New to RC
Hi everyone.
I am new to RC. Just got a 705. I know, not a good idea as a newbie.
Anyway, I just finished assembling Section4. I notices the front arms and rear arms are EXTREMELY tight. especially the back where the arms are connected to the shocks now... There is hardly any travel.. is this normal?? It takes substantial force to push the arms "up" and it only travels about 3cm (vertically), can this be right? When I take the shocks out, I expected the arms to hang freely, meaning if I take the car upside down, the arms should drop. But thats not the case. I reckon this is wrong because by having the arms sooooo tight, it limits the effectiveness of the shocks... can someone tell me how I can make things (especially the arms) lose.
Also, will the parts "losen up" after running the car on the track for a while?
Things seemed "tighter" after installing antiroll bars... it also seemed to limit vertical travels. I reckon if I don't want the car to roll over, would one just use stronger springs?
Last question, with the diff, when I move the rear wheels forward (both the same direction) there is slight metal noice, is this ok? And if I rotate the rear wheels in opposite directions, it is NOT as smooth... thats ok right? (This is what the local dealer told me to check)
Thanks for all the help!!
BTW, is there anyone here in HK on the forum? I would like to have the car checked before actually running it.
lawndoggie is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
