Old 08-25-2003, 08:11 PM   #3286
Arun's Avatar
Has anyone here ever yanked the new FC steering blocks off of the pivot balls. I raced in a big race near Atlanta this past weekend, and, on a slight hit in the A-main, it did this. I was able to pop it back on and run the remaining 30 minutes, though, finishing 6th.
I would have never beat Barry Baker anyways .
http://nexusracing.com
Arun is offline   Reply With Quote
Old 08-26-2003, 01:28 PM   #3287
Trader Rating: 2 (75%+)
Cool
Yes, the FC steering has a bigger hole for the pivot ball that allows it to pop off easily.
The good thing about that is what you mention you can pop it back in place then cracking them. However, the more times you yanked off the FC steering blocks the better chance of them not being reused because of the opening.
PUNISHER is offline   Reply With Quote
Old 08-28-2003, 09:09 AM   #3288
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
I damaged my 705 for the first time practicing on the track last night...its an asphalt track with pvc and coupled together. Going down the back straight at full speed I took the first right hand sweeper a little too tight and made contact with my front right wheel with a coupler which went the wheel/upper arm flying Broke the upper arm, pulled the lower ball through the knuckle and at the same time cracked the knuckle due to the lower ball being pulled from it. Boy was that a show stopper Darn me trying to get the perfect line I gotta learn to take that section a little wider, the same thing happened to my xray earlier in the season. Car was running like a top though.
John Fontaine is offline   Reply With Quote
Old 08-29-2003, 02:15 AM   #3289
apmk's Avatar
Default Pics
Hey its Firday, wheres the pics?
apmk is offline   Reply With Quote
Old 08-29-2003, 03:32 AM   #3290
markp27's Avatar
Send a message via ICQ to markp27
I'm on a engine and front end rebuild - still awaiting parts no pics from me
markp27 is offline   Reply With Quote
Old 08-29-2003, 07:28 AM   #3291
Accord's Avatar
Send a message via AIM to Accord
Default Serpent Factory Tour Pictures!
Hey guys, I was just browsing the Starting Grid website and came across a gallery of pictures from a factory tour of Serpent! Check out all the pics here... http://www.forgas.org:1089/0/index/19421983891743510
Also, go here for pictures of the Serpent museum with pictures of all the classic Serpent cars! http://www.forgas.org:1089/0/index/19421964612382508
Accord is offline   Reply With Quote
Old 08-30-2003, 11:18 AM   #3292
InitialD's Avatar
Yup, I had this experience before when I first tried the new FC steering blocks... Are you using these steering blocks with the correct pivot balls? The reason I'm asking is because the problem arose when I used the stock pivot balls with the new FC steering blocks. Since I changed to the new aluminum shortened pivot balls (801219), it was less of a problem. I only remembered the steering block coming off once after 5 months of use.
You will... soon
Old 08-30-2003, 11:22 AM   #3293
InitialD's Avatar
Engine and front end rebuild? What an excuse...
If you have an extra body post, do a 5th body post on the upper bumper plate holder just in between the front shocks and the upper radio tray while you're rebuilding the front end.
Old 09-01-2003, 12:57 PM   #3294
superk's Avatar
Ok..guys!! after years and years....of Serpent fan....now that I have (2) 705.......I decided to switch brand!! ... Almost every race...I have to have some kind of problem with the car...seem like I dont have any luck at all. ....also...with the price and parts avalibilty...and the new car every year...seem to make want to spend more $$$ ...witch..I moslt likely will... LOL... any how... This new car that I run for the 1st time...yesterday.. brought me 2nd place in 30Min A main. At my Local Race track (nice trophy event race www.wnyrcinfo.com )...so now I decided to leave Serpent for now.
Good luck to you all.
superk is offline   Reply With Quote
Old 09-01-2003, 04:00 PM   #3295
Red face
GOOD LUCK superk!
Hey D,
I took some pics of the s-705 4mm chassis but need to get them from Nizee that took them with his camera. Also I didnít take them before I ran it so it has some scares.
The chassis doses make the car more ridged.....had to take off the sway bars for a very loose track.
Old 09-01-2003, 10:57 PM   #3296
InitialD's Avatar
Are you guys still at the other's throats?
Nizee, would you be so kind enough to post them please?
Well, nevermind them. Post them anyways. I like to compare with the 4 mm one I got. The sides look like it does not have more chamfers like the original Serpent one. The air holes has a lot of chamfer for air cooling and the front is made more rigid. I'll post pics of it and try to weight it as well.
Thanks for the tip. I'll keep that in mind when I fit mine on. For the moment, I don't have any reason to fit it on as the stock one still works fine <knock on wood>.
Old 09-01-2003, 11:16 PM   #3297
Arun's Avatar
I had to replace mine recently after I hit a spotter (ouch). Unfortunately, only a 3mm chassis was available.
Old 09-01-2003, 11:32 PM   #3298
InitialD's Avatar
Arun, where did you break yours? At the front tip where the 1st screw locks onto the front bulkhead? Perhaps you had the 1st version of the 3 mm chassis which does not have reinforcements at the front.
Can't wait for Friday to post pics of the 4 mm chassis.
Old 09-02-2003, 03:30 AM   #3299
so how much did u pay 4 ur 4mm chassis ?
pokemon is offline   Reply With Quote
Old 09-02-2003, 05:27 AM   #3300
InitialD's Avatar
RM 230 or approx USD 60. It's not the original Serpent 4 mm chassis though.
Any shops in town selling it already? How much?
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
