Old 08-14-2003, 05:01 AM   #3106
Ec1
Ec1's Avatar
I dont know howe they match them but has been told it takes MANY ours finding the right part for one engine....
Fantini has the time to do so as he sells his own engen line (MAX).. but he does not work for Nova Rossi any more.
I dont there are many people who REALY god at matching and putting engines together that are REALY fast... But any way a stock JP, Rody etc is far more than most people can handle anyway....
Ec1 is offline   Reply With Quote
Old 08-14-2003, 05:07 AM   #3107
EVOLUTION's Avatar
I think you'll need someone a bit more versed in engine manufacturing/tuning etc but when the pistons and sleeves are made i think(could be wrong)they are both measured and sets are then chosen for the best "match".You obviuosly can't create all pistons and sleeves to be exactly the same size down to the millionth of an inch so therfor the "matching" process is what companies do to choose the best sets for there drivers.Supposedly the MAX engines have better matched piston and sleeves according to uncle manticore.
EVOLUTION is offline   Reply With Quote
Old 08-14-2003, 05:12 AM   #3108
Ec1
Ec1's Avatar
the best the public can have...
Old 08-14-2003, 05:15 AM   #3109
EVOLUTION's Avatar
Originally posted by InitialD
Ummm, anybody want to share how you select piston / sleeve fitting if one was given the chance to do so? I always wondered what engine tuners mean when they say they lap the piston and the sleeve to fit...
Also for normal sponsored drivers, do they go into the LHS and open up the engine to check piston / sleeve matching?
Unless some sponsered drivers have eye vision that is beyond comprehension then i don't think so. I have no idea how companies run there operations but maybe the best sets are kept for the drivers and the majority of the others that are within certain tolerances are put in engines and sold over the counter.I have heard of some people getting new P/S sets and then claiming there engine all of a sudden is a completely new animal,could be they got a lucky better matched set,who knows!
Old 08-14-2003, 05:22 AM   #3110
Ec1
Ec1's Avatar
And its not only the piston/sleve that has to be a god match.... everyting need to be... and together.... thats what makes it so hard to get a RELY god one...
Old 08-14-2003, 05:29 AM   #3111
EVOLUTION's Avatar
Is Fantini still sponsered by Nova or is he now competing with them?
Old 08-14-2003, 05:36 AM   #3112
Ec1
Ec1's Avatar
Does Nova has any competition?? The make RB. Rex. Top. Jp. Max. Nova Rossi. Mugen. Mega and the list goes on.....
th competetion is from OS and Picco then, but they are in a different leage
Old 08-14-2003, 05:46 AM   #3113
EVOLUTION's Avatar
LOL,i take it he isn't then.
They are an empire-
Old 08-14-2003, 02:18 PM   #3114
serpentracer1's Avatar
Send a message via AIM to serpentracer1
when looking at Ralphs car with the 950 arms on it Not sure if yall noticed that also the arm is moved in further to the center of the chassis directly in front of the rear top plate screws instead of to the outside of them So that makes me wonder how the lower arms are mounted also
DAVE (THE SNAKE) Rasnake
Original Mimi Wong Clan. M.W.C. For Life
Associated B6D
Orion R10 Pro VST powered
serpentracer1 is offline   Reply With Quote
Old 08-14-2003, 07:52 PM   #3115
Que
Has any one tried the alu pivot point shock caps yet or the alu shock seals?
Que is offline   Reply With Quote
Old 08-14-2003, 09:21 PM   #3116
InitialD's Avatar
Shock Absorber Alloy Membrane Ring (909408) was optionally used for better seal between the older shock bladder and the shock cap. The was applicable to the older shock bladder shape.
I believe I read somewhere on mytsn that Serpent recently changed the shock bladder shape and the new ones do not require this alloy membrane ring.
When using the alloy membrane ring with the older shock bladder, you needed to modify the shock cap a little. The extruding part that normally keeps the membrane in place needed to be cut away.
The membrane will be squeezed through the ring and the shock absorber can be assembled as normal.
After this modification the membrane will not be disformed any more when the shock absorber top end is tightened.
Old 08-14-2003, 10:00 PM   #3117
Pit-racer's Avatar
Nats pic....
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 08-14-2003, 10:01 PM   #3118
Pit-racer's Avatar
Another....
Old 08-14-2003, 10:03 PM   #3119
Pit-racer's Avatar
and another....
Old 08-14-2003, 10:48 PM   #3120
Trader Rating: 2 (75%+)
Cool
Thanks for those Pics Pit!!
PUNISHER is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
