Old 08-05-2003, 03:11 PM   #2926
Trader Rating: 2 (75%+)
Anyone know if Serpent has a development going on to succeed Serpent 705 next year ? Just out of curiosity
The rumor mill has been working on the next 705 coming out as soon as early of next year!! Some may say that the new "706" will have a completely new look. Time will just have to see if its the truth!!
Either way the new Serpent 706 car is my next nitro car!!
PUNISHER is offline   Reply With Quote
Old 08-05-2003, 03:13 PM   #2927
Originally posted by Que
Ok like i didn't bring up the rim thing first I know i am a rookie but give me some credit
Credit to Que with bents rims.
Old 08-05-2003, 05:17 PM   #2928
Que
Default Re: Any news for new development of SERPENT 200 mm
Originally posted by khyber
Guys,
Yeah when is the next 200mm serpent coming out and will there be a update kit for the 705?
Also is there a fix for the miss alinged holes in the front bulkheads where the upper deck mounting holes are? seams like this is tweaking my chasis!!
Que is offline   Reply With Quote
Old 08-05-2003, 05:41 PM   #2929
EVOLUTION's Avatar
Default Re: Re: Any news for new development of SERPENT 200 mm
Yes there is a fix but serpent would rather save money instead of rectifying the problem once and for all,and what is even more surprising is that one of there team members let this slip on mytsn!
I was always wondering why my pro just never quite handled correctly.
EVOLUTION is offline   Reply With Quote
Old 08-05-2003, 08:39 PM   #2930
InitialD's Avatar
Originally posted by Devin
Thanks for the reply guys on the rear camber/toe. This is the first nitro that you couldn't adjust the camber via the top by a turnbuckle. After I put the 705 back on the hudy board I was very suprized that no adjustments were out of alignment. It's a strong car so it stayed in tack. I was a -2.5 camber and 3 toe in for the rear. I changed back to -3 camber L&R and 2 toe in. I'll mount up a new pair of foams and see how that works for me. I still do not understand why when looking from the back of the car that the rear right would cone towards the outside of the rim when most of the turns are right handers...you think the left would wear more and that one looked fine.
Perhaps, it could be that maybe one of the left hand corners is a hard one taken at high speeds... What tire shores are you using?
Yes, the Serpent pivot ball suspension does not allow the camber adjustment to be made via turnbuckle camber links... That is why for the rear, I always set the toe in first and foremost, only then , turn out equal amounts on both pivot balls to get the right rear camber.
Old 08-05-2003, 08:43 PM   #2931
InitialD's Avatar
Agreed that when it's new, the holes do not align properly. But after in about a few times of taking out and putting the upper deck, the holes on the upper deck and the front bulkheads somehow align. Mine does
Old 08-05-2003, 09:13 PM   #2932
Sorry to hear that you had one of the miss aligned upper deck.
Out of six 705 I know of only one had that problem and was solved by loosen the bulkhead from the chassis then tighten the upper deck to the bulkhead while tighten the screws to the bulkhead from the chassis. It will all come together perfect.......good luck!
Old 08-05-2003, 09:17 PM   #2933
Que
should i order a new top deck will that solve the problem? or should i get new bulkheads
Old 08-05-2003, 09:20 PM   #2934
khyber's Avatar
Default 706?
Wow cool .... if it's true I am gonna wait for 706 then and i can save some money I am thinking to get another 705 but seems like I'd better wait now
khyber is offline   Reply With Quote
Old 08-06-2003, 06:09 AM   #2935
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Im running 45 shore TRC fronts in 26mm and 30 mm rear 40 shore TRC's. As for the track I ran out, it is an banked oval with an infield, so there is one really sharp 180 left turn that needs to be taken slower than any other turn in the track. Maybe that could be it. I want to see how the tires wear going back to stock settings in the rear. I have also taken the approach to set toe in, and then equal turns to bring it out to reflect the correct negative camber. I guess that way, you always know your track width is always going to be the same L&R.
Also, I was checking out Ralph B's setup and he runs a 5mm spacer and the stock is 7mm high, do you know what the difference in handling characterists would be for doing that?
John Fontaine is offline   Reply With Quote
Old 08-06-2003, 09:06 AM   #2936
InitialD's Avatar
Putting 5 mm spacers on the rear uprights instead of 7 mm makes for slightly lowered rear roll center. A lowered rear roll center introduces more rear traction as it allows the car to roll more than a car with 7 mm rear spacer.
4 to 6 mm spacers are apparently a sweet spot. Try it. What I use for spacers are blown out bearing casings. The ones for the 2 speed layshaft (in the rear bulkheads) and the mid bearing block layshaft are perfect and they are 5 mm thick. I believe their size is 6 x 13 x 5.
Old 08-07-2003, 12:56 AM   #2937
Que
what size were the impulse spacers?
Old 08-07-2003, 01:05 AM   #2938
InitialD's Avatar
The original Impulse Streetspec does not come with any spacers on the rear hubs. Using rubber tires, these spacers are not required.
On the Impulse PRO kit, this is when the 7 mm spacers were first introduced. They are a standard feature in the 705 kit also. Same 7 mm spacers.
Old 08-07-2003, 01:32 AM   #2939
Que
I think that Serpent should make a 6mm 5mm 4mm for tunning purposes that would be a big help in tuning if we could lower the rear rool center!!!!!!!
Hey Serpent are you hearing this!!!!!!!
Old 08-07-2003, 01:43 AM   #2940
InitialD's Avatar
Well, I think they are in the process...
For the moment, the best and most cost effective way is to use broken bearings that you want to throw away. Just read what I have suggested earlier.
Else, you could also use the engine aluminum washers. If you have extras, you can use them as spacers too. The silver ones that come in the kit are about 2.5 mm thick. For 5 mm spacers, you can use 2 of this shims stacked on top of each other on each side.
For the rear floating GTP mount that I'm currently using on the 705 to mount the Lola shell, I'm using one of these spacers on each side of the rear hub. 2.5 mm is about the max spacing the rear GTP flooating mount will allow without causing any binding.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
