Old 07-30-2003, 01:01 PM   #2881
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Originally posted by nizee
How about sending some to me if it works !
If I like how it comes out sure. Do you think there is any reason to cover both the sides of the ball dif or just the side without the the belt guide? The short side of the dif has a ridge to help junk from getting to the balls, why didn't serpent engineer the left side the same as the right?!?
John Fontaine is offline   Reply With Quote
Old 07-30-2003, 01:33 PM   #2882
Send a message via ICQ to nizee
It would be better if you can think of a way to cover both side. But you also gotta think of the drag that piece going to have, if any.
nizee is offline   Reply With Quote
Old 07-30-2003, 02:48 PM   #2883
I dont believe that they will have too much drag... the left side of the ball dif is what will accumulate the most gunk as the right side is well protected by the molded ridge and also since it is in close proximinity to the bulkhead/bearing. My main focus is going to be covering the left side using the three holes like serpents parts make. We'll see how it works out. I'll keep you posted.
Old 07-30-2003, 07:44 PM   #2884
taz5176's Avatar
Default belt part #
hey d
forgot to ask u which belt (68 toothed, 204mm) u use for the rear? part #?
taz5176 is offline   Reply With Quote
Old 07-30-2003, 08:19 PM   #2885
InitialD's Avatar
Default Re: belt part #
Originally posted by taz5176
hey d
Get it from the belting shop as Serpent does not produce this. You can specify the width you want. Mine is 6 mm. Then specify you want a timing belt which is 204 mm in length with 68 tooth (i.e. 3 mm pitch).
Old 07-30-2003, 09:23 PM   #2886
taz5176's Avatar
Default Re: Re: belt part #
hmmm... tat is gonna be tough. wat do u mean by 3mm pitch? pls forgive me for this question, wat is a belting shop?
Old 07-30-2003, 09:40 PM   #2887
InitialD's Avatar
Default Re: Re: Re: belt part #
Any shop that sells belts for machinary stuff. Pitch is the distance from one tooth to the other. So 68 tooth x 3 mm = 204 mm in total length.
Old 07-30-2003, 09:54 PM   #2888
taz5176's Avatar
not sure if i can get tat here
Old 07-31-2003, 12:23 AM   #2889
taz5176's Avatar
If you're using the FPS diff, then these two plates that come with the 15x28x9 thrust bearing will be used.
15 mm inner diameter
28 mm outer diameter
9 mm thickness
hey d
so, can i say 9mm is oso the thickness if the balls? but 9mm is abit too big? or 9mm is the total thickness of the thrustbearing & the 2 plates?
Old 07-31-2003, 09:04 AM   #2890
InitialD's Avatar
Yes. The total thickness of the thrust bearing assembly. The plates are part of the thrust bearing.
Old 07-31-2003, 09:04 AM   #2891
modellor's Avatar
9mm is the overall width of the bearing with the sides. The balls are normally around 7mm to allow for 2 x .5mm shields and a .5mm lip on the outer bearing case beyond the shields to hold them.
modellor is offline   Reply With Quote
Old 08-03-2003, 06:43 AM   #2892
Que
On the 705 laying down the shocks like on the 950 is suposed to give more steering by softening the suspension action right?
Que is offline   Reply With Quote
Old 08-03-2003, 08:50 PM   #2893
InitialD's Avatar
Initial steering response will be "slower" than when the front shocks are stood up vertical. Don't get me wrong... It's not like there's a delay or lag time in steering... Just that when the shocks are stood vertical, the responds are somewhat magnified. Laying the shocks horizontal smoothens out initial steering input that makes it very stable during high speed tracks. It makes the shocks softer and more progressive. During mid corner, you get more side bite. So going into high speed sweepers, shocks that are more horizontally layed down will be better for the car.
I find that when the front shocks are stood up, the car needs to be setup so that the rear of the car can respond and react as fast as the front steering input. When you can get it correct, a more vertical shock position will be good for small tight tracks as the car will be sensitive to steering input.
Old 08-03-2003, 09:21 PM   #2894
superk's Avatar
What is the servo horn # for the HITEC servo?? doesserpent make one for Hitec?? I know they don't make one for the steering saver. ...some one told me that Serpent come out with a new HITEC servo adaptor??
superk is offline   Reply With Quote
Old 08-03-2003, 09:34 PM   #2895
paulfitipauldi's Avatar
Smile
Superk,
The Servo Saver insert that Serpent release to use the Hitec servos is #1641 ,, Good Luck!!
Ciao!!
paulfitipauldi is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
