Old 07-24-2003, 10:30 AM   #2791
supra528's Avatar
http://www2.towerhobbies.com/cgi-bin...?&I=LXFBD6&P=7
wat a f*ckin rip off... hahhaa
supra528 is offline   Reply With Quote
Old 07-24-2003, 09:54 PM   #2792
Pit-racer's Avatar
Here's a pic of my 705....
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 07-24-2003, 09:56 PM   #2793
Pit-racer's Avatar
another.....
Old 07-24-2003, 10:08 PM   #2794
Ducati998's Avatar
Hey Pit-Racer how the Ns 3?
Ducati998 is offline   Reply With Quote
Old 07-24-2003, 10:18 PM   #2795
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Talking PitRacer
That S.T.S. pipe you have on your car is a bit restrictive, if you remove the stinger and drill a hole in the baffle then replace the stinger the motor will breath a lot eaiser.
Slotmachine is offline   Reply With Quote
Old 07-24-2003, 10:23 PM   #2796
paulfitipauldi's Avatar
Thumbs up
Originally posted by Pit-racer
another.....
Nice Shell Pit Racer,, I like the top of the body post Too!!
paulfitipauldi is offline   Reply With Quote
Old 07-24-2003, 10:25 PM   #2797
Default Re: PitRacer
Why does just try the RD Logics Tuned pipe??
Old 07-24-2003, 11:23 PM   #2798
Pit-racer's Avatar
What would the hole drilling do for me? and what size? Pipe seems to be fine power wise.
Old 07-24-2003, 11:30 PM   #2799
InitialD's Avatar
That's a lot of toe in in the rear I see. How's the aluminum pulleys treating the belts? No external fuel filter?
And yes, why is there a transponder holder at the side of the car when you already mount the personal transponder in the front?
Old 07-24-2003, 11:31 PM   #2800
InitialD's Avatar
another.....
Ummm, with and without shell is like night and day difference (j/k). Changing to new tires just for this shoot is a good idea.
I think Mark will agree to give you lots of points on the car's cleanliness
But seriously, I think the extended fuel lid protruding out on top of your bodyshell will give you problems when the car overturns. The lid will open and fuel will spill out because the track will inadvertently pull it open when the car overturns and slides on the top of the shell.
Perhaps it will be a better idea if you get a longer cable tie to make the lid extend and protrude out to the rear of the bodyshell. That is what I see most of the team drivers do.
What I do to mine is I make a short loop with the cable tie just like what the AE team drivers do to their NTC3.
Old 07-25-2003, 12:20 AM   #2801
InitialD's Avatar
Originally posted by Que
Hey InitialD what .12 is that you and he are running?
I run a 5 port .12 NovaMega MS engine. My other friend was running the Novamax. Both on 705 and with same gearings.
For your info, the NovaMax is actually based on the new NS12 engine and modded by Italian Novarossi / Serpent driver Massimo Fantini. Watch him out at the 1/8th scale European Championships in Oslo.
Old 07-25-2003, 08:08 AM   #2802
Pit-racer's Avatar
The alum. pulleys seem to be easy on all belts, the front pulley is the culprit of all. Tried the ext. filter and doesn't seem to work for me cause of maint. after a few runs.I find it is not needed.
As for the transp. holders,I run at different tracks and some are not prepared for personals.
Old 07-25-2003, 08:14 AM   #2803
Pit-racer's Avatar
Pics were shot at diff. times. I don't seem to have a problem flipping over as you (oops...) some people do. But I see your point.....thanks. I have been trying out things daily on the car so it just gets brushed off, and goes right back on the track.
Old 07-25-2003, 08:27 AM   #2804
markp27's Avatar
Send a message via ICQ to markp27
Slander, Sir! My lawyer will be in touch!
Anyway - its Friday and its my turn to post some (D1) pictures!
Anyone else cut the rear bodywork like me? I was hoping to increase the rear downforce by means of utilising "ground effect". I notice all of the electric guys do it, but they don't have cooling holes in the body work, so the "ground effect" will be much better.
I suppose the question is: does this work for Nitro cars with cooling holes?
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 07-25-2003, 11:49 AM   #2805
markp27's Avatar
I couldn't resist - it being friday and all
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
