Old 01-21-2003, 09:51 AM   #256
Pit-racer's Avatar
Did any of you 705 owners have problems with the shocks caps popping off? I have adj. shocks on my other serpent cars and never had problems and the only thing I've done differently is glue the bladders to the caps like the manual says. And yes I did screw them on correctly.
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 01-21-2003, 07:08 PM   #257
InitialD's Avatar
Strange that you mentioned it... I had mine popped off on an outing. Tried to fix it back but it seems that the threading on the top of the shock body stripped !! Changed it to a new one though. Will try to take a photo of it if I can find it in the bin when I get back.
Old 01-21-2003, 07:13 PM   #258
InitialD's Avatar
Default Re: OK!!
Originally posted by Dookiestick
Thanks for the info!! I think I am going to give the STS PRO 10 a try and use their upgrades along with a few from the 705 with hopes of having a pretty decent 1/10th scale car. I have a Brand new Dennis Ritchey modifed Collari 5 port thats been sitting for months on the shelf begging to be used. If you find out any other info pleas keep me posted.!!
I also know for a fact that the STS comes with 3 mm stock (there's optional 4 mm chassis) but I'm told there are no side braces like the ones that come with the Impulse.
Anyway you'll be doing a disservice to the Dennis Ritchey engine if you put it in a STS though Should be more fitting to put such a great engine in a 705
Old 01-21-2003, 08:51 PM   #259
Default Overpriced?
Well my thinking is if both cars are all most identical with just a few exceptions, I would rather pay $200.00+ less for the STS PRO 10 II and get the same or near the same performance. Plus I don't think you can ge too much better then that floating rear suspension! And it seems that the STS Pro 10 II offers an upgraded 4mm chassis. With that Aluminum radio top plate and 4mm chassis I think it will be pleanty stiff enough to handle the power and torque. I didn't seem to stop Josh Cryul from winning with it!! Besides... Whatever car I put the Dennis Ritchey modified Collari engine into is gonna FLY!!!!
Dookiestick is offline   Reply With Quote
Old 01-21-2003, 10:09 PM   #260
InitialD's Avatar
Corrections. The STS Maddog 235 mm driven by Josh Cyrul is different than the STS PRO 10 II which is 200 mm. In 200 mm category, Josh Cyrul drove the Trinity Reflex NT.
Good luck on the purchase. Please report to us your findings on the STS
Old 01-22-2003, 11:23 AM   #261
Trader Rating: 2 (75%+)
Cool
Maybe you shouldn't follow the manual!!
PUNISHER is offline   Reply With Quote
Old 01-22-2003, 08:06 PM   #262
Send a message via ICQ to nizee
Pit,
Try not to glue the bladders this time round and use it this Saturday at RPM race. See what happen. My only reason like i told u for not gluing the bladders for easy rebuilding and maintenance. I know the Impulse Pro manual does not indicate to glue.
nizee is offline   Reply With Quote
Old 01-22-2003, 09:51 PM   #263
InitialD's Avatar
Originally posted by nizee
Pit,
The Impulse PRO manual did indicate to use CA to glue the bladders. I know because I did follow it.
On my 705, I did not glue it and still the shock cap came out. I don't think the problem is related to glueing or not glueing the rubber bladders. The threads are simply weak probably.
Yes, by not glueing the bladder, chances are very high that you can use them back again after rebuilding and maintenance.
Old 01-23-2003, 08:15 AM   #264
Pit-racer's Avatar
So did serpent go with a different mold or plastic? I'm gonna have to use my old shocks from the impulse or impact cars.
Old 01-23-2003, 10:04 AM   #265
JJ187RC's Avatar
I have been using the GS bladders in my shocks on my 2WD and both my Pro and my 705 and have not had any problems with the shock top popping off. The only time this did happen was when I got nailed in the first corner after the start of the main.
JJ187RC is offline   Reply With Quote
Old 01-23-2003, 07:31 PM   #266
InitialD's Avatar
As I mentioned earlier, I don't think the bladders has anything got to do with the shock top popping off. I think it's got to do with the material or the thread.
Anyway, I have heard that you can use GS bladders on the shokcs. Can anybody post a picture of it?
Old 01-23-2003, 10:22 PM   #267
OK, my mistake i did not read the manual, you're a champ.
Pit,
You can always try all options (trial-n-error), that's behind R/C game.
See you on Saturday.
Old 01-24-2003, 08:44 AM   #268
Pit-racer's Avatar
I think the material has something to do with it cause I used older shock bodies from a previous kit and was able to tighten it more without it stripping.Also if the bladders aren't glue on line perfect it can also be a problem, so I choose not to glue them at all.
Old 01-24-2003, 11:22 AM   #269
Neil Rabara's Avatar
I just got my 705. Has any one had any problems with the rear diff loosening?
Neil Rabara is offline   Reply With Quote
Old 01-24-2003, 11:47 AM   #270
Trader Rating: 16 (100%+)
Same here, according from the manuel, you are supposed to use CA to glue the bladders......and that is a MUST. I did that on my Streetspec back in 99 and PRO on 02.......I never had the shock cap popped out because of the bladder.....that has nothing to do with it.......like Initial-D said, it is the plastic, but still, my SS and PRO didn't have that problem at all.......the only time I had something similar to that was on my friends HPI NMT right after a 8'-0" jump......
If you got hit by other cars or you hit the board......that is the DRIVER....not the shock.
Go check out mytsn and do a search, I believe Pieter does have an article about shocks called "How to build a perfect shocks?"
RCinfinity....rear diff. lossening at WHERE...? The cap or the diff itself.........? It happened to me several times that my rear diff was......one wheel is spinning and the other does not move at all, but after popping the car several times, its back to normal......and I checked, no gears were stripped at all. Don't know why.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
