Old 07-07-2003, 10:37 PM   #2431
Pit-racer's Avatar
I am using the stock shock towers w/ yellow springs.Both on the 2nd whole out.Can you posts picks?
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 07-07-2003, 10:42 PM   #2432
supra528's Avatar
well... i was talking to a friend who races electric back in toronto but im out west so he cant build it... i think i'd screw it up if i built it... so could i get a link to somewhere online where i could get the premade ones??
supra528 is offline   Reply With Quote
Old 07-07-2003, 10:50 PM   #2433
Send a message via ICQ to nizee
Originally posted by Jump 7 Miles
I don't really believe any Ni-Cd battery (I assume you are talking about Ni-Cd, this is about the only type of rechargable battery avialiable 16 years ago) can last that long. Main reason why Ni-Cd battery fails becasue of the separator between the electrodes oxidized and short out the electrodes. It is a chemical reaction and there is nothing much can be done to stop it. Unless you are playing R/C rockets in space , oxidization will happen. Doesn't matter how you charge the batteries, it will fail eventually, most likely in 4 to 5 years, but not 16 years. Just my thought.
WT
It is not call "Oxidization". Physic and Electronics term call it "Crystalization". The catalyse is the, Voltage, current and air at the same time. When voltage and current flows, those separator create like a "capacitance" effect, which in turn creating crystaline to develop across each other electrodes slowly in terms of micron. This also call CAF effect amount the PCB engineer are facing problem today for designing high density multilayer fine pitch BGA.There is a chance the battery will last that long with the folowing scenario:-
1) The applied voltage drawn from it or the charge is low.
2) The applied current drawn from it or the charge is low.
3) He or She do not use it regularly.
4) Keep the charge rate at normal discharge stage not Full charge.
5) Low humidity places.
Hope that helps.
nizee is offline   Reply With Quote
Old 07-07-2003, 10:53 PM   #2434
Originally posted by InitialD
Hi there, please don't take it the wrong way. The original message and advise was intended for supra528. If you look at his post for help on the car, you'll know that he may not be too familiar with things.
I went through that and I thought I would just share what could happen if you mess up with things. As you know, the what if situations can come when you do not need them the most. Shit happens. Just sharing my personal experience.
If I underestimated supra528's capabilities, my apologies. For all we know, he may have a job like what nizee is having... Doing soldering work for a living If he's just daring enough to want to try it out and solder the pack for himself, why not. My advise is open. If you want it, take it. If you feel it's ridiculous, then just ignore. I won't take heart to that.
I don't do just solder for living!
Just part of it..
Old 07-07-2003, 10:58 PM   #2435
InitialD's Avatar
supra, if you can get the AAA batteries separate, you could probbaly find some LHS near you that you could ask them do solder and shrink wrap the pack for a small fee. You also need to get the plug connector to connect it to the receiver. That depends on what type of Tx/Rx radio you're gonna get. I believe you can get GP batteries that are 800 mAH. Sanyo ones are 750 mAH max.
For people who know how to do it, it's pretty simple and does not take more than 15 minutes. Even faster for those who have spot welding equipment
If you want it premade, I believe you can get it at Ashford Hobbies. Part number is 801173. This receiver pack is specifically for the Serpent 705 and the Serpent 835. It already comes with the plug connector and but it's only 730 mAH. Else if that is not available, you can get part number 1692 which consists of 5 AAA batteries (750 mAH), a piece of wire for soldering connection and a heat shrink wrap. You need to solder these separately.
Old 07-07-2003, 10:59 PM   #2436
InitialD's Avatar
Just part of it..
The receiver pack guru speaks He's alive
Old 07-07-2003, 11:02 PM   #2437
supra528's Avatar
ok... thanks a lot... ill call my lhs and see if they could build one for me
Old 07-07-2003, 11:02 PM   #2438
InitialD's Avatar
Picks as in pics? I'll try to post some even if it's not Friday yet
Old 07-07-2003, 11:08 PM   #2439
markp27's Avatar
Send a message via ICQ to markp27
Come on InitialD, show us the non-D1 pics
markp27 is offline   Reply With Quote
Old 07-07-2003, 11:11 PM   #2440
InitialD's Avatar
You know, it's very difficult to take pictures and purposely make them into non-D1 quality You're the expert
Old 07-07-2003, 11:15 PM   #2441
supra528's Avatar
wats the ordering from ashford like?? how long does it tak e to come?? wats dealing wit them like?
Old 07-07-2003, 11:16 PM   #2442
InitialD's Avatar
... especially after I gave the car a good scrub recently
Old 07-07-2003, 11:18 PM   #2443
I thought u saw mine already?
I'll let u try during the race day.
Old 07-07-2003, 11:39 PM   #2444
markp27's Avatar
That'll be the Photoshop scrub and clean filter?
Old 07-07-2003, 11:48 PM   #2445
InitialD's Avatar
How I wish there was such a filter that I could use to clean the car with the click of the mouse... One of those things I dread doing after weekends Well, I need to keep to keep the car clean to keep the wifey happy
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
