Serpent 705
Old 06-30-2003, 09:08 PM
  #2251
Trader Rating: 2 (75%+)
Cool
Originally posted by supra528
s**t.... i still cant get the servo saver on... i have the right one for jr radios... what should i do?? and i cant really drive down to my not so lhs cuz up in whistler here its like 2 and a half to 3 hrs away....lol
I had trouble putting on the servo saver insert too. It needs a little force to place it on. It like the rest of the car.....everthing fits like a tight glove!
Unlike the Mugen MTX3 rear suspension!
PUNISHER is offline
Old 06-30-2003, 09:19 PM
  #2252
BOWTIE1's Avatar
PUNISHER
can u give me some ## of spurs to get i new to on-road thanks
BOWTIE1 is offline
Old 06-30-2003, 09:38 PM
  #2253
supra528's Avatar
ok.. thanks alot punisher
supra528 is offline
Old 06-30-2003, 11:48 PM
  #2254
BOWTIE1's Avatar
any1 running carbonfiber chassie on there 705??? if so how do u like it and is it worth it? thanks
BOWTIE1 is offline
Old 07-01-2003, 08:57 AM
  #2255
InitialD's Avatar
Default Re: Re: Re: Good answer
Originally posted by Slotmachine
I have found a set up that works very well, and I only loose .5 of a m.m. during a 20 min. run.
Nice Mind sharing your setup? Would be interested to know some alternatives...
InitialD is offline
Old 07-01-2003, 09:08 AM
  #2256
InitialD's Avatar
Originally posted by BOWTIE1
what is the best up grade for the 705?
Punihser is right Just get spurs and pinions. The car runs out of the box race ready. Everything that you need to stiffen the chassis is already provided in the form of carbon graphite side stiffeners. The Centax II and the lightened 2 speed gearbox is state of the art. It gives consistant shifting all the time.
Like Punisher mentioned, if you are running on a smaller track, you may want to gear down the 705 with smaller pinions. To further gear it down, you can optionally get the internal pulleys to make the internal drive ratio bigger. The 22T brake pulley (to replace 23T brake pulley), 17T rear side pulley (to replace 18T rear side pulley) and 47T rear diff pulley (to replace 46T rear diff pulley) are the pulleys to get to achieve better acceleration on a smaller track. I would think that would be the best upgrade
Second comes the FC Steering Blocks
InitialD is offline
Old 07-01-2003, 09:18 AM
  #2257
InitialD's Avatar
PUNISHER
It depends on the length of the track you run on... For spurs and pinions, you have the following options that you can run on your 705;
1st gear spur
50T (902450)
49T (902449)
48T (902448)
47T (902447)
2nd gear spur
46T (902446)
45T (902445)
44T (902444)
1st gear pinion
15T (909575 steel, 909555 aluminum)
16T (909576 steel, 909556 aluminum)
17T (909577 steel, 909557 aluminum)
2nd gear pinion
18T (909578 steel, 909558 aluminum)
19T (909579 steel, 909559 aluminum)
20T (909580 steel, 909560 aluminum)
Unlike other cars, you need not necessarily stick to a particular gear tooth jump for the Centax pinions and spurs. For example, you can use 50T/44T spurs (6 tooth jump) with 16T/18T pinions (2 tooth jump), so long as you tune your engine and 2nd speed gear engagement to suite.
To get a lower set of gearing for even smaller tracks, you can use the optional 22T brake pulley (909242), 17T rear side pulley (801252) and the 47T rear diff pulley (808376).
InitialD is offline
Old 07-01-2003, 09:22 AM
  #2258
InitialD's Avatar
Carbon fibre chassis? I don't think there's one. GPM once made for the Serpent Impulse Streetspec / Impulse PRO but even though a carbon graphite material will provide for a rigid stiff chassis, the material is not a good heat conductor. Hence bad for engine.
InitialD is offline
Old 07-01-2003, 10:49 AM
  #2259
BOWTIE1's Avatar
hmmm i am looking at the guy's 705 or he say it is a 705...here is a pic of the carbonfiber chassie maby u can tell me what it teally is so i dont get mested around on a used car thanks
BOWTIE1 is offline
Old 07-01-2003, 10:53 AM
  #2260
BOWTIE1's Avatar
ok 1 more pic with the body off
BOWTIE1 is offline
Old 07-01-2003, 10:57 AM
  #2261
Accord's Avatar
That is NOT a 705... don't let the guy fool you.
Accord is offline
Old 07-01-2003, 11:01 AM
  #2262
BOWTIE1's Avatar
can u tell me what it is???
BOWTIE1 is offline
  #2263
Accord's Avatar
Looks like an Impulse Pro.
Accord is offline
Old 07-01-2003, 11:11 AM
  #2264
Default Not 705
That is an Impulse Pro (hop-up). Not a 705. How much did you pay for it?
nizee is offline
Old 07-01-2003, 11:14 AM
  #2265
BOWTIE1's Avatar
i have not got it yeti was going to trade a new EK4 for it ... how much is that car worth ????like it sets
BOWTIE1 is offline
