Old 06-23-2003, 12:09 PM   #2056
Send a message via ICQ to nizee
Originally posted by superk
OVA, I use Yellow front and orange rear....I think I use hole #3 front and #2 rear.
InitialD .... yes you are right.. I drove one way b4 with my electric car. So...I perfectly understand how to drive it...the right way with oneway and yheaaa... it actually teach me to drive a bit smoother in and out of the connor.....I actually set the brakes just enough to slow the car down....it's so light that if I keep on the brakes I won't spin out.....any ways...with the way I drive....i'm going to try front salid diff in.....it just a little easier for me to drive.
If you like and you able to drive the above setting is fine. Its all in the matter of preference. I just did the above setting like yours, but i don't use any front shock tower and using the optional laydown shock tower for the rear. We have move to a new track location and it was so loose on my car, that i have a hard time trying to figure out the best setting. My last setting was using the front yellow and orange rear for my last race of the day. It did helps with the rear traction but i'm getting too much oversteer at off trottle, which i don't like. And i introduce to much body roll on a small track, which is not good. I think i'm going to change back to yellow spring on the rear and trey it again next week at the same track. Any inputs?
nizee is offline   Reply With Quote
Old 06-23-2003, 12:43 PM   #2057
Trader Rating: 2 (75%+)
Nizee,
All you have to do is look at my set-up!!
Yeah, I think the yellow springs in the rear will work better on that surface. Also try alittel more toe in the rear for the oversteer or back some steering on your radio.
PUNISHER is offline   Reply With Quote
Old 06-23-2003, 01:44 PM   #2058
Originally posted by PUNISHER
Nizee,
Dude....i have already move my toe-in to -3 as what David told me on my main. Until my brake arm came off (forgot to put the screw in ) and my knuckle arm came off frm the pivot ball and have to quit the race. But thanks for pitting for me though...
Old 06-23-2003, 04:01 PM   #2059
JABRONI's Avatar
Default Driver Rumors
Word has it that Marty Barnes is no longer racing for Serpent, He apparently showed up at the McCoy Championships this weekend with a Mugen.
This is the track that the Sedan Nats Are being held at:
Revelation Raceway in Cal.
Sedan A Main
pos Car Laps time name id avg.mph
1 1 141 40:03.30 BARRY BAKER 120 29.60
2 2 139 40:00.99 PEPE VELEZ 127 29.21
3 6 137 40:03.91 GIL LOSI JR 74 28.75
4 8 137 40:17.83 JOSE CASAS 104 28.59
5 4 136 40:11.96 RON ROSSETTI 25 28.45
6 3 135 40:10.69 ROBBIE COLLINS 22 28.25
7 9 135 40:15.78 MEL SALIGUMBA 61 28.20
8 5 132 40:01.67 TONY NEISINGER 5 27.73
9 0 118 40:01.34 ANTHONY DE DUZMAN 58 24.79
10 7 82 26:29.58 LEO VIRTUSIO 47 26.03
JABRONI is offline   Reply With Quote
Old 06-23-2003, 04:18 PM   #2060
JABRONI's Avatar
Default Retract
Marty Barnes was racing a Picco !!!!
Old 06-23-2003, 04:18 PM   #2061
modellor's Avatar
Yeah. I heard rumours about that a few weeks ago. I believe he is running Mugen with Picco engines. Not good news for Serpent USA.
modellor is offline   Reply With Quote
Old 06-23-2003, 05:23 PM   #2062
Pit-racer's Avatar
Take a look at mine next time nizee......mikey still has problems.
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 06-23-2003, 06:36 PM   #2063
superk's Avatar
Well..for my parking lot track...they put some sugar water on the track....I forgot to mension. So..with a slicely ruff serface with sugar water on the track...the car give me alot of puch into the cornor. I did some chage and see alot of improvement on the car. I give more caster to the front and seem like I have more agressive steering into the cornor.
Well...next week ..I'm going to try a bit stiffer setup with the spring and may be go up a little on the shock piston (harder oil) see what the car will do. I think I have a bit too much body roll.
superk is offline   Reply With Quote
Old 06-23-2003, 07:05 PM   #2064
EVOLUTION's Avatar
I think you heard wrong,he is running for Picco.
I was searching mytsn a week ago for any formal publication but didn't find anything anyone know what happened?
EVOLUTION is offline   Reply With Quote
Old 06-23-2003, 07:31 PM   #2065
modellor's Avatar
Cool. I knew he had left Serpent but you know what rumours are like. They are only ever half right . But I knew he was connected to Picco. Its on either the Picco or Paris Racing website.
Not sure of the reason why though.
But lets just say I'll be staying with Serpent next year in 200mm but I will be selling my 705 (fact).
Old 06-23-2003, 07:48 PM   #2066
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Thumbs up Set up`s!
I think I have a good set up for you guy`s. First shorten the front wheel base like they do on the 950,next use serpent 35/weight oil in the dampeners,set the fronts at 2 holes&the rears at 3.Mount the front dampeners on the bearing blocks,and the rears on the middle of the shock tower& the bottom of the dampener on the rear arm. 2.5deg. toe in on each rear ,0front toe3% rear camberand 2%front I run no spacer on the rear upright and the one way in the front. For braking try the Mugen teflon brake pads, you have to trim them a bit but it is well worth the time.
I hope this works as well for you as it does for me!
R/C Painter
Slotmachine is online now   Reply With Quote
Old 06-23-2003, 07:50 PM   #2067
Angry forgot 1 thing
Yellow springs all the way around
Old 06-23-2003, 08:01 PM   #2068
EVOLUTION's Avatar
Ok now i'm a fair person and let you in on that secret(well it wasn't a secret,i read it off the grid )now it's your turn.
You say you're not racing your 705 so your either going back to the impulse(not) or you have a secret that i want in on,is this another RUMOUR or do you have something solid?
Old 06-23-2003, 08:21 PM   #2069
Smile
I hope Serpent come out with a new 200mm soon!
There are a lot of nice and competitive cars coming out on to the market now days.
It only makes sense for Serpent to come out with a newly design 200mm car to compete with this new cars coming!! Its EVOLUTION in the hobby world!!
As for Marty Barnes, I would to race any kit that someone gives me for a fully sponsorship….Serpent USA is stingy to their sponsors drivers.
Old 06-23-2003, 08:22 PM   #2070
modellor's Avatar
Well I wont be reverting to an older model for sure. But even if they do bring out a completely new car next year they are not being dishonest about the thing. They never said that the 705 was a new car. They purely made the Impulse better and changed the names to let people differentiate between the different scales (which is stated clearly on the MYTSN website somewhere). All they have done is alter the weight distribution and add on a few 1:8th and 235mm parts to enhance the performance of an already great car to allow it to compete better against the other cars on the track. They even offered a complete upgrade kit for existing Impulse runners.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
