Old 06-12-2003, 11:20 AM   #1936
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Thanks for the direction.
John Fontaine is offline   Reply With Quote
Old 06-12-2003, 02:27 PM   #1937
Neil Rabara's Avatar
Originally posted by Proficar403
Is anyone using the novak synthesized receiver? Are there any tricks to getting easy access to the adjustment screws while still keeping it protected?
Hi Arun
This is Neil, I raced over at Hurricane for the month of March 2002. How are things over there?
Neil Rabara is offline   Reply With Quote
Old 06-12-2003, 05:22 PM   #1938
Arun's Avatar
Hey Neil...It is interesting running into you like this. Things are going OK over at Hurricane Motorsports. I recently got the track record in electric touring with my tc3.
Overall, however, touring has seemed to drop off. Everyone, it seems, is running oval cars. It is very dissapointing. I will be moving to Athens, GA soon to go to college, and I am confident I will find some good gas touring racers there, so that should be fun.
Thinking about getting a 705? I would highly recommend it. I have had an impulse for a while, and it is basically the same car. I will be getting a 705 pretty soon. The car is, overall, very durable. Broken parts are usually the steering blocks or the front and side belt, if anything. But that is only if you hit stuff.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 06-12-2003, 09:52 PM   #1939
Congrats on college. I already have a 705, gave up on the NTC3. I need to race it more often, I've been mainly racing electric. Too bad about hurricane, if I make it out there again, I'll try and stop by. I hear Athens has a couple of fine tracks nearby. Keep rc car racing a hobby as you go through college, grades are more important. Talk to you soon. Laterz.
BTW, picked up a few sponsors along the way!
Old 06-13-2003, 01:45 PM   #1940
J_Longbrake's Avatar
Trader Rating: 20 (100%+)
Head Shims?
Couple questions for you guys. I just bought a used JP that has about a gallon of 30% through it. I personally have always run 20%. Since this motor was run with 30% the head has been shim'd. I know I need to remove some or all of these shims to run the lower nitro %, but I don't know how many or what kind of a clearance I am looking for between the top of the piston and button head? Any insight would be most appreciated.
Thanks, J Longbrake
J_Longbrake is offline   Reply With Quote
Old 06-13-2003, 03:07 PM   #1941
InitialD's Avatar
Default Re: Head Shims?
Thanks, J Longbrake
Could you tell us what shims are currently on the button head? There should be an aluminum shim (0.3 mm). Be sure to check under this aluminum shim if there are any other copper shims (0.1 mm each). These copper shims are thin and they may be stuck together as one piece and very difficult to separate them.
If I was running 20% nitro, I would leave the stock aluminum shim (0.3 mm). But this depends on the ambient temperature around you. If hot and humid, I would add 0.1 mm (bronze) shim to the stock (total 0.4 mm).
As to the type of clearance that is needed, Motorman gave some pointers recently at this thread
Old 06-13-2003, 03:43 PM   #1942
Accord's Avatar
Send a message via AIM to Accord
Okay guys, well apparently the problem was infact a messed up front bearing. I bought a new front bearing, and I talked to Serpent USA and they told me I have to heat the engine up in a toaster over or something and then pop it out, but in the process the main bearing would be damaged and I would have to replace that .
Also, I am having an impossible time trying to get the Flywheel off, so does anyone have any tips on getting it off?
How can I easily change out the front bearing without damaging anything?
Accord is offline   Reply With Quote
Old 06-13-2003, 04:03 PM   #1943
JABRONI's Avatar
Default Engine Tool
This is what I use, It will take you about 10 seconds and a couple of pulls.
Very easy to use,
It is made by ofna,
Just type ofna engine tool or OFNA beaing tool in a search engine and you will find one.
JABRONI is offline   Reply With Quote
Old 06-13-2003, 04:04 PM   #1944
Accord's Avatar
Anything I could do on my own without having to buy any special tools? The reason is I have to have this motor ready to race tomorrow .
Old 06-13-2003, 04:10 PM   #1945
modellor's Avatar
Just give the back of the flywheel a few gentle taps with a set of pliers and it will pop off.
modellor is offline   Reply With Quote
Old 06-13-2003, 04:11 PM   #1946
Trader Rating: 2 (75%+)
Smile
YES, JABRONI
Beat me to the OFNA bearing puller #10797.
Nice tool to have
PUNISHER is offline   Reply With Quote
Old 06-13-2003, 04:15 PM   #1947
You can try the oven method.
A friend pull his motor bearings with a screwdriver plastic handle and a hammer! Just give it some wacks!!
Old 06-13-2003, 04:25 PM   #1948
Accord's Avatar
I just got the flywheel off with a flathead screw driver, so now i've got to remove the piston. I tried sliding the piston rod off the crank, but it is held on by mabye .3mm and I can't force it off anymore. Any other tips for getting pistons off?
Old 06-13-2003, 04:59 PM   #1949
dg8one's Avatar
used a heat gun and towel
dg8one is offline   Reply With Quote
Old 06-13-2003, 07:05 PM   #1950
Default Re: Re: Head Shims?
Okay, there is only the 0.3mm shim in the motor right now so I should be good to go. Thanks for all the help.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
