Old 06-07-2003, 12:47 PM   #1831
Originally posted by markp27
Since about the age of 3 I had a huge interest in F1 - an uncle used to work at the Silverstone circuit and this helped fuel my interest. From there it was a passion until about 3 years ago.
I hate modern F1 - it's not the F1 I knew and loved. For a few years I worked on the F1 circuit as a photographer and I saw each year how it was harder and harder to see the drivers and how much more closed F1 became.
At the same time I covered the Le Mans 24hrs race - although it too has been modernised, it still holds a very magical element. I did the full 24 hrs and loved every moment!!!!
I love prototype cars (especially the old Porsche 962s) and now this is my only real passion left in motorsport.
The RC racing scene (especially the 1/8th) reminds me much of the early days in motorsport. When I went to see the EFRA race a couple of weeks ago, it was like F1 of maybe 30 years ago! Fantastic.
My passion for sports prototype racing will definately lead me to buy a 950 But at the moment, those things are probably too fast for me
Cheers, Mark.
I also missed the prototype cars. We had the IMSA GTP series here awhile back. Porsche 962s, Jaguar XJ14s, Nissans, Buick Hawk, Corvette gtp, Toyota gtp, etc.
There's nothing like the sound of V-12 jag going the down straight.
Sometimes I post just to look at Kraig's avatar
RoyU is offline   Reply With Quote
Old 06-07-2003, 01:02 PM   #1832
markp27's Avatar
Send a message via ICQ to markp27
Default International racing colours
Originally posted by modellor
I think you are right about the German colour being white. I believe they used white and then switched to Silver when Mercedes entered Grand Prix racing. I am not sure about the BRG myself. But I have pictures somewhere with the old Bentleys done that colour.
Here you go guys, just found this for anzone who's interested in the history of racing:
http://www.miata.net/misc/racecolor.html
Quite interesting!
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 06-07-2003, 01:04 PM   #1833
markp27's Avatar
You're speaking my language, RoyU!
Old 06-07-2003, 01:06 PM   #1834
supra528's Avatar
k... thnx for all the help
supra528 is offline   Reply With Quote
Old 06-07-2003, 04:38 PM   #1835
supra528's Avatar
okl... i got more q's... ok... i was just skimmin over the manual and i have a few questions... at my lhs they gave me anti wear grease and ball diff grease... now... is this what im supposed to use them for?? i use the ball diff grease on the balls in the rear diff... and i use the anti wear grease for everything else that says gr.... and i asked this a few weeks ago i think... its about screwing the clutch nut on to the shaft... r u guys sure i dont need a piston locker?? cuz when i take everything off to clean it, when i put it back on wont i need something to prevent the crank from turning??
Old 06-07-2003, 04:41 PM   #1836
supra528's Avatar
oh... and i have 2 types of thread lock... one is tamiya blue one and the other is permatex blue... which should i use??
Old 06-07-2003, 04:51 PM   #1837
Accord's Avatar
Send a message via AIM to Accord
You should use Serpent One-Way Lube for the front one way diffs.
You do not need a piston locker!
Generally all blue thread lock is the weakest, however there many be differences between brands. Check the bottles and see if you can tell which one is weaker and use that, if you can't, use the Tamiya blue threadlock. Also, do not use any thread lock on plastic parts, only use it on metal to metal parts.
Accord is offline   Reply With Quote
Old 06-07-2003, 04:52 PM   #1838
supra528's Avatar
yah.. i know.. but for the ball diff grease, should i put that on the balls in the diff??
Old 06-07-2003, 05:33 PM   #1839
supra528's Avatar
oh.. and for the piston locker, will i need one to put on the clutch nut after i hvae run the engine and the compression has decreased??
Old 06-07-2003, 06:13 PM   #1840
supra528's Avatar
ok... one other question before i forget.. do i use the collet included wit the 705 or the one from the engine?
Old 06-07-2003, 08:30 PM   #1841
sparksy's Avatar
Trader Rating: 14 (94%+)
Permatex thread lock has a few blue colours....
you want to use their "nut lock" blue. The other blue is too strong for some RC applications
sparksy is online now   Reply With Quote
Old 06-08-2003, 05:19 AM   #1842
dg8one's Avatar
Originally posted by InitialD
I think Paul from Puerto Rico (paulfitipauldi) used them before. Part number is 808347 and it comes in 8 pieces. It is very light but you may find that the stock steel ones are harder for durability.
Anyway, note that there is the shortened aluminum pivot balls meant for the new FC steering blocks. Part number is 801219. They come in 4 pieces. Do not confuse this with the other aluminum pivot balls.
Paul mistakenly bought the 808347 instead of the 801219 to be used with the new FC steering blocks.
thanks a lot
nelly
dg8one is offline   Reply With Quote
Old 06-08-2003, 06:05 AM   #1843
supra528's Avatar
k.. thnx.. and wat about the collet and balldiff question... and will i need a piston locker after the engine has been run for a bit??
Old 06-08-2003, 06:06 AM   #1844
supra528's Avatar
and my threadlock is the permatex medium strength blue thread lock... so should that be fine??
Old 06-08-2003, 08:17 AM   #1845
n1technik's Avatar
use the collet that came with your kit. and about the diff, when i had impulse, i never lubed rear ball diff. just take it apart every 2-3 races and just clean it. never had problem with it till i sold that thing.
and about piston locker, what you can do is put alot i mean alot of afterrun oil and tighten the glow plug (before doing so, make sure piston is in the lowest postion)
and when your work is over, just take out the glow plug and put it on a starter box (make sure to put something over the glow plug hole) for a second or two.
why do you need a piston locker anyways?
n1technik is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
